Great! I would put a little ATF or Marvel mystery oil into each plug hole for now. It will coat it with oil, loosen the rings, and take care of any rust.
1981H xs1100 rebuild project, started Feb.2017
♬Comment
Edit: Well, that didn't work when I posted. Hmm .... Looks good though, Frank!-- Scott
♬Comment
hi Frank,
The mystery continues. That looks like an 81H that has been painted maroon. Cues are: Front fairing. slotted rotors, saddle, Bags, rack, rear turn signals on a bar. short Special exhaust. rectangle foot rests.
That is a longlist of 81 parts for it to be a 78E
Check date of manufacture on the neck and confirm vin# is same on both.
Somewhere on here is a list to identify all the serial numbers.
Check TCI part number 4RO-
Can you get it inside as this warm spell will not last.
PhilLast edited by MaximPhil; 02-21-2017, 07:03 PM.1981 XS1100 H Venturer ( Addie)
2004 Kawasaki Concours. ( Black Bear)Comment
Frank, do the YAMAHA logos on the tank have two screws holding them on?
81 H 6.2 gallon (US) tank does not have screws...all other years do.
Is it time to welcome another Venturer back into the fold ?
Phil1981 XS1100 H Venturer ( Addie)
Hi Frank
Take a look at the pictures of Brian's 78E
A mystery - cool!
I do remember that the serial number on the steering head ended in 00043x. It was all I could see with the fairing on, and haven't looked since.
I'll check on things tomorrow. Leafs vs Jets is on.
1981 BMW R100
My photo/moto site: frankfoto.jimdo.comComment
Last edited by motoman; 02-21-2017, 07:44 PM.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
The black ring-groove on the engine's alternator cover says '81, you should probably change the 'sig after you check the serial numbers, it could be a Frankenbike.
U.S. Models:
1981 XS1100H 4R1-000101 Indigo Blue
1981 XS1100SH 4R0-000101 Black Blue, Cardinal Red
1981 XS1100LH 4W1-000001 New Yamaha Black-- Scott
♬Comment
The problem with motor oil is that it will NOT free up rings, or take care of rust! ATF or MMO are your best friends at this point, IMHO. BTW, it DOES look like an '81. Check the engine number, and then see if the frame matches it when you can.I put in some regular motor oil.Ray Matteis
Good to know, thanks. Tomorrow.1981H XS1100
1981 BMW R100
. BTW, no kick-start assembly NOR kick-starter with the 81H. You'll notice the kick-start hole on right side is plugged from factory.
