hi Frank,
I sent you a PM ( Private Message)
While you wait for your key you should clean and lightly lubricate the ignition lock. Soaking overnight in Evapo-Rust is a good way to clean after disassembly.
I used a towel on the bed to catch the small springs and parts that can jump out. save the Evapo-Rust as it can be used multiple times.
. If all seems to be good and just may need a carb rebuild and some serious tunin'......THEN find an internal non rusted tank
