The day the tensioner died ( lucky way)
    • 8930
    And oil could run down under the right side cover from the front and make the seal leak seem worse
    I believe the answer to this is yes. I have oil under both L + R side covers and neither of my crankshaft seals leak. The wind will blow that oil all over the place making it very difficult to pinpoint leaks.
    Once these cylinder O-Rings go bad, oil will eventually seep past the base gasket, up the cylinder head studs and out...
    Click image for larger version  Name:	Jugs.png Views:	0 Size:	108.8 KB ID:	879500
    • speedlimit85
      • Jan 2017
      • 454
      • Gainesville, Fl.
      #47
ID:	879517 Looks like the tensioner bolt and gasket are good. Leaking from the inside right bolt and for awhile.
      80 G
        • 5073
        #48
        I installed a tensioner froma Venture/ Ventura? I got on E bay.
        Probably from a Venturer (note that the Venture was the 81H).
          • 5073
          #49
          Some tensioner housings are thinner than OEM which makes the bolt bottom out.
            • 2088
            I also wrote in a later post it was from a 1990 V-Max not from a Venturer. It doesnt leak at all.
            • speedlimit85
              • Jan 2017
              • 454
              • Gainesville, Fl.
              #51
              Yes. The bolts are different. I did install correct bolts for the tensioner.
              The cylinder bolt is what I meant to say is where oil is leaking.
              80 G
              • Matthieu
                • Sep 2025
                • 1
                • Netherlands
                #52
                I have an oil leak at the chain tensioner. Can it be anything else than the gasket behind the tensioner. It's a 1978 XS1100
                  • 7830
                  Yes, there is a seal on the original XS1100. It plugs the hole on the outside. You can try and clean it really well and then seal it with high temp silicone.
                    • 2057
Name:	3 SEALS.jpg
                      • 2057
ID:	886124 Click image for larger version
Name:	special shape plug.jpg
ID:	886125 Click image for larger version
                        • 2160
                        Usually it is the plug on the end. Easy and inexpensive to replace the plug with a new one. I also use high temp silicone when I replace them.
