oil on the good foot
    • 5067
    #286
    Good write-up.
      • 1922
      Thanks Skids, however, this was not the end of my leak problem. It started to leak slightly even with the repair. I looked into it further and found pitting on the crankshaft. This corrosion was caused by water in the crankcase sitting for years and eating away at the metal. I tried cleaning it up with #2000 emery cloth but could still catch the pits with a dental pick. You can change seals all you want but the end result is the same. Leaks. You can see the tiny threads at the end of the shaft that turn in as it rotates. Nice sharp edges to cut new seals. You must tape the shaft to protect a new seal or it will certainly fail.
ID:	879642 Click image for larger version
ID:	879643 Click image for larger version
        • 1922
        Purchased the SKF 99128 sleeve kit to repair the crankshaft surface. Welding the pits and re-machining are the only other alternative.
          • 1922
          I installed the sleeve and removed the lip. This leaves a nasty rough knife edge. You *MUST* tape the end to protect the seal. I used another Viton single lip seal. Let's hope 3rd times the charm.
ID:	879648 Click image for larger version
ID:	879649 Click image for larger version
ID:	879650 Click image for larger version
ID:	879651 Click image for larger version
            • 2108
            For the record, no goop under the sleeve in your instance?
              • 1922
              Mike, the directions that come with the sleeve suggest that you use a "Non Hardening" sealant under the sleeve. You are also asked to fill the pits in the metal with "powdered?" epoxy. I can tell you it was not easy to line up this sleeve and tap it on with a plastic mallet. Quite the interference fit. VERY tight. If you apply anything It would slip off and be pushed in towards the motor/sleeve bearing so I felt that in my case it was certainly not necessary.
              BTW, I took it for a hundred mile hike yesterday and it was finally dry.
                • 5067
                #292
                Wow! Good work.
                  • 1922
                  Update, this repair has lasted over a year with many thousands of miles. I highly recommend it.
                  • speedlimit85
                    • Jan 2017
                    • 437
                    • Gainesville, Fl.
                    #294
                    awesome, mine too
                    I've got over 10,000 miles leak free.
                    80 G
                      • 8849
                      Well, I had to redo the left crank seal on my 79 Special. It lasted about 3 years and 25K, it was a buna rubber from O-rings plus. I put the same type back in, should be good for a while. This motor has 150K+ miles on it, the crank looked good, no deep grooves.
                        • 1922
                        The Viton seal is still holding. I checked it a few weeks ago.
                          • 1922
                          April of 2026 still sealed!
                            • 1922
Name:	XS11 Crankshaft repair sleeve.jpg
