1981H xs1100 rebuild project, started Feb.2017
    #76
    Not explode, just sliced!
    Hey Frank,
    Mack donated a few carb bodies a couple of years ago, and I took a metal cutting band saw to them to get these views. Here are just a couple of the 80-81 series carbs sliced both across and length wise. You can click on the photos to get a larger/closer view.
    Here's the thread I posted showing the 78-79 model as well as showing the jets in place, and strings and such to try to show the fuel air flow passages.
    • MarkD
      • Jun 2013
      • 488
      • N. Michigan
      #77
      Seems my best contribution to the carb fun is a copy of an earlier post :
      Hi-- Besides these great guys on this site, I found this video to alleviate some fears, and give me some courage to tackle the xs carb rack. My bike runs super strong and smooth. You must use genuine Mikuni pilot jets!
      Check this vid out :
      motorcyclememoir is the guy, and he has other vids, too. He seems to
      be very knowledgeable.
      Mark
      79 F
      1967 Suzuki X6 Hustler
      1973 Suzuki TM 125
      1979 XS1100 F
      2005 Kaw. Vulcan VN800
      1991 BMW K75
      • FranksBMW
        • Feb 2017
        • 121
        • north of Toronto, Canada
        #78
        I am so grateful for this site! Thanks guys and gals.
        1981H XS1100
        1981 BMW R100
        My photo/moto site: frankfoto.jimdo.com
          #79
          Hey Frank,
          That was REALLY an amazing job. You could have been a surgeon.
          • FranksBMW
            • Feb 2017
            • 121
            #80
            Weather turned seasonally cold again, temporarily curbing work in my unheated garage.
            1981H XS1100
            1981 BMW R100
              Hi Frank,
              It's that vicious wind that makes it so miserable outside at this time.
              Hang in there it will soon get better. Throw another log on the fire
              • FranksBMW
                • Feb 2017
                • 121
                #82
                Hi Pil. Just noticed your location. You're getting the same-ish weather as me.
                1981H XS1100
                1981 BMW R100
                  Hi Frank,
                  looks like it will stay cold fora little longer so thow more logs on the fire and read what Gary has to say about waking an XS from a long rest.
                  • FranksBMW
                    • Feb 2017
                    • 121
                    #84
                    Thanks Phil. Will do!
                    It will get warmer.
                    1981H XS1100
                    1981 BMW R100
                    • FranksBMW
                      • Feb 2017
                      • 121
                      #85
                      I took advantage of a warmer afternoon and spent 3 1/2 hours in the garage, focusing on the brakes, which I removed early on because the callipers were all seized and I needed the bike to roll.
                      I took apart, cleaned, and reassembled the 3 callipers. I reinstalled and bled the front callipers . It was slow going because there was a lot of air in the system so I used a vacuum technique with a large syringe to suck brake fluid out of the bleeders on the callipers. I think I may have cross threaded one of the bleeders though.
                      I also took apart, cleaned, and put back together the rear master cylinder. Installation of the rear brake system on the bike will require rear wheel removal so I'll leave that for next time as my back was getting sore.
                      Anyway, great day in March wrenching, and making progress on this project!
                      Forgot to mention that a few days ago I attended to the clutch cable and adjustment. The cable required wd40 and oil to free it up.
                      1981H XS1100
                      1981 BMW R100
                      • mschor
                        • Jan 2017
                        • 183
                        • West Palm Beach, FL.
                        #86
                        Caliper Rebuild
                        If your calipers are seized, use a grease gun to push the pistons out. I fought my first two for a day, and tried the grease gun trick on the last one. WORLDS of difference. Youtube it or check on this forum.
                        81 Special
                        • mschor
                          • Jan 2017
                          • 183
                          #87
                          I'm in the middle of getting an 81 Special up and running after 20yrs in a garage. Quite a process unlocking all the stuck parts, was losing confidence for a while, but I'm almost there now
                          81 Special
                          • FranksBMW
                            • Feb 2017
                            • 121
                            #88
                            Good luck with your project, Mschor!
                            Thanks for the grease gun trick. I knew about it but had forgotten. Luckily I didn't need it.
                            1981H XS1100
                            1981 BMW R100
                            • SS Clift
                              • Apr 2015
                              • 9
                              • Ontario, Canada
                              #89
                              XS1100 Rebuild
                              Hello Frank from Whitby, Ontario. It`s nice to know that there is XS1100 enthusiast close by. I bought a running `79 XS1100E Standard last summer for some parts . The frame is cracked at the left side foot peg. If there is anything that you need for your bike , that I may possibly have , perhaps I can help you out with your restoration .
                              Steve theclifts@rogers.com
                              78 E
                              • FranksBMW
                                • Feb 2017
                                • 121
                                #90
                                Thanks Steve! Have you got a headlight bucket, front turn signals, gas tank, and seat in good condition?
                                1981H XS1100
                                1981 BMW R100
