Zee head is on. Taking a small coffee break, then cam install. So far, so good.
ZRX1200 Carb Conversion
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.😎 1 -
Aight. Got it started. No issues. Back to square one with the carbs. Will re-time the bike, then tune with the Mikuni's, first. If it won't hold an idle, I'll go back to the ZRX carbs.1979 XS1100F
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.👍 1Comment
Well, even with the butterfly shaft seals replaced + intake boots, that hanging idle is still present with the Mikuni's. It kinda sucks, as that head being destroyed was for nothing.
I have a leak on the front end, which is more than likely coming from the ACCT. I'll check the torque on the head bolts to ensure it's not from the base gasket. I dusted down the bike with AP flour to see if I could find it, and couldn't.
I'm going to start over with the ZRX carbs.1979 XS1100F
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Comment
Hanging idle is a bummer. ZRX carbs will be a good experience once everything is dialed in, IMO. That's the fun for me, more "modern" carbs vs not made in the same century and making them work like it should. XS 1100 carbs 1970's- early1980's. ZRX1100/1200 carbs 1990's into mid-2000's.
Did it with ZX11/ZZR1200 carbs on the ZRX. Downdraft carbs from a ram air motcycle adapted to work on a side draft head. Noticeable power increase on the dyno, 5-7 hp, and 2-3 mpg upgrade from stock.Last edited by Bonz; 08-13-2026, 06:48 PM.Howard
2001 ZRX 1200
1982 Seca 750
1983 Nighthawk 550Comment
Something that may have been overlooked on the Mikuni is snapping the throttle shut a few times with the butterfly shaft screws loose to properly seat/align all the plates. Then tighten them. Otherwise the throttle plates will probably hang up.2H7 (79) owned since '89
☮Comment
Lol. No going back with those screws. I blue locktited them and peened them.1979 XS1100F
Blue Loctite on the throttle plate screws throws loosening of the plates out the window...
With that said, I like the idea of putting them in lightly snug and snapping them shut a few times. Could be accomplished in the minutes after using Loctite before it begins to cure. Then snug them down and they are good for eternity.Howard
2001 ZRX 1200
1982 Seca 750
The first time I changed throttle seals, I put the plate screws in with blue locktite, not knowing about the alignment problem. Sure enough there was a hanging idle. If I forced the linkage closed, the idle would come down. I separated the bank and I was able to break the screws loose without too much effort using a JIS serrated tip screwdriver. I can't recall if I used a propane torch or not to heat the screws, but I did get them loose and was able to snap the throttle closed on each individual carb and reset the plates. That indeed was the problem. Carefully using localized heat on the screws shouldn't be an issue regarding the health of the seals as IIRC, the shaft is made of aluminum and will not hold heat for as long as steel would. I wish I remembered this earlier so I could have tipped Ian about this.Blue Loctite on the throttle plate screws throws loosening of the plates out the window...
With that said, I like the idea of putting them in lightly snug and snapping them shut a few times. Could be accomplished in the minutes after using Loctite before it begins to cure. Then snug them down and they are good for eternity.Last edited by bikerphil; 08-15-2026, 07:17 AM.2H7 (79) owned since '89
☮Comment
For what it's worth: I did indeed do that to get them to seat, when first installing the butterflies (as they were not centered). I'm ready to move on back to the ZRX carbs.1979 XS1100F
Update is in the post below.Last edited by IanDMacDonald; 08-19-2026, 02:54 PM.1979 XS1100F
Got the ZRX carbs back on. Runs like a raped ape. So, maybe I'll leave it alone.
I have an oil leak from somewhere, so I ran a bead along the front where the cylinders meet the head, along with the ACCT area. I retorqued the head again to 30 Ft. Lbs., thinking it needs more torque.
Next up is pulling the clutch basket again, and swapping one from the parts bike. Then, fabbing new brackets to mount the airbox.1979 XS1100F
