Mystery Carbs
    • 2104
    At 23mm you're close, raising them, which lowers fuel level ( for the newbies) , that'll probably do it.
    • autotech44
      • Apr 2026
      • 48
      #107
      I went up 2mm to 25mm and the level is still about 3mm high. I'm not going any further because the needle out-of-the-seat travel is decreasing too much.
        • 2104
        The idea with the fuel level (4newbs), stated in the manual, is always to have the resting level in the bowl so as not to depend on the gasket too much. I know my stock '80G carbs tune easily and run smooth when running fuel levels are in between the washer and the head of the screw.
        • autotech44
          • Apr 2026
          • 48
          #109
          I've heard the general rule of thumb is a couple mm below the gasket. Right now I'm where the washer meets the bowl.. I'm sure it's the cheap floats causing the problem, but bending that tab any more is too much. Runs good before I even synced or tweaked IM.
          • autotech44
            • Apr 2026
            • 48
            #110
            Sync was only off a little. Started with IM at 3 turns. Had to screw all the way in to get a lean stumble. Left them at 1.5. Blue smoke big time on first start but seemed to decrease the more I ran it. Serious cylinder wash. The crankcase was full of gas.
              Good to hear you got it. Looks like it is now time for your friend to make up his mind what he wants to do.
              • autotech44
                • Apr 2026
                • 48
                #112
                He's coming to get it. I told him too many hands on everything and I've already spent too much time. When a repair becomes a restoration it's not a money maker.
                  Any chance you could post some pictures of the bike? If he doesn't want it someone on here might be interested.
                  • autotech44
                    • Apr 2026
                    • 48
                    #114
                    Looking to make it a cafe racer.
                    Click image for larger version  Name:	PXL_20260405_211943055[1].jpg Views:	0 Size:	243.1 KB ID:	889398
                      Looks comfortable.
                      • autotech44
                        • Apr 2026
                        • 48
                        #116
                        Looks comfortable.
                        You must be referring to the Honda Shadow Phantom in the background.
                          Yes, even with no seat it looks more comfortable than the XS
