1981H xs1100 rebuild project, started Feb.2017
    Originally posted by FranksBMW
    Got to change back my signature?
    Peace of mind for yourself, if serial no. starts with 4R1, tis' an 81 Venturer. Serial no. is located on right-side on steering neck. Also, if motor original, serial no. is on right side, top of engine case above clutch cover, stamped into a rectangle recess. If engine is original, that serial no. matches frame serial no..
    • red bandit
      • 970
      • central michigan
      Yes, an 81. Didn't the 81 have swirly wheels?
      79 SF parts bike.
      • mcmotohistory
        • Aug 2015
        • 44
        • Crescent City, CA.
        No swirly wheels on the 81. Here's mine.
        [IMG][/IMG]
        81H Venturer
          • 4015
          This is EXACTLY how I'd like a Standard to look! Except, I really like the Venturer blue.
          • FranksBMW
            • Feb 2017
            • 121
            • north of Toronto, Canada
            #35
            4T100043x
            matching numbers on frame and motor
            1981H XS1100
            1981 BMW R100
            My photo/moto site: frankfoto.jimdo.com
            • FranksBMW
              • Feb 2017
              • 121
              #36
              So it's a 1981 xs1100 H, Canadian, originally indigo blue
              Does that make it a Venturer?
              1981H XS1100
              1981 BMW R100
                A'yup, it sure does.
                The '81 Venturer had a larger fuel tank so if it's not been replaced or rusted out you'll want to hang on to it and take good care of it. I've heard that the front forks got stiffer springs from the factory for the fairing too but I've never seen and compared them myself so keep that in mind if you remove the fairing.
                From 1978 to 1981 there are not a whole lot of importance differences between any of the Standards except minor trim variations, tubeless tires and rims along with air forks. For 1981 the 4R0 TCI has the ignition advance curves built in so Yamaha got rid of the mechanical advance that lives under the left-hand engine cover but they kept the vacuum advance.
                The 4R0 TCI is getting rare and can be expensive, if you want a spare you should start shopping now.
                • FranksBMW
                  • Feb 2017
                  • 121
                  #38
                  Thank you very much Scott! Downloading now.
                  Good day in the garage. Drained and refilled engine and drive oils.
                  The bike came without a key. Is the code on the underside of the ignition switch enough to order a new key? Where can one order a new key?
                  Any trick to removing the carbs? I've loosened the airbox so it can move back a bit, then just unclamp the boots?
                  1981H XS1100
                  1981 BMW R100
                    Yes, that's the key code. Go to a Yamaha dealer to get a key or try a locksmith.
                    Loosen the manifold clamps and move them off 'lip' so they drop next to the cylinder head.
                    Straddle the bike, pull the carburetors out of the manifolds, then the carburetors come out to the left.
                    You'll have to finagle the throttle cable lever and the clutch cable guide on the #4 carburetor hat as you do it so you don't gouge the manifolds or bend the lever. If it's cold, try heating the rubber manifolds with a hair dryer or a heat gun.
                    To put the carburetors back in, here's a short video I made with a former forum member. Yes, it really does take five minutes or less to reinstall the carburetors. RIP Planedick.
                    XS1100 Carburetor Install
                    Take your time, there's always time to do it over again. And again. And again, right?
                      4T100043x
                      Oppps, sorry FranksBMW. Forgot about the different prefix of the Canadian version. But hey, you folks also got the XJ's two extra yrs....only one yr. here in the States.
                        Hi Ian,
                        +1 on the blue. When the lottery come in repaint back to original is on my list. come on LOTTO I have stuff to do
                          Hi Frank,
                          Keys here: http://www.keys4urride.com/advanced_...cat=0&sort=20a
                          Takes a week or more but I doubt you will find cheaper or genuine Yamaha blank. Check with them but I think YH48P is the blank you need.
                          I would suggest you get three unless your code is the same as mine.
                          Then get 5
                          Click on the picture of blank and it takes you to the next page. Cutting is an extra $6.50 but do have them cross check the code is correct for that blank.
                          the fine print says they can not do ALL codes.
                          • FranksBMW
                            • Feb 2017
                            • 121
                            #43
                            Thank you Phil, done!
                            This saves both time and $ over the option of visiting a locksmith in a nearby town.
                            1981H XS1100
                            1981 BMW R100
                            • FranksBMW
                              • Feb 2017
                              • 121
                              #44
                              If my small town had a locksmith, they'd get my business, but the known good blacksmith is in another town, 45 minutes drive.
                              1981H XS1100
                              1981 BMW R100
                                Hi Frank,
                                Then get 5
                                If wanting to have paint original color, AND to keep it simple, it is actually carbon blue-black-effect, 2000 Toyota, fast dry acrylic enamel(single stage,M46031E. That IS a perfect match, as several yrs. back I sanded and re-painted the sidecovers of my Venturer. This was mixed in their quality arosal can with the quality adjustable fan pattern nozzle.Layed like glass and defy anyone to know whether re-painted or not. I didn't, but suggest a quality clear-coat over the paint if fuel drops hit the tank. Otherwise, paint dulls, but can polish out perfectly with Meguiar's mirror glaze fine-cut cleaner #2. BTW, all products used including Meguiar's were from an automotive paint store.
