Street fighter/ Bobber build 2.0
    I SHOULD have one of each, but I'll have to wait until this afternoon when I get home from work. PM me if still in need at 3:00pm Pacific time.
    • Fearthepack
      • May 2012
      • 255
      • Orlando, Fla.
      #137
      Will do sir...
      1979 F worst one i could find
      to convert into a bobber/ streetfighter!
      _________________________________
      We can't all get along!
      • Fearthepack
        • May 2012
        • 255
        • Orlando, Fla.
        #138
        Carbs done getting ready to move onto the brakes...
        Don't remember the emgo's giving me previous problems but re-looking at this lip wondering if it can hinder any orifices....
        • Fearthepack
          • May 2012
          • 255
          • Orlando, Fla.
          #139
          parts are in...
          • Fearthepack
            • May 2012
            • 255
            • Orlando, Fla.
            #140
            Practiced getting the bleeder screw out of this caliper a lot of torch and vice grips it gave up the ghost and cam loose. No I did not deform it in the process...came that way
            Is this off a special because no inspection window?
            • Fix
              • May 2009
              • 384
              • Lake Orion, MI
              #141
              Those Emgo's absolutely will cause havoc with your carbs. The lip messes with a port in the throat.
              If you must use them, make a small adapter from spare airbox boots.
              It's what I did until I tracked down a decent airbox to replace my broken one.
              Mike C
              Lake Orion, Michigan
              '78 XS1100E
              Here I am! Where are you?
                • 3193
                #142
                Looks to be a caliper off of an 81 MNS. The window would be at the rear if so. Will not fit unelss using a MNS rear setup.
                • Fearthepack
                  • May 2012
                  • 255
                  • Orlando, Fla.
                  #143
                  Happy Birthday Merry Christmas to me this little whore came out with no damage to the threads.......
                  The left side I had to grab with a set of vice grips that I had to close it with a huge pair of channel lock pliers then tap with a hammer and it came loose as well...Me so happy!!!!!!
                  • Fearthepack
                    • May 2012
                    • 255
                    • Orlando, Fla.
                    #144
                    Question if the emgo filter pods cause problems and need to be modified I should be able to search and find the procedure but i'm not finding anything... Any answers
                      Answer is use the rubber velocity stacks from the stock air box. If you don't have a stock air box, I think there is a hose about the correct size available from you auto parts store. Measure the outside diameter of the carbs, in inches, and look for a fuel hose with that inside diameter. It will be a hose used for the fill neck on fuel tanks for cars or boats.
                      • Fearthepack
                        • May 2012
                        • 255
                        • Orlando, Fla.
                        #146
                        i have stock stacks so my vision goes like this...
                        End of carb...stock boot...something here to clamp onto both stock boot and emgo pod....then emgo pod. What am I missing?
                        • Fearthepack
                          • May 2012
                          • 255
                          • Orlando, Fla.
                          #147
                          My clean carbs just puked in their mouths.....
                          This inner lip was just as bad.. now looks great... is there hope?...yes maybe
                            #148
                            Here's one of a few threads/tips about the Pod Filter mounting mods:
                            • Fearthepack
                              • May 2012
                              • 255
                              • Orlando, Fla.
                              #149
                              Search King! Thank you clears it up nicely...
                              • Fearthepack
                                • May 2012
                                • 255
                                • Orlando, Fla.
                                #150
                                Rebuilt front master brake and calipers over the weekend getting ready to bleed them...
                                FYI if you soak this rubber seal in brake fluid for fifteen minutes it literally turns into a rubber band and just slides right on....seems many have a difficult time with this part....
