ZRX1200 Carb Conversion
    • 3962
    Wouldn't adding a steel make it worse?
    I'm not sure, Mike. I DO know that originally upon acquiring the bike, the owner had an extra steel in there. All I know is that I cannot adjust this thing to get it from lurching, when putting it into gear.
      • 2098
      Ian, is the cable streching upon use ? Maybe go an 1/8 turn at the arm ?
        • 3962
        Nah. Brand new cable. Not a cable issue.
        On another note: I pulled the plugs, and certainly FAR from running rich. Very lean. I'm at 140 mains. I may need to go up.
          • 3305
          Yes and no going up on the mains.
          -What position/groove is the clip on the needle.
          - How does it pull/feel once you're up on the main accelerating hard above 6,000 or 7,000 rpm. Reading your previous post today, appears it's running well throughout the power band.
          If it pulls good at high RPM acceleration, richen up the needle first, IMO/IME.
          2001 ZRX 1200
          1982 Seca 750
          1983 Nighthawk 550
            • 3962
            I think I'm in the 3rd position down from the top. From memory of your previous post, I want to lower the clip (#4 slot down from the top) to richen it.
            I think I'll go one more turn on the A/F screw, and drop the clip, and report back.
              • 3305
              Excellent information. The bike is 2.5 turns on the pilots, if it's idling well, my move would be to leave those alone for the moment. Definitely a good next change is going to the fourth clip position.
              The AFR gauge change at idle on the ZRX 1200 shows .5 to .7 of a point richer or leaner with a half turn on the pilots. For what it's worth I've run 40 and 38 pilots in those carbs, and the change amount is basically the same with a half turn.
              My thought ia a full turn on the pilots and a clip position richer at the same time would take a bigger swing at it then may be expected.
              Main thing is you know what you're looking for on the plugs. If it's telling you to do a full turn along with the clip position adjustment, by means go with what it's telling you. Either you undo some richening because it was too big of a swing, or if you don't adjust as much and it's not enough, you're doing another adjustment either way. Kind of the beauty of doing all this isn't it, lol.
              2001 ZRX 1200
              1982 Seca 750
              1983 Nighthawk 550
                • 3962
                Yeah, I was looking super-lean, at 2.5 turns on the A/F screws, and 3rd clip position down from the top. I think I'll go half a turn out, as the A/F screws are starting to feel loose at 3 turns. Anything more, and I'd be concerned. And, I'm dropping the clip to the #4 position from the top.
                  • 3305
                  Sounds good.
                  2001 ZRX 1200
                  1982 Seca 750
                  1983 Nighthawk 550
                    • 3305
                    Sounds good. Good call on going up on the pilots if three or three and a half turn starts to feel loose. No choice but to do that. 40's will make a difference in cruise mixture. 40p's flow 11% more fuel vs 38's. Since that's one of the main contributors to cruise, you should see some improvement with those on top of going richer on the clip.
                    2001 ZRX 1200
                    1982 Seca 750
                    1983 Nighthawk 550
                      • 3962
                      Gonna take a small break on this. I ordered new carb intake manifolds (upon inspection, there was nothing wrong with the ones I had on, other than external cracking), ANOTHER set of steels, frictions, and springs (cheap eBay set), along with a clutch cover gasket to see if I can figure out what's going on with the clutch. I have the carbs on the bench ready to go back on.
                      Bonz- I have not gone up yet on the Pilots (again). I'm at 40's right now (started with 38's), and trying 3 turns out (but they're starting to feel loose). I did drop the clip one position to see what it'll do. I do have 42 and 45 pilots to try.
                      If all works out, my next steps are figuring out how to secure the airbox in place and figuring out the throttle cable. I did order another XJ750 cable (what I'm using currently, as I have SuperBike bars).
                      I was tempted to drill and weld O2 bungs into the headers, but this is OE exhaust in perfect condition, so I did not want to risk damaging the exhaust. Trial and error. I'm running out of time.
                        • 3305
                        Thanks for sharing the update on the carb jetting. I didn't realize you were already at 40's. Sounds like you're turning and burning, making the changes to dial this in. Sorry about the clutch, that's frustrating.
                        2001 ZRX 1200
                        1982 Seca 750
                        1983 Nighthawk 550
                          • 3962
                          Okay, got the carbs back in, and the bike definitely likes the 40 pilots. Idles well. I took it for a short jaunt, but it started raining. I want to put some more gas in the tank and take it for a longer ride with new plugs in, to see where I'm at.
                          From there, I'll have to pull the tank again and figure out the throttle cable and airbox mount.
                            • 3305
                            Here's hoping it ran well for the short jaunt! Looking forward to hearing about the plug check.
                            2001 ZRX 1200
                            1982 Seca 750
                            1983 Nighthawk 550
                              • 3962
                              Interesting. Pulled the old plugs, and put new one's in. Went for a 20-mile ride at various speeds. Cyl.'s 3&4 have rich plugs, but Cyl. 1&2 are lean. Either I need to go up on the mains, or something.
                              I did put the old carb bank back together. I'm tempted to put them back on and see if the vacuum leak is gone.
                                • 3305
                                That scenario is interesting... one and two running the same and three and four running the same. Typically 2 and 3 run lean because of heat trapped in the middle of the head versus 1 and 4 running richer because they get better cooling air along the outside.
                                Did you keep the needles specific to each cylinder when you took the carbs apart? I don't know this for a fact, however does Dynojet use different tapers in their needles? It's not unheard of for different needles for inner and outer cylinders. If the needles are different they could be matched up on those cylinders leading to what you're seeing.
                                2001 ZRX 1200
                                1982 Seca 750
                                1983 Nighthawk 550
