Cleaning pistons and Valves
    check how much [they call it ] white metal is left in your gudgeon pin hole top of conrod,[little end] check for slop with your old pin as well,you,ll have some wear[diagonal in the hole] as long as its not square to the rod,[up and down]
    Ummmm... Huh?!?
    • kirmit77
      • Mar 2009
      • 464
      • Kingwood, TX
      Huh?!
      Originally posted by Steptoe
      g,day kermit, if your that far down in the motor check how much [they call it ] white metal is left in your gudgeon pin hole top of conrod,[little end] check for slop with your old pin as well,you,ll have some wear[diagonal in the hole] as long as its not square to the rod,[up and down] .worst comes to worst they can be re-metaled. as for the carbon go to your local auto store and buy a decarbonizing brush that fits in the end of your drill
      I dont get it? white metal??? please explain and maybe some pics?
      Austin Ingalls
      MIDNIGHT FURY
      XJ maxim rear air shocks
      KERKER 4-into-1 exhaust
      Pod Filters
      Money pit.......
      BLACKED OUT
      • BigDick
        • 521
        • McConnell AFB, KS
        It's australian, either you or the motor has to be upside down. Maybe both.
        1980 XS11SG
        Dunlop elite 3's, progressive fork springs, tkat brace
        Stock motor, airbox, carbs, exhaust
        ratted out, mean, and nasty
        • kirmit77
          • Mar 2009
          • 464
          • Kingwood, TX
          #34
          still dont get what yall are talking about.
          Austin Ingalls
          MIDNIGHT FURY
          Pod Filters
          Money pit.......
          BLACKED OUT
            Maybe ol' Dan (Stralya) will translate for us... lol.
            • 79XS11F
              • Jul 2006
              • 3563
              • Ottawa, Ont. Canada
              #36
              The gudgeon pin hole is the small hole at the top of the con rod that the piston pin goes through. The piston pin hole in the piston is also a gudgeon pin hole. The piston pin is the gudgeon. This is based on a search for "gudgeon pin hole". I believe what he's getting at is that there should be no free play straight up and down in line with the con rod. I am not sure what the "white metal" part is about.
              Rob
              KEEP THE RUBBER SIDE DOWN
              1978 XS1100E Modified
              1978 XS500E
              1979 XS1100F Restored
              1981 Suzuki GS1100
              1983 Suzuki GS750S Katana
              1983 Honda CB900 Custom
              • wingnut
                • Oct 2005
                • 695
                • NC
                #37
                The white metal he's talking about is the bushing material in the wrist pin hole on the connecting rod.
                wingnut
                81 SH (Daily Ride)
                81 XS 400
                No man has a natural right to commit aggression on the equal rights of another; and this is all from which the laws ought to restrain him.โ€
                Thomas Jefferson
                • kirmit77
                  • Mar 2009
                  • 464
                  • Kingwood, TX
                  #38
                  No play
                  there is no play in them at all and i think i ran reuse the rings. Should the rings be cleaned at all is my NEXT question...
                  I know... ya'll are gunna have to walk me through this.
                  But if you look at in my point of view.. well.. its worth it!
                  Austin Ingalls
                  MIDNIGHT FURY
                  Pod Filters
                  Money pit.......
                  BLACKED OUT
                  • kirmit77
                    • Mar 2009
                    • 464
                    • Kingwood, TX
                    #39
                    Rings
                    Take that back. The rings are at .584MM. That is the avg top ring gap.
                    Is that ok?
                    Austin Ingalls
                    MIDNIGHT FURY
                    Pod Filters
                    Money pit.......
                    BLACKED OUT
                      • 7607
                      Is that ok?
                      According to Yamaha, 2H7-28197-10 manual, the service limit is 1mm. Standard is .2 to .4 mm. I would go ahead and reuse the old rings. If you have NO freeplay that you can feel in the wrist pins, (gudgeon pin) then the bushing (white metal) is good in the small end of the con rod. With only 9,800 miles, even if the PO NEVER CHANGED THE OIL, you should be good with all the parts.
                      JMHO
                      • kirmit77
                        • Mar 2009
                        • 464
                        • Kingwood, TX
                        #41
                        good deal
                        Thanks DiverRay. The only thing that needs to be done is cleaning the pistons, honing the cylinders, and doing a valve job. Got it down to the bare frame and about to get it painted!
                        Austin Ingalls
                        MIDNIGHT FURY
                        Pod Filters
                        Money pit.......
                        BLACKED OUT
                          Just remember to VERY LIGHTLY hone them. Honing opens up the bore slightly and will widen the ring gaps even more. Then on initial startup, that cross hatch from the hone is going to wear those rings further. So just be careful with that honing and don't go crazy with it.
                          You are putting the same pistons back in the same hole.. right? And remember that the pistons have an arrow on top pointing to the front of the engine and they need to be put in that way.
                          • kirmit77
                            • Mar 2009
                            • 464
                            • Kingwood, TX
                            #43
                            honing
                            should i get rid of the carbon ring at the top of the cylinders before honing? and when you say very light hone like how long?
                            Austin Ingalls
                            MIDNIGHT FURY
                            Pod Filters
                            Money pit.......
                            BLACKED OUT
                              • 7607
                              YES, You DO need to get ride of the ring in order to hone properly. A little bit of Berrymand B12 or Seafoam on a rag will get ride of most of it. Use the back side of a hacksaw blade to clean the rest of it.
                              To hone, just use the FINE stone with light oil for about 30 seconds per cyl. Do ALL 4 and THEN CLEAN WITH SOAP AND WATER(Dawn dishwashing soap works VERY WELL). Look for a series of lines going up and down, about 15 to 30 degree angle from top to bottom. If you see the fine lines, and no "bright" spots, you are good. If you have an area with a "bright" or shiny spot, you will need to hone a little bit more. It's best to UNDER HONE, as you can always hone it a little bit more. Remember to keep the hone moving up and down, from top to bottom, as the drill motor is turning.
                              • kirmit77
                                • Mar 2009
                                • 464
                                • Kingwood, TX
                                #45
                                drill
                                I have done honing on cars and thats it. i really just want to make sure everything goes good so how fast should the drill be going. slow, moderate, or a good bit??? also, i can still see crosshatching on the cylinder walls.... just to let you know.
                                Austin Ingalls
                                MIDNIGHT FURY
                                Pod Filters
                                Money pit.......
                                BLACKED OUT
