Street fighter/ Bobber build 2.0
  • Fearthepack
    • May 2012
    • 255
    • Orlando, Fla.
    #166
    Sail4free, look at post #139 should provide your answer....
    1979 F worst one i could find
    to convert into a bobber/ streetfighter!
    _________________________________
    We can't all get along!
    • Fearthepack
      • May 2012
      • 255
      • Orlando, Fla.
      #167
      Sail4free, I used the stock air box boots and modified them to eliminate emgos inherent issues thanks to others before me for this great mod
        • 7835
        Originally posted by Fearthepack
        The large square part is that just an extra not used on these petcocks? That is what is confusing me......
        The kit has all the parts to rebuild both manual tank mounted fuel valves and the vacuum operated fuel shutoff, mounted on the left carburetor (octy).
        • Fearthepack
          • May 2012
          • 255
          • Orlando, Fla.
          #169
          Confusion cleared thank you.....
          • tcoop
            • Nov 2009
            • 793
            • South Weber, UT
            #170
            That is for the octy. If you are not using the octy then it is not needed.
            I am slow to reply....
            Ty
            78 XS1100E - Now in Minnesota
            80 XS1100LG - The Punisher
            82 XJ1100 - Daughter's Bike
              ....just takes a while for it to 'jump the hill' Ty.
              • sail4free
                • May 2014
                • 138
                • Boise, Idaho
                #172
                Kewl -- had to put me glasses on -- three of the 32-150, one 32-4033 and one 32-1085 (all from K&L).
                Thanks!
                JIM P.
                79 SF
                • Fearthepack
                  • May 2012
                  • 255
                  • Orlando, Fla.
                  #173
                  Holly bat **** Robin we are going to have to do major surgery....
                  • TomB
                    • 967
                    • Cumbria, UK
                    #174
                    Maybe not too bad, the rusty part should lift off, then the rubber bellows next, under that is the inside of the reservoir
                    Tom
                    • Fearthepack
                      • May 2012
                      • 255
                      • Orlando, Fla.
                      #175
                      Booooooo just as orange inside
                      • Fearthepack
                        • May 2012
                        • 255
                        • Orlando, Fla.
                        #176
                        Got the pods modified with the stock air box boots.... Looks even better...Thanks to the original poster of this mod.....
                        • Fearthepack
                          • May 2012
                          • 255
                          • Orlando, Fla.
                          #177
                          Still looking for an answer to where the washer (bottom left corner goes) couldn't find it in tear down of rear master brake.....
                          Anyone????
                          • Fearthepack
                            • May 2012
                            • 255
                            • Orlando, Fla.
                            #178
                            Mack offered this answer...
                            On the plunger close to the pointy end you'll see a flange with holes in it. The little washer goes against that and the thinner of the rubber gaskets goes against the washer. Make sure the middle gasket is installed first, it's the thicker of the two and ensure the larger diameter is facing the pointy tip. The little metal nipple goes over the end, then you put the narrow end of the spring on the metal nipple. Coat the M/C bore and rubber gaskets with brake fluid before assembly into the bore to lubricate. Insert then install horseshoe clip then c-clip then rubber boot.
                            • Fearthepack
                              • May 2012
                              • 255
                              • Orlando, Fla.
                              #179
                              Member Mach made this video about rear MC replacement parts orientation and install should be in tech tips....
                              • Fearthepack
                                • May 2012
                                • 255
                                • Orlando, Fla.
                                #180
                                My front calipers will not reverse bleed..... bleeder screw 3/4 open and MC plunger depressed but no movement of brake fluid.... 1st time using this method.....Is this indicating failure else where in the system?
