1981H xs1100 rebuild project, started Feb.2017
    Great! I would put a little ATF or Marvel mystery oil into each plug hole for now. It will coat it with oil, loosen the rings, and take care of any rust.
    • FranksBMW
      • Feb 2017
      • 121
      • north of Toronto, Canada
      I put in some regular motor oil.
      1981H XS1100
      1981 BMW R100
      My photo/moto site: frankfoto.jimdo.com
      • FranksBMW
        • Feb 2017
        • 121
        Finally a picture
        1981H XS1100
        1981 BMW R100
            Edit: Well, that didn't work when I posted. Hmm .... Looks good though, Frank!
            • FranksBMW
              • Feb 2017
              • 121
              Naked!
              1981H XS1100
              1981 BMW R100
                Originally posted by FranksBMW
                Finally a picture
                hi Frank,
                The mystery continues. That looks like an 81H that has been painted maroon. Cues are: Front fairing. slotted rotors, saddle, Bags, rack, rear turn signals on a bar. short Special exhaust. rectangle foot rests.
                That is a longlist of 81 parts for it to be a 78E
                Check date of manufacture on the neck and confirm vin# is same on both.
                Somewhere on here is a list to identify all the serial numbers.
                Check TCI part number 4RO-
                Can you get it inside as this warm spell will not last.
                  Frank, do the YAMAHA logos on the tank have two screws holding them on?
                  81 H 6.2 gallon (US) tank does not have screws...all other years do.
                  Is it time to welcome another Venturer back into the fold ?
                    Hi Frank
                    Take a look at the pictures of Brian's 78E
                    • FranksBMW
                      • Feb 2017
                      • 121
                      A mystery - cool!
                      I do remember that the serial number on the steering head ended in 00043x. It was all I could see with the fairing on, and haven't looked since.
                      I'll check on things tomorrow. Leafs vs Jets is on.
                      1981H XS1100
                      1981 BMW R100
                        Naked!
                        ...and that IS an 81H(Venturer). BTW, no kick-start assembly NOR kick-starter with the 81H. You'll notice the kick-start hole on right side is plugged from factory.
                        • FranksBMW
                          • Feb 2017
                          • 121
                          Got to change back my signature?
                          1981H XS1100
                          1981 BMW R100
                            The black ring-groove on the engine's alternator cover says '81, you should probably change the 'sig after you check the serial numbers, it could be a Frankenbike.
                            U.S. Models:
                            1981 XS1100H 4R1-000101 Indigo Blue
                            1981 XS1100SH 4R0-000101 Black Blue, Cardinal Red
                            1981 XS1100LH 4W1-000001 New Yamaha Black
                              The problem with motor oil is that it will NOT free up rings, or take care of rust! ATF or MMO are your best friends at this point, IMHO. BTW, it DOES look like an '81. Check the engine number, and then see if the frame matches it when you can.
                              • FranksBMW
                                • Feb 2017
                                • 121
                                Good to know, thanks. Tomorrow.
                                1981H XS1100
                                1981 BMW R100
