  • draketrumpet
    • Feb 2010
    • 387
    • Norman, OK
    #46
    Originally posted by Yard Dogg
    Congratulations! I remember the first time I was shot out of a cannon. Did you crank the throttle?
    It really wasn't all that exciting. I've already gone 70 on a highway in the middle of nowhere near here. I don't even think I got to get to 60 b/c I was behind a gravel semi . But, nonetheless, first time going that fast around so many cages.
    • ross
      • Dec 2006
      • 542
      • see signature...
      #47
      progress today...
      hey there folks...progress today....went to the man-cave, looked at the 'rebel devil", said still don't have the parts to complete the project, took a drink of the brew-ha-ha, thought to myself "ain't it a wonderful day!", and tried to decide where to install my 2h7-98990-58-37......"very" optional beer transportation device.....
      ride hard, ride safe.....ross
      rebel devil
      1979 xs 1100f standard
      authenic historical vehicle
      42°36'23.52"N, 82°52'44.78"W
      "I'M IN MY HAPPY PLACE"
      "i got 14 jobs mon....you only got 1 job....you lazy bones mon"
      "if you don't wrench on it, get behind me satan!"
      '96 venture cct.....installed!
      stainless, braided, pvc coated brake lines
      i can translate...deustch, nederlands, 汉语, 漢語, français, ελληνικά, italiano, 한국어, português, русско, español and most importantly, 日本語....
      • XSokieSPECIAL
        • Jun 2009
        • 1631
        • Tulsa, OK
        #48
        Rode mine.
        • STEPPENWOLF
          • Jan 2007
          • 4188
          • CINCINNATI OH
          #49
          Looked at it and then rode a Sportster...
          '80 XS1100 SG
          • draketrumpet
            • Feb 2010
            • 387
            • Norman, OK
            #50
            How could I forget
            I finally checked my tire pressure after at least a month of owning the bike. The tires always seemed firm, so I figured PO had a good amount of air pressure in them.
            Well, turns out I shouldn't have been cursing my forks as much as I have for the wobble I get after I'm warmed up. The cold PSI was 40 front 42 rear
            I'm glad my tires didn't explode. So, I dropped both of them down 4 to see how that goes, and for the short ride I did after doing that, all seemed to be ok.
            • kjohnson
              • Aug 2007
              • 202
              • Wetaskiwin, Alberta, Canada
              #51
              I finally got my replacement idle mix scew from Len @ XJ4ever so I put that in as well as replaced all the washers and o-rings for the idle screws. Put the carbs back on and fired her up for the first time this year. She started up easer than she has previously so I 'm happy about that. Now I just have to colortune and balance properly, after I get a colortune of course.
              I also took apart the side covers to sand/polish the aluminum and prep the insert for paint. Apparently my XJ was originally red as per the edges of the side cover inserts. Poorly painted black as well. I guess It is a good thing I intended to paint it mostly red.
              K. Johnson
              -1978 XS750SF - brought back from the dead with carb
              triple clean and boots
              -1982 XJ1100J - brought back from the dead by
              replacing motor after throwing #4 rod
              -1985 XJ750XN - shim job, oil change, ride. not bad for
              $500 including new rear tire.
              • psycoreefer
                • Feb 2008
                • 1557
                • Minden, NV
                #52
                Well, I rode my 79 to work, also put gas in it...
                On the 81 I added a ground wire for right side controls, checked compression and pulled the carbs apart ->
                I thought I had to tap that #3 emulsion tube a little harder then the rest....now I know why!
                1979 xs1100 Special -
                My Bike:
                [link is broken]
                • DJinNH
                  • Mar 2008
                  • 854
                  • New Hampshire
                  #53
                  lol same here but with my Raider....or at least that's the plan of the day.
                  currently own;
                  1980 Yamaha XS1100 SG
                  2009 Yamaha Star Raider
                  • Wildkat
                    XS Special Gurette
                    • Apr 2004
                    • 3416
                    • Location, Location
                    #54
                    Yesterday...
                    Put the new front tire on the FJ... finally cut the new fuel line for it... jumped her off and listened to her run (with NO idle problems... YEA!!) patted myself on the back since there were no leaks...
                    This morning... cursed the leaks that appeared over night...
                    Yeah... a shocker...
                    Looked at the XS and thought about polishing her... because that's usually all she ever needs...
                    81 SH Something Special
                    79 SF MEAUQABEAUXS
                    81SH Nor'eas tah (Old Red)
                    80 LG Black Magic
                    78 E Standard Practice
                    James 3:17
                    “Alis Volat Propriis”
                    Yamaha XS 1100 Classic
                    For those on FB
                    • Yard Dogg
                      • Mar 2010
                      • 884
                      • Tri-Cities, Wa
                      #55
                      Had a good and bad day. Rode the bike and will some more. My headlight and gauge lights would not work. So I jumped on here and learned how to bypass the headlight relay. Now it works. Then I started to ride. My blinkers would not work right. Came back took the switch apart and cleaned out all the grease I had in it. Found a connection in there I had over looked as a connection previously, the ground slash spring slash ?. Cleaned that up, now they work better than ever. Now I will ride.
                        • 8929
                        I put the 850FD back on my 79F. It blew a seal a month back, so I put the stock 11 unit back on until I got the necessary parts to rebuild it. Haven't test rode it yet, but it should be fine. (knock)
                        • ross
                          • Dec 2006
                          • 542
                          • see signature...
                          #57
                          just some tinkerin'....
                          hey there folks....this was today's progress....
                          at end of post (page 4)......gettin' closer to ridin'!......ride hard, ride safe....ross
                          rebel devil
                          • psycoreefer
                            • Feb 2008
                            • 1557
                            • Minden, NV
                            #58
                            79 special - put gas in it and rode to work
                            81 standard - got the easy outs out and pulled all the stripped jets and screws out of the carbs. Tried the electrolysis thing on the tank and failed miserably, I guess my battery charger is too "smart"
                            My Bike:
                            [link is broken]
                            • draketrumpet
                              • Feb 2010
                              • 387
                              • Norman, OK
                              #59
                              Have you tried using a battery? If you have a spare, use it instead of the charger. Most batteries I know of are dumb enough to put electricity through anything
                              • tinman905
                                • Aug 2007
                                • 946
                                • Orangeville,Ontario ,Canada
                                #60
                                Ordered the green coils wires and new clutch plates today from mikesxs. I have been doing some light polishing on the engine covers and foot/exhaust brackets. Changing my shift shaft seal when it comes in tomorrow.
                                BDF Special
