LOL......it's been my experience that people that don't trust you can't be trusted.
fuel bottle
I made a little auxiliary fuel tank from an old empty Lucas Fuel treatment bottle.
Drilled a hole in bottom just slightly smaller than some clear line I had.
Cut off cone shaped tip to just smaller than the line also so line could be press fit in both - cut line about 18" long...
Measured where line would be inside the bottle if 2" stuck out bottom of bottle, then drilled 4 small holes in the thick fuel line. Now when bottle is filled, line in hole in bottom keeps fuel from dumping out when filling. Screw cap on and turn upside down after hooked up to a fuel tee.
I just set bottle on frame and it gravity fed the bike fine - you could squeeze lightly or raise up if you need more flow.
The line out the bottom acts as a vent and allows free flow out nose.
Anyway its nice to be able to work without big tank in the way.
JohnJohn is in an anonymous city with an Alamo (N29.519227,W-98.678980)
'81 XS1100H - "Enterprise"
"Not all treasure is silver and gold"Comment
Sometimes I cover it sometimes I don't. I had a piece of cardboard laying right there that fit perfect so I did it. And I definitely don't trust you Greg!
John, they are pretty freakin huge. Don't remember the size, something like 20x17x8 ish. I was only planning on keeping them on there till I found a cover for the real hardball I have but I don't know if I could downgrade in size that much! So if I keep them on there they will get painted, if not they won't. Next they will get tail lights though.Nathan
Theodore RooseveltComment
I like those bags, Nate. If my plastic ones ever get crunched, I will bolt some of those on in their place. Like the lights too.1980 XS 11 Special: The King of Kong, 9th wonder of the world. Pacifico fairing, chopped shield, Yamaha hard bags, Diamond seat, T-Kat fork brace, XJ top end, YICS Eliminator, '80 carbs from Spyder Cycle Works, K&N Air filter, Fuse block, stainless steel valves & reg/rect from Oregon MC Parts. Raptor CCT, XJ air shocks, 850 FD, Sportster mufflers, Standard handle bar, Tusk Bar Risers, SS braided brake lines. Cat Eye speedometer. HID projector beam headlight, LED running lights.Comment
Stripped the tank and fenders on the LG. New color is Black Cherry with a hint of pearl. Then I will try my hand at ghost flames...Whish me luck.
Ty
78 XS1100E - Now in Minnesota
80 XS1100LG - The Punisher
82 XJ1100 - Daughter's Bike
72 Yamaha Mini JT2 - Youngest Daughter's bike (She wants a bigger one now)Comment
This is thew final results for the tank.
Not bad for my first time with an air brush.Ty
Put the cover back on mine. No time to ride it.1980 XS 11 Special: The King of Kong, 9th wonder of the world. Pacifico fairing, chopped shield, Yamaha hard bags, Diamond seat, T-Kat fork brace, XJ top end, YICS Eliminator, '80 carbs from Spyder Cycle Works, K&N Air filter, Fuse block, stainless steel valves & reg/rect from Oregon MC Parts. Raptor CCT, XJ air shocks, 850 FD, Sportster mufflers, Standard handle bar, Tusk Bar Risers, SS braided brake lines. Cat Eye speedometer. HID projector beam headlight, LED running lights.Comment
Carbs for XJ
Finished cleaning and installing carbs on Dylan's XJ550 yesterday. Test run up the street after synch was super responsive. Got back and it wouldn't restart. Dead battery.
Charging up overnight....if it ain't one thing its another!
Finishing carbs today for Great Ranger.
Did battle with the airbox...
Finished carbs on Great Ranger and fought long and hard with the airbox.
I can squeeze the carbs in with box loose and get them into boots, but airbox boots though very pliable just didn't want to go on....tried for an hour, took a break and finally able to get them on. I hate that airbox.
Started it up before sync and things seem good. When I get home in a couple weeks I will adjust them properly.
Feels good to get two bikes back going in two days
Just agreed to do the Lone Star Rally in Galveston in November with friends and booked a hotel, so now I really need to get my bagger build going.
Getting Closer
I installed the new/rebuilt xs rear master cylinder, got the new SS brake lines on and bleed, hooked up the new left handlebar switch from Mikes XS. Just need to get the tank and seat back on and we will see how it goes and stops.1979XS1100SF
K&N's and drilled airbox
Jardine 4in1
Dunlop Elite 3's
JBM slide diaphragms
142.5 main jets
45 pilot jets
T.C.'s fusebox & SOFA
750/850 FD mod.
XV 920 Needle Mod.
Venture Cam Chain TensionerComment
I have been looking at them forever and lately my hands have been killing me so I finally bit the bullet and put some Kuryakyn ISO Grips on!
I also have been noticing lately that I have slowly been getting a groove melted into my left boot
So that pushed me to figure out how to get the floorboards I got mounted. Took some ingenuity but I got it figured out. I did have to take the 3 point case guards off though
Feels pretty good sitting on it I will find out tomorrow morning how it all feels thought!Nathan
CZ
