1981H xs1100 rebuild project, started Feb.2017
    hi Frank,
    I sent you a PM ( Private Message)
    While you wait for your key you should clean and lightly lubricate the ignition lock. Soaking overnight in Evapo-Rust is a good way to clean after disassembly.
    I used a towel on the bed to catch the small springs and parts that can jump out. save the Evapo-Rust as it can be used multiple times.
    • FranksBMW
      • Feb 2017
      • 121
      • north of Toronto, Canada
      #47
      Carbs and air box out. 3 of the slides are stuck/sticky. Time for a cleaning of the old gas varnish.
      1981H XS1100
      1981 BMW R100
      My photo/moto site: frankfoto.jimdo.com
      • FranksBMW
        • Feb 2017
        • 121
        #48
        Here's a question I'll need to know the answer to in the future: Do all gas tanks fit all years and models of the XS1100?
        Or, what are the restrictions?
        1981H XS1100
        1981 BMW R100
          Hi Frank,
          All Gas tanks fit the frame however some saddle conflict/ require modification or leave a gap. Believe me you want to preserve the Venturer tank if you possibly can.
          • FranksBMW
            • Feb 2017
            • 121
            #50
            There are 2 or 3 rusted through holes. The biggest one is about 3 by 1 inch.
            1981H XS1100
            1981 BMW R100
              hi Frank,
              That sound pretty bad. What does the interior surface look like ?
              Would be fairly simple to weld in patches for someone skilled at welding light gauge steel. Know anyone with the skill and a welder?
              Am i correct in guessing the holes are on the bottom outer edges?
              • FranksBMW
                • Feb 2017
                • 121
                #52
                The lower parts - yes. That's where the water would settle. I do know someone who might be able to weld it. But the tank is a later task (in my head.)
                1981H XS1100
                1981 BMW R100
                  Fire
                  Just get another tank, Frank, you really don't need to mess around with a rusty one with visible holes.
                  • FranksBMW
                    • Feb 2017
                    • 121
                    #54
                    Do tanks from other years fit?
                    1981H XS1100
                    1981 BMW R100
                      Yes.
                      The '81 Venturer has a larger ~6 gallon US tank with higher handlebars so they don't hit the tank but you can fit others like an XJR1200:-
                      gas tank sizes
                      Apparently, the European tanks are larger than the Standard ~5 gallon US tanks too so it might be worth checking around Canada and across the pond too:-
                      Fuel tank conversion
                      Have fun, life's too short to screw around with rusty tanks.
                        Oh! Canada!
                        Here's a UK tank listing that doesn't really want US biz but may deal with the Canada:-
                        http://www.ebay.co.uk/itm/yamaha-xs1...gAAOSwLEtYjz4t
                        £50.00 | 0 bids
                        yamaha xs1100 petrol tank
                        Bedford, UK
                        May not post to United States - Read item description or contact seller for postage options. | See details
                        Item location:
                        Bedford, United Kingdom
                        Posts to:
                        United Kingdom
                        • FranksBMW
                          • Feb 2017
                          • 121
                          #57
                          So today, I went through the carbs. There were a few stubborn screws and I had to grind off 2 of their heads because the impact wrench still mangled the cross slots and the vicegrips slipped off their heads.
                          3 slides were stuck and I cleaned off the varnish with some break cleaner. (keeping that liquid away from rubber diaphragms) On the bottom end, I cleaned out the bowls and the orifices where gas gets sucked up along the needle. The floats of one of the carbs were frozen and I was able to pull the pin and clean off the sticky varnish.
                          There may be more work to be done to them but this was my first time and I did the obvious.
                          1981H XS1100
                          1981 BMW R100
                          • FranksBMW
                            • Feb 2017
                            • 121
                            #58
                            Ideally, I want to get the bike running with just my labour before investing in expensive parts.
                            1981H XS1100
                            1981 BMW R100
                              Good luck with your project then, Frank.
                                Good idea. Initially then, I'd suggest use a portable plastic tank of some sort hung from a three legged or roll-around stand. If all seems to be good and just may need a carb rebuild and some serious tunin'......THEN find an internal non rusted tank.
