78 Sidecar Project
    More work. All new rear wheel bearings including genuine Yamaha special bearing and new seals. Rebuilt rear caliper with new piston & seals. 3rd floating rotor. Black stainless 17" brake line. Spline service. New tire & tube.
ID:	879664 Click image for larger version
ID:	879665 Click image for larger version
ID:	879667 Click image for larger version
ID:	879666 Click image for larger version
ID:	879670 Click image for larger version
ID:	879671 Click image for larger version
ID:	879672 Click image for larger version
ID:	879673 Click image for larger version
        Mom on Mother's day!
          On The Road.
ID:	880089 Click image for larger version
ID:	880090 Click image for larger version
ID:	880091 Click image for larger version
ID:	880092 Click image for larger version
            On the road. Granville MA.
ID:	880260 Click image for larger version
ID:	880261 Click image for larger version
ID:	880262 Click image for larger version
              On the road. Just turned 10,000 miles on the rig. Living the dream.
ID:	880973 Click image for larger version
ID:	880974 Click image for larger version
ID:	880975 Click image for larger version
ID:	880976 Click image for larger version
                • 845
                #112
                The best part of owning any bike is using it as intended! Allegheny National Forest, Northwest Pa
                Click image for larger version  Name:	IMG_20240727_083940340.jpg Views:	0 Size:	169.0 KB ID:	881012
                  More from the road.
ID:	881422 Click image for larger version
ID:	881423 Click image for larger version
ID:	881424 Click image for larger version
ID:	881425 Click image for larger version
                    Living the dream.
ID:	881913 Click image for larger version
ID:	881914 Click image for larger version
ID:	881915 Click image for larger version
ID:	881916 Click image for larger version
ID:	881919 Click image for larger version
ID:	881920 Click image for larger version
ID:	881921 Click image for larger version
ID:	881922 Click image for larger version
                      • garyramir
                        • Oct 2024
                        • 4
                        • fort worth texas
                        #116
                        this is what im wanting to do to my 1979 yamaha xs1100 since a long time. where did you get your sidecar at and the mounting hardware? i have a welder too. any info would be appreciated. gary in Fort Worth Texas
                          Hi Gary, the M72 CJ750 sidecar is ex military and is well suited to the power of an XS11. I picked this unit up in front of Coney Island in Brooklyn New York several years ago. It needed a lot of work. The bike needed a lot of work. The fabrication work was very time consuming. Most of your questions can be answered by reading this post from the beginning. I tried my best to be detailed in the construction of this project. Hopefully it will be helpful to you and others long after I am gone.
ID:	881929 Click image for larger version
ID:	881930 Click image for larger version
ID:	881931 Click image for larger version
                            Pulled out the bike (after 3.5 month layup). Took out the drain plugs on the carbs and turned the manual petcock on and flushed fuel through the carb bowls into a stainless catch. Returned the plugs with new copper crush washers. Put air in the tires and off we went. Ran great. Pulls like a train.
ID:	883805 Click image for larger version
ID:	883806 Click image for larger version
                            • Ccitis
                              • Jun 2023
                              • 213
                              #119
                              Just found this thread. I have always said my XS would be a great candidate for a hack. Have never ridden one, nor do I have the build skills to make one. Seeing this makes me want to figure out a way to make it happen!
                                I would answer any questions for anyone that wants to do this modification. In this topic, I showed the mount modifications which would be the most complicated part of the project. The alignment process is also key in a strait tracking machine.
ID:	883813 Click image for larger version
ID:	883810 Click image for larger version
ID:	883811 Click image for larger version
