ZRX1200 Carb Conversion
    • 3983
    Zee head is on. Taking a small coffee break, then cam install. So far, so good.
      • 3983
      Aight. Got it started. No issues. Back to square one with the carbs. Will re-time the bike, then tune with the Mikuni's, first. If it won't hold an idle, I'll go back to the ZRX carbs.
        • 8908
        Wow, what an ordeal to have this happen when doing this carb mod, good that it's back running.
          • 3983
          Well, even with the butterfly shaft seals replaced + intake boots, that hanging idle is still present with the Mikuni's. It kinda sucks, as that head being destroyed was for nothing.
          I have a leak on the front end, which is more than likely coming from the ACCT. I'll check the torque on the head bolts to ensure it's not from the base gasket. I dusted down the bike with AP flour to see if I could find it, and couldn't.
          I'm going to start over with the ZRX carbs.
            • 3316
            Hanging idle is a bummer. ZRX carbs will be a good experience once everything is dialed in, IMO. That's the fun for me, more "modern" carbs vs not made in the same century and making them work like it should. XS 1100 carbs 1970's- early1980's. ZRX1100/1200 carbs 1990's into mid-2000's.
            Did it with ZX11/ZZR1200 carbs on the ZRX. Downdraft carbs from a ram air motcycle adapted to work on a side draft head. Noticeable power increase on the dyno, 5-7 hp, and 2-3 mpg upgrade from stock.
            2001 ZRX 1200
            1982 Seca 750
            1983 Nighthawk 550
              • 8908
              Something that may have been overlooked on the Mikuni is snapping the throttle shut a few times with the butterfly shaft screws loose to properly seat/align all the plates. Then tighten them. Otherwise the throttle plates will probably hang up.
                • 3983
                Lol. No going back with those screws. I blue locktited them and peened them.
                  • 3316
                  Blue Loctite on the throttle plate screws throws loosening of the plates out the window...
                  With that said, I like the idea of putting them in lightly snug and snapping them shut a few times. Could be accomplished in the minutes after using Loctite before it begins to cure. Then snug them down and they are good for eternity.
                  2001 ZRX 1200
                  1982 Seca 750
                  1983 Nighthawk 550
                    • 8908
                    The first time I changed throttle seals, I put the plate screws in with blue locktite, not knowing about the alignment problem. Sure enough there was a hanging idle. If I forced the linkage closed, the idle would come down. I separated the bank and I was able to break the screws loose without too much effort using a JIS serrated tip screwdriver. I can't recall if I used a propane torch or not to heat the screws, but I did get them loose and was able to snap the throttle closed on each individual carb and reset the plates. That indeed was the problem. Carefully using localized heat on the screws shouldn't be an issue regarding the health of the seals as IIRC, the shaft is made of aluminum and will not hold heat for as long as steel would. I wish I remembered this earlier so I could have tipped Ian about this.
                      • 3983
                      For what it's worth: I did indeed do that to get them to seat, when first installing the butterflies (as they were not centered). I'm ready to move on back to the ZRX carbs.
                        • 3316
                        Looking forward to the second round with the Keihin 36mm carbs.
                        2001 ZRX 1200
                        1982 Seca 750
                        1983 Nighthawk 550
                          • 3983
                          Yessir. Pulling the Mikuni's off tomorrow, and reinstalling the Keihins. I'm contemplating ordering larger mains.
