1981H xs1100 rebuild project, started Feb.2017
  • Eveready1100
    • 539
    #61
    Frank, if you're planning on doing much work on the carbs etc, I"d advise you to invest in a set of J.I.S (Japanese Industry Standard) screwdrivers so you don't ruin any more screw heads on the bike. It'll save a LOT of heartache in the future.
    • DeanR
      • Jan 2005
      • 1499
      • Finger Lakes NY
      #62
      highly recommend this
      80 SG
      81 SH in parts
      99 ST1100
      91 ST1100
      • FranksBMW
        • Feb 2017
        • 121
        • north of Toronto, Canada
        #63
        Thank you for this suggestion, and I agree. The proper tool for the job is very important.
        The screw heads were already mangled by previous owner, so I'm replacing the 4 screws on top and 4 screws on the float bowls (per carb.)
        1981H XS1100
        1981 BMW R100
        My photo/moto site: frankfoto.jimdo.com
        • FranksBMW
          • Feb 2017
          • 121
          #64
          Yamaha 1981 SX1100
          $150 cost
          $50 winch to pull it up onto the trailer
          $20 cut key from internet
          $20 motor oil
          $20 gear oil and WD40
          $15 new screws for carbs
          1981H XS1100
          1981 BMW R100
            Hi Frank,
            Some have replaced the original JIS Screws with socket head cap screws using metric allen keys instead and eliminating the need for multiple tools in the kit.
              • 4015
              Hi Frank,
              Yup. Not a single fastener on my bike except the final and mid-drive plugs are original. All S/S SHCS on my bike.
                Frank, if you're putting off getting a good gas tank that doesn't have holes in it because it's too expensive then tools and new fasteners are going to knock your budget through the roof. You are going to screw up some screws whatever you do but the screwdriver in the emergency toolkit has a JIS tip, use it when you can.
                If the screws are stubborn, leave off the plastic handle and put the screwdriver in the screw, then rap on the shank to loosen the screw. Try not to mushroom the shank. If the screw wallows out you can usually smack the screw on the head with a hammer to peen the cross back down enough to let you 'set' the screwdriver tip into it with the hammer, then unscrew it.
                Anyway, take care of what you need to get your project running with a polypropylene hot water bottle for a temporary fuel supply if that's what you have to do but be careful. When you're working with gasoline, take it outside to play and have a fire extinguisher nearby. If something pops, Mr. Hydrocarbon is not your friend and you don't want to burn down your bike/garage/house while you try to figure out how to put out a fuel fire.
                • FranksBMW
                  • Feb 2017
                  • 121
                  #68
                  While I'm waiting for my key to arrive, what 2 colour wires do I jump on the wiring harness to ignition unit connecting block in order to activate the starter motor and energize the coils? Thanks!
                  1981H XS1100
                  1981 BMW R100
                    #69
                    Hey Frank,
                    Okay, on the Ignition switch, the large solid red wire is the power from the MAIN FUSE/Battery, and the large brown wire feeds the fuseblock and the other circuits. The Red/White/yellow striped is just to power the Emergency flashers, and the blue is just for the parking lights when the switch is turned to Park....which nobody ever does...on purpose!
                    Aside from the seat fitment with different tanks, there are other differences. The specials use gravity controlled petcocks and a separate vac. controlled valve/Octopus, and they don't fit/mount onto standard tanks, and vise versa...the holes are spaced differently. The Standards use vac. controlled petcocks. The Standards use a float/fuel level sender, the specials only use a Thermister idiot light switch. The Standards also have a vent tube that runs from the gas cap recess area THRU the tank to the bottom/end of the tank to drain away rain water/fuel that might get spilled into the recess. These tubes can also RUST thru causing fuel leaks. The Specials have a raised/elevated gas cap so don't have/use the drain tube. And the Specials are smaller less capacity tanks than the standards overall.
                    • FranksBMW
                      • Feb 2017
                      • 121
                      #70
                      Thank you, TC.
                      1981H XS1100
                      1981 BMW R100
                      • FranksBMW
                        • Feb 2017
                        • 121
                        #71
                        So, it's sort of alive. I placed a jumper wire in the connection block and hooked up a battery. The lights on the instrument cluster came on. The starter motor responded to the start button and turned the engine over. I put a spark plug in the lead, grounded it on the engine, and I see a spark while the starter cranks over the engine. Getting there.
                        1981H XS1100
                        1981 BMW R100
                        • FranksBMW
                          • Feb 2017
                          • 121
                          #72
                          Not having a gas tank at this preliminary stage, I used a syringe to inject gas into the 2 gas lines to the carbs to fill up the bowls, and I added a squirt of quick start fluid into the throats of each carb. The motor "caught" and almost started. There were definitely successful detonations in some cylinders.
                          I have to clean the carbs better now. There is probably another jet or needle that I haven't found. I'm not experienced with carb work. Is there an exploded view of parts in the carbs anywhere?
                          1981H XS1100
                          1981 BMW R100
                            • 8962
                            Here is a carb pictorial...
                            • FranksBMW
                              • Feb 2017
                              • 121
                              #74
                              Super, thank you!
                              1981H XS1100
                              1981 BMW R100
                              • Webster71
                                • Feb 2017
                                • 2
                                • Columbus, OH.
                                #75
                                Carbs
                                If you want the bike to run right you will at least have to do a thorough carb clean. Be very careful pulling the float pins so you don't break the pivot stands. I just had to repair two broken ones on a project bike I just got. You will for sure have to clean the pilot jet, and it's pretty easy to get to. Find a good fitting sharp screwdriver to remove it so you don't strip it. You may need to grind down the screwdriver tip to get it in there. Next, you absolutely need to get the main emulsion tube out. It is the tube the slide needle goes into. I'll be you'll be very surprised how dirty it is. After you remove the main jet and the slides you can push the emulsion tube toward the carb top to remove it. I had to use a punch and drive them out. If you do that be aware there is a small brass pin in the carb body to orient the emulsion tube so use a tool of smaller diameter than the hole the tube is in to drive it out.
                                For sure get the floats to move freely and I've also looked into the float pin and seat and seen it pretty dirty so I used a Dremel tool with a small brush tip and aluminum polish to shine it up inside. Then a good clean out of course.
                                I just got two project bikes and the carburetors were disasters once I got in there. Both are now running well. Wouldn't hurt to check your compression if you can too so you'll know if the valves are working well enough for now.
                                78 E
