Jet Kit for 79 xs1100F
    • 3918
    Honestly, between the lack of the airbox, pods, or whatever, versus your drilled slides, your airbox dillema should be the least of your worries. Do what you gotta do to get as-close to stock as possible.
    • TheRev
      • Jun 2012
      • 235
      • Madison, Wi.
      #47
      OK, so I have a air box that I purchased a few years ago. I think what I am going to do is purchase new slides and try to go back to stock. I have a feeling I will be chaising the tuning issue for a long time if I stick with the PODS. So here is my question. What jets should I start with if I have a air box and Mac 2 to 1 exhaust? Thanks
      1979 xs1100f
      New Fuse Box
      Progressive Shocks
      Gold Valve Emulator
      Dyna Coils
      Electronic Flasher
      Led Headlight
      Led Turn Signals
      4 Led Driving Lights
      2nd Gear Fix
      Auto Cam Tensioner
      Digital Dash
      Stainless Braided Lines
      R6 4 Piston Calipers
      Stainless Bolt Kit
      Maier Fairing
      Dyna Balancing Beads
      Spin On Oil Filter
      Stebel Nautilus Horn
      Plasti Dip Rims
      ISO Grips
        • 3918
        Hey Rev- Gimme a sec, and I'll answer you.
          • 3918
          I know we have the same bike, but do u have the '79 carbs? Stock, you should have 137.5 Mains, and 40 Pilot jets(?). Start there. Plug chop come Spring.
          • Orange4
            • Sep 2013
            • 398
            • Maple Ridge, B.C., Canada
            #50
            The easiest is going back to stock. The stacks in the stock airbox are almost 4" long. With those on there's not much room for a pod filter between the end of the stack and the frame. You could get fancy and build your own filters. Uni Filter sells it's filter material in sheets but then you are practically building an air box.
            BTW, what do you do with your crankcase breather when you run pods?
            Living to EXcess.
            1979 XS1100F Canadian, stock exhaust. Top end rebuild in progress.
              • 7766
              Rev,
              No. I didn't get to the carbs yet. I spent part of Sunday on the BMW, as it was 80F in the afternoon.... I'll get to the carbs in storage after work today, and let you know.
                • 7766
                Sent you a PM. I have the slides! Let me know what else, if anything, you need.
                  • 3918
                  Nice!! Let's help getting that beautiful bike running as sweet as she looks!
                  • TheRev
                    • Jun 2012
                    • 235
                    • Madison, Wi.
                    #54
                    I would love to live in a place that I could ride all year long. It's -13 today in Wisconsin. My goal is to get these carbs to work well before May. Any suggestions on where I should start as far as the jets. I have a 2 in 1 mac exhaust.
                    Rev,
                    1979 xs1100f
                    New Fuse Box
                    Progressive Shocks
                    Gold Valve Emulator
                    Dyna Coils
                    Electronic Flasher
                    Led Headlight
                    Led Turn Signals
                    2nd Gear Fix
                    Auto Cam Tensioner
                    Digital Dash
                    Stainless Bolt Kit
                    Maier Fairing
                    Spin On Oil Filter
                    Plasti Dip Rims
                    ISO Grips
                      • 7947
                      Start with stock.
                        • 7766
                        As SpecialEd runs a MAC, I would say go 1 up on the mains, and start from there. If you need to turn the screws out more than 2 1/2 times, go 1 size larger on the mains. IIRC, Ed has 1 up, and about 2 1/4 turns on his carbs. This is with a stock air box, K&N filter installed.
                        • TheRev
                          • Jun 2012
                          • 235
                          • Madison, Wi.
                          #57
                          So I assembled my airbox and will soon be in the process of going back to stock. So for those of you with the air box, what are you using for a filter? Is the K&N filter so much better than the uni or foam filters? I don't want to spend three times as much on a filter if I don't need to.
                          1979 xs1100f
                          New Fuse Box
                          Progressive Shocks
                          Gold Valve Emulator
                          Dyna Coils
                          Electronic Flasher
                          Led Headlight
                          Led Turn Signals
                          2nd Gear Fix
                          Auto Cam Tensioner
                          Digital Dash
                          Stainless Bolt Kit
                          Maier Fairing
                          Spin On Oil Filter
                          Plasti Dip Rims
                          ISO Grips
                          • phatts27
                            • Aug 2012
                            • 189
                            • Clementon, New Jersey
                            #58
                            Hey rev, I read a lot of good things about the k&n drop in. I'm on the same boat as you, reverting back to stock. I believe uni offers a filter for around $15, an oem will run you about $40 and a k&n will set you back about $55. I went with the k&n because I know I'll never have to buy another and it only cost a little more than oem. Plus, I'm a sucker for a good sales pitch: more hp, more tq, more mpg (we'll see)...
                            81 xs1100 SH
                            81 xs1100 SH (parts)
                            80 suzuki gs550et
                            07 suzuki S40
                              • 3918
                              Buyyyyyy ittttttttttt!!!!
                              • Prisoner6
                                • Aug 2013
                                • 1184
                                • Phoenix, AZ
                                #60
                                +1 ...
                                Buy the K&N filter ... it's a quality product and you will be pleased with it.
                                And as Ed (phatts27) alluded to, you can use it indefinitely ...
                                Marco
                                1979 Honda CBX
                                2002 Kawasaki ZRX1200R
                                WE MISS YOU, DON
