Clutch replacement
    • 7947
    Clutch replacement
    I’m going to replace my friction plates and springs. Is there a good reason I can’t or shouldn’t do the job on the sidestand? I would prefer to leave the basket in place if it looks OK. Will the sidestand lean it far enough that I won’t have to drain the oil?
    • 8801
    Check for wear on the basket and the boss where the frictions and steels contact. A high mileage bike will probably show some grooving. The oil level should be low enough to not have to drain with it on the sidestand.
      • 1822
      You might want to replace the kickstart seal when you replace the side cover gasket.
        • 7947
        My ‘80 bike has no kickstart parts. No shaft seal.
        I definitely need to give the sight glass a good cleaning.
          • 1916
          I don't want to speak for Deebs but he may be talking about the seal on the cover where the kick starter would be. 1980 Yamaha XS1100 OEM Clutch Cover | eBay
            • 7947
            Ah. Thanks!
