Valve Adjustment Pictorial
    • 9980
    Same-same.........
    Maybe a problem that was corrected? Mine is only 2 or 3 years old.
    • Rasputin
      • 3189
      • Lacombe, Alberta, Canada
      #47
      Like I said the MP tool works for me. It is just a bit more finicky to use and the other was easier. But I did not have to grind any off the MP to use it either.
      2-79 XS1100 SF
      2-78 XS1100 E Best bike Ever
        • 9980
        What part did you have to grind Steve?
        • Rasputin
          • 3189
          #49
          This is the pic from xssiveone's post that shows where he had to grind it. I do not know if it is the same for other members or not.
          http://www.angelfire.com/on3/myXSsiv...MotionPro3.jpg
          Whoops that did not work.
          2-79 XS1100 SF
            #50
            I haven't done anything with mine yet, as I have yet to use it. I did look at using it when I did the valves on the SG, and it appeared to me that mine needing grinding in two places; a bit like shown on the one in the link, but also on the inside curve as mine looks 'fat' through there; I believe that's where Phil had to grind his. It certainly wouldn't fit as-is...
            I may go ahead and mod it to fit, then post another tutorial using the MP tool before I button-up the motor I'm working on. It's winter, I don't have anything better to do...
              • 8767
              Like this...
              Had to ream out the bolt holes a little too.
                • 9980
                Why? Did it contact the cam?
                If so it must have been installed incorrectly. Mine never came close to the cam unless the engine was rotated in the wrong direction then it interfered with the cam lobe.
                Not being a smart a$$, I'm just really interested. I have never had a problem and I'm just curious.
                • Rasputin
                  • 3189
                  #53
                  Mine MP is close to the cam but does not touch. It is fatter there than the yamaha one, but does clear with no issues. As Greg said I am interested in knowing as well.
                  2-79 XS1100 SF
                  • xssiveone
                    • 766
                    • Windsor,Ontario,Canada
                    #54
                    I didn't have any problems with it contacting the camshafts. Mine just wouldn't push the cam buckets down far enough to provdie enough clearance to remove the shims. Grinding on the bottom face, the surface that would contact the cylinder head, allowed the tool to sit lower and push the bucket down further.
                    Brian
                    remembering the same thing!
                    • XS1100_OEM4ME
                      • Mar 2009
                      • 1619
                      • Fort Myers, Florida
                      #55
                      Heads
                      I know there were some changes in head castings over the years, dont know if that matters, mine is OEM 79SF, it takes some getting used to, but works fine once you only open the valve 1/4" or less
                      1980 XS1100 Special
                      1990 V Max
                      1982 KZ750 LTD Twin
                      1974 CB750-Four
                      Past/pres Car's
                        • 9980
                        It's not supposed to "push" the bucket down, it's supposed to "hold" the bucket down.
                        • xssiveone
                          • 766
                          #57
                          You are, of course, correct. I used the wrong terminology.
                          Brian
                          • trdriver71
                            • 360
                            • Edmonton Alberta
                            #58
                            special
                            I use the motion pro tool too to do my shims did take me a while as i had to adjust all 8. The first time i used it i thought there was something wrong but it turned out to be just the operator.
                            '79 XS11SF
                            • EricHa
                              • Mar 2009
                              • 198
                              • IL
                              #59
                              Yesterday I shimmed 5 of 8 on my SF, one exhaust and all on the intake. I got lucky having several of the needed shims from my KZ900 parts laying around. I used DGSXER's method of removing the CCT and loosening the cam caps, as well as Steve's tips. I think petejw's suggestion of just loosening the CCT may have been a good way to go too.
                              As for the MP tool, I guess maybe I was using the tool incorrectly. The KZ shim tool, which works great (on Z engines), actually depresses the bucket, which is what I tried to do with the MP tool. Should I have depressed the bucket with the cam lobe, then held it with the MP tool? Even so, the example of the MP tool that I have puts the tip 1/8" south of the bucket.
                              I also found that I have a repair area at the #2 exhaust shim spot on the head. Spit shim or ham handed shim tool use? I found silicon inside the cam cover :-( and a cracked cam cover at this area. I also have noticed oil residue outside. Someone trying to torque down the cover to stop the leak.I just picked up a replacement cam cover, and wondered if I should put a thin bead of RTV gasket sealant in this area. The head "looks" flat placing a straight edge across the repair, but obviously it's not. This bike was a low mileage but rough project, and I'm still getting to know her.
                              Thanks to everyone for sharing their knowledge/opinions here at Channel 11!
                              1979 Yamaha XS1100SF (gone)
                              Airbox w/K&N element
                              Jardine 4 into 1
                              145 mains, 45 pilots
                              1996 Ducati 900SS CR
                              1977 Kawasaki KZ900-A5
                              1975 Honda CB550K
                                • 2078
                                I had to grind...
                                ...mine also, and Yes, it did contact the cam. I tried for a long time to make sure I wasn't doing something wrong, put it down, did some more reasearch and found others also had to grind theirs so this is what worked for me, and I will say after the modification of the tool it worked well It also works on my '83XJ 750 as I swapped shims between my '80G and the XJ 750 and I only needed a couple from the library to get both bikes back in spec.
                                Here is a look at where I had to clearance my tool...
