Rear Wheel Help
    Any oil wet or misting?
    Rev,
    Is the output shaft bearing in the Middle Drive still good or is has it started to fail or come loose and the output shaft is trying to crawl out of the drive, pushing the u-joint and drive shaft back and sideways?
      I was just out looking at some swing arms I have in the garage and at my bike to see what could cause the problem you are having assuming the middle drive is good.. There are only 2 things I can see that might cause it.
      #1 - Your engine mounts are worn and are letting the engine drop down in the rear too far. That u-joint is bolted to the middle drive and depends on the rubber engine mounts to keep it centered properly in the drive line tube which is mounted to the frame via the swing arm bearings. Check your engine mounts for wear. Particularly the rear mounts that the long bolt goes through that your foot pegs are mounted with. Be sure the rubber is in good shape and that bolt is centered good in them.
      #2 - The bottom of the swing arm somehow got caved in right there at the u -joint and is bent up into it.
      • TheRev
        • Jun 2012
        • 235
        • Madison, Wi.
        #63
        How would I check that? I will go out in a few minutes and wiggle the U Joint and see if there is any play.
        Originally posted by 3Phase
        Rev,
        1979 xs1100f
        New Fuse Box
        Progressive Shocks
        Gold Valve Emulator
        Dyna Coils
        Electronic Flasher
        Led Headlight
        Led Turn Signals
        4 Led Driving Lights
        2nd Gear Fix
        Auto Cam Tensioner
        Digital Dash
        Stainless Braided Lines
        R6 4 Piston Calipers
        Stainless Bolt Kit
        Maier Fairing
        Dyna Balancing Beads
        Spin On Oil Filter
        Stebel Nautilus Horn
        Plasti Dip Rims
        ISO Grips
        • TheRev
          • Jun 2012
          • 235
          • Madison, Wi.
          #64
          I was thinking the same thing about the rear of the engine. What would be the best way to check those mounts? Take the foot pegs out, remove the long bolt and remove the mounts? How would I know if the middle drive is bad? When I spin the U Joint it spins nice and smooth by hand. So I am assuming it is fine.
          1979 xs1100f
          New Fuse Box
          Progressive Shocks
          Gold Valve Emulator
          Dyna Coils
          Electronic Flasher
          Led Headlight
          Led Turn Signals
          2nd Gear Fix
          Auto Cam Tensioner
          Digital Dash
          Stainless Bolt Kit
          Maier Fairing
          Spin On Oil Filter
          Plasti Dip Rims
          ISO Grips
          • TheRev
            • Jun 2012
            • 235
            • Madison, Wi.
            #65
            So I went out and rotated the U Joint. There is absolutely no play either horizontally or vertically. So I am assuming that the middle drive is good.
            Rev,
            1979 xs1100f
            New Fuse Box
            Progressive Shocks
            Gold Valve Emulator
            Dyna Coils
            Electronic Flasher
            Led Headlight
            Led Turn Signals
            2nd Gear Fix
            Auto Cam Tensioner
            Digital Dash
            Stainless Bolt Kit
            Maier Fairing
            Spin On Oil Filter
            Plasti Dip Rims
            ISO Grips
            • TheRev
              • Jun 2012
              • 235
              • Madison, Wi.
              #66
              I went out to look at the swing arm. I took some pics. Basically the u joint has been hitting the swing arm on the left and right sides not the top and bottom. So I would assume the engine is right where it is supposed to be horizontally. Is that a good assumption? I have included some pics of the gouges in the swing arm.
              1979 xs1100f
              New Fuse Box
              Progressive Shocks
              Gold Valve Emulator
              Dyna Coils
              Electronic Flasher
              Led Headlight
              Led Turn Signals
              2nd Gear Fix
              Auto Cam Tensioner
              Digital Dash
              Stainless Bolt Kit
              Maier Fairing
              Spin On Oil Filter
              Plasti Dip Rims
              ISO Grips
                You should be able to visually check them, you'll be able to see if there is a problem. You could put a jack under the rear of the engine and see if you can raise it enough to stop the rubbing.
                One other thought I had was if you or the PO has had the driveshaft pulled out of the u-joint it may not have gotten snapped back in there straight and is wobbling. trbig had that happen along the road in Tennessee a couple years ago when he pulled his middle drive to check it.
                  Just saw the pics you posted. It looks like that u-joint is either wobbling in there like I said, or is coming apart or the wrong joint.
                  How about a pic of the u-joint.
                    I just had another thought, it would be too easy though.
                    The only thing I can see that COULD rub there is the bolts that hold the u-joint to the middle drive. Did you have the bolts in with the heads on the u-joint side or the MD side?
                    If you have them in with the heads on the MD side, the tips of the bolts are hitting the swing arm.
                    • TheRev
                      • Jun 2012
                      • 235
                      • Madison, Wi.
                      #70
                      I believe the bolts are not the originals. Perhaps the bolts are the problem. Here is a pic of the U Joint.
                      1979 xs1100f
                      New Fuse Box
                      Progressive Shocks
                      Gold Valve Emulator
                      Dyna Coils
                      Electronic Flasher
                      Led Headlight
                      Led Turn Signals
                      2nd Gear Fix
                      Auto Cam Tensioner
                      Digital Dash
                      Stainless Bolt Kit
                      Maier Fairing
                      Spin On Oil Filter
                      Plasti Dip Rims
                      ISO Grips
                      • TheRev
                        • Jun 2012
                        • 235
                        • Madison, Wi.
                        #71
                        I took the shaft out when I dismantled the bike. What do you mean by snapped back in? I don't remember hearing a snap when I pushed it into the u joint. Are you supposed to push the shaft onto the u joint and then put the wire clip on or push the shaft in with the clip in place? When I rotate the u joint there is no vertical or lateral movement.. It seems very solid.
                        1979 xs1100f
                        New Fuse Box
                        Progressive Shocks
                        Gold Valve Emulator
                        Dyna Coils
                        Electronic Flasher
                        Led Headlight
                        Led Turn Signals
                        2nd Gear Fix
                        Auto Cam Tensioner
                        Digital Dash
                        Stainless Bolt Kit
                        Maier Fairing
                        Spin On Oil Filter
                        Plasti Dip Rims
                        ISO Grips
                          There shouldn't be nuts on the back of those 4 bolts, the u joint itself has it's own threads. Not the correct bolts either.
                            What I mean by snapped back in is there is a snap ring around the splines on the driveshaft that snaps into a groove inside the u-joint receptacle. It has been discussed in the 750/850 final drive swap that this actually does nothing but make it more difficult to install the driveline.
                            If the driveline doesn't slide completely into the u-joint it will wobble, vibrate and booger up the splines on both.
                            You say those aren't the original bolts in the u-joint? Are they longer than the originals?
                            I see you have them running with the heads toward the MD. Try running them the other way. With the heads at the u-joint side and the nuts on the MD side.
                            • TheRev
                              • Jun 2012
                              • 235
                              • Madison, Wi.
                              #74
                              So do you think this is my problem? Do I take the nuts off and use the bolts or try to find the origionals?
                              1979 xs1100f
                              New Fuse Box
                              Progressive Shocks
                              Gold Valve Emulator
                              Dyna Coils
                              Electronic Flasher
                              Led Headlight
                              Led Turn Signals
                              2nd Gear Fix
                              Auto Cam Tensioner
                              Digital Dash
                              Stainless Bolt Kit
                              Maier Fairing
                              Spin On Oil Filter
                              Plasti Dip Rims
                              ISO Grips
                                You know, your right Phil? I had to go look because it's been a while but THERE IT IS!
                                Those bolts are hitting because they don't stick back that far.
