starter clutch slip
  • speedlimit85
    • Jan 2017
    • 445
    • Gainesville, Fl.
    That ebay kicker is the emergency set up. See the rubber boot? And the one on your bike swivels. The ebay one Is put away with that clip and bolted on the spline to kick it then put it back.
    80 G
      • 1967
      4 oz of marvel mystery oil and it's working better. I plan on going more miles then changing to 10-40 for awhile.
      I still want a kickstart- that's a bit to do...we'll see.
      what brand of oil are you using?
      • speedlimit85
        • Jan 2017
        • 445
        • Gainesville, Fl.
        usually castroll
        just used Orielly's brand 10-40 conventional
        The oil flush cleaned it out much better than I expected. The oil looks clean in the window now- has not for several changes.
        I went 50 mi with the mystery oil added, left it overnight, 50 mi today. Then changed it hot and the filter.
        80 G
          • 1967
          usually castroll
          You might want to consider swapping to a good quality motorcycle oil. Car oils are known to cause excessive sludge in motorcycles.
          • JonnyO
            • Oct 2020
            • 229
            • Sun City West, AZ
            Yes! I filled mine with an excellent CAR engine oil thinking there was no difference. Big mistake. Soon after the starter clutch would spin and not engage properly. I thought I'd have to replace the starter but some some wise members
            said to switch to yamaha 10-40 first. That was 3 years ago. It cleared up the problem right away and I only use yamalube now since IT WORKS.
            YMMV
            -Jonny
            • speedlimit85
              • Jan 2017
              • 445
              • Gainesville, Fl.
              Maybe I should try yamalube.
              80 G
                • 2074
                Last time I used Kawasaki motorcycle oil that I had bought in bulk on E Bay. Bel-ray is what I used to buy but was always told don't put synthetic oil in a wet clutch older bike.
                  • 1980
                  Yes, it was the gears that I was focusing on. The swing out kicker came from a late 70's Yamaha. Maybe 850?
                    • 801
                    Here's a video that gives you a no BS look into motor oil. I'll continue to use 15W40 Diesel oil despite what most people claim to know.
                      • 1980
                      I use 15W40 in mine.
                      • speedlimit85
                        • Jan 2017
                        • 445
                        • Gainesville, Fl.
                        A good mechanic here won't touch the oil seals but will put a kick-starter on. But... If I get parts wrong or missing, he'll put it back together charge me twice- won't leave a bike apart in limbo in his shop.
                        80 G
                          • 1980
ID:	879503 Click image for larger version
                            • 1980
                            A good mechanic will install a simple seal without hesitation. Not sure why he would not touch the seals. It's arguably the most important part of the modification. Don't buy another cover with a used seal or you will have yet another oil leak. The seal must be new and installed carefully so you don't nick it.
                            https://www.ebay.com/itm/18618020925...Bk9SR_z0gMfmYw
                              • 1980
                              Perhaps you meant the crankshaft seals. Since they are not stock, I can understand why he does not want to take responsibility. Could be a risk for re-work and lost profit.
                              • speedlimit85
                                • Jan 2017
                                • 445
                                • Gainesville, Fl.
                                Yes. He won't touch the crankshaft seals.
                                I appreciate the pictures and instruction. Click image for larger version
ID:	879509 Left side good. Click image for larger version
ID:	879510 Right side bad. Click image for larger version
ID:	879511 Front... not sure. Some leaks show only after longer rides.
                                80 G
