The day the tensioner died ( lucky way)
  • #46
    And oil could run down under the right side cover from the front and make the seal leak seem worse
    I believe the answer to this is yes. I have oil under both L + R side covers and neither of my crankshaft seals leak. The wind will blow that oil all over the place making it very difficult to pinpoint leaks.
    Once these cylinder O-Rings go bad, oil will eventually seep past the base gasket, up the cylinder head studs and out...
    Click image for larger version  Name:	Jugs.png Views:	0 Size:	108.8 KB ID:	879500
    • #47
ID:	879517 Looks like the tensioner bolt and gasket are good. Leaking from the inside right bolt and for awhile.
      80 G
      • #48
        Originally posted by oldyam80sg View Post
        I installed a tensioner froma Venture/ Ventura? I got on E bay.
        Probably from a Venturer (note that the Venture was the 81H).
        • #49
          Some tensioner housings are thinner than OEM which makes the bolt bottom out.
          • #50
            I also wrote in a later post it was from a 1990 V-Max not from a Venturer. It doesnt leak at all.
            • #51
              Yes. The bolts are different. I did install correct bolts for the tensioner.
              The cylinder bolt is what I meant to say is where oil is leaking.
              80 G
