i have stock stacks so my vision goes like this...
End of carb...stock boot...something here to clamp onto both stock boot and emgo pod....then emgo pod. What am I missing?
Street fighter/ Bobber build 2.0
Answer is use the rubber velocity stacks from the stock air box. If you don't have a stock air box, I think there is a hose about the correct size available from you auto parts store. Measure the outside diameter of the carbs, in inches, and look for a fuel hose with that inside diameter. It will be a hose used for the fill neck on fuel tanks for cars or boats.Leave a comment:
Question if the emgo filter pods cause problems and need to be modified I should be able to search and find the procedure but i'm not finding anything... Any answersLeave a comment:
Leave a comment:
Looks to be a caliper off of an 81 MNS. The window would be at the rear if so. Will not fit unelss using a MNS rear setup.Leave a comment:
Those Emgo's absolutely will cause havoc with your carbs. The lip messes with a port in the throat.
If you must use them, make a small adapter from spare airbox boots.
It's what I did until I tracked down a decent airbox to replace my broken one.Leave a comment:
I SHOULD have one of each, but I'll have to wait until this afternoon when I get home from work. PM me if still in need at 3:00pm Pacific time.Leave a comment:
In need of one 265, and one 270 valve shim if anyone has them... willing to buy,trade, beg or steal them.Leave a comment:
Those are cool.... I tried a mock-up moving the pegs to the rear and it put me in a very uncomfortable riding position with a lot of pressure on the wrists... I suspect the low seat is causing this.... I have a Suzuki 1975 T500 with clubmans that I have no problem riding.Leave a comment:
Leave a comment:
