ZRX1200 Carb Conversion
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights. -
Ian, is the cable streching upon use ? Maybe go an 1/8 turn at the arm ?1980 XS1100G "Dolly G" Full Dresser (with a coat of many colors
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Comment
Yes and no going up on the mains.
-What position/groove is the clip on the needle.
- How does it pull/feel once you're up on the main accelerating hard above 6,000 or 7,000 rpm. Reading your previous post today, appears it's running well throughout the power band.
If it pulls good at high RPM acceleration, richen up the needle first, IMO/IME.Last edited by Bonz; 07-22-2026, 05:00 PM.Howard
2001 ZRX 1200
1982 Seca 750
1983 Nighthawk 550Comment
I think I'm in the 3rd position down from the top. From memory of your previous post, I want to lower the clip (#4 slot down from the top) to richen it.Yes and no going up on the mains.
I think I'll go one more turn on the A/F screw, and drop the clip, and report back.1979 XS1100F
Excellent information. The bike is 2.5 turns on the pilots, if it's idling well, my move would be to leave those alone for the moment. Definitely a good next change is going to the fourth clip position.
The AFR gauge change at idle on the ZRX 1200 shows .5 to .7 of a point richer or leaner with a half turn on the pilots. For what it's worth I've run 40 and 38 pilots in those carbs, and the change amount is basically the same with a half turn.
My thought ia a full turn on the pilots and a clip position richer at the same time would take a bigger swing at it then may be expected.
Main thing is you know what you're looking for on the plugs. If it's telling you to do a full turn along with the clip position adjustment, by means go with what it's telling you. Either you undo some richening because it was too big of a swing, or if you don't adjust as much and it's not enough, you're doing another adjustment either way. Kind of the beauty of doing all this isn't it, lol.
2001 ZRX 1200
1982 Seca 750
Yeah, I was looking super-lean, at 2.5 turns on the A/F screws, and 3rd clip position down from the top. I think I'll go half a turn out, as the A/F screws are starting to feel loose at 3 turns. Anything more, and I'd be concerned. And, I'm dropping the clip to the #4 position from the top.Excellent information. The bike is 2.5 turns on the pilots, if it's idling well, my move would be to leave those alone for the moment. Definitely a good next change is going to the fourth clip position.
Main thing is you know what you're looking for on the plugs. If it's telling you to do a full turn along with the clip position adjustment, by means go with what it's telling you. Either you undo some richening because it was too big of a swing, or if you don't adjust as much and it's not enough, you're doing another adjustment either way. Kind of the beauty of doing all this isn't it, lol.1979 XS1100F
Sounds good. Good call on going up on the pilots if three or three and a half turn starts to feel loose. No choice but to do that. 40's will make a difference in cruise mixture. 40p's flow 11% more fuel vs 38's. Since that's one of the main contributors to cruise, you should see some improvement with those on top of going richer on the clip.Last edited by Bonz; Yesterday, 04:54 PM.Howard
2001 ZRX 1200
1982 Seca 750
Gonna take a small break on this. I ordered new carb intake manifolds (upon inspection, there was nothing wrong with the ones I had on, other than external cracking), ANOTHER set of steels, frictions, and springs (cheap eBay set), along with a clutch cover gasket to see if I can figure out what's going on with the clutch. I have the carbs on the bench ready to go back on.
Bonz- I have not gone up yet on the Pilots (again). I'm at 40's right now (started with 38's), and trying 3 turns out (but they're starting to feel loose). I did drop the clip one position to see what it'll do. I do have 42 and 45 pilots to try.
If all works out, my next steps are figuring out how to secure the airbox in place and figuring out the throttle cable. I did order another XJ750 cable (what I'm using currently, as I have SuperBike bars).
I was tempted to drill and weld O2 bungs into the headers, but this is OE exhaust in perfect condition, so I did not want to risk damaging the exhaust. Trial and error. I'm running out of time.
Thanks for sharing the update on the carb jetting. I didn't realize you were already at 40's. Sounds like you're turning and burning, making the changes to dial this in. Sorry about the clutch, that's frustrating.Howard
2001 ZRX 1200
1982 Seca 750
