Jet Kit for 79 xs1100F
  • TheRev
    • Jun 2012
    • 235
    • Madison, Wi.
    WOW! These slides are expensive. Perhaps it is cheaper to purchase an entire new set of carbs. Anyone have any slides they would like to sell?
    1979 xs1100f
    New Fuse Box
    Progressive Shocks
    Gold Valve Emulator
    Dyna Coils
    Electronic Flasher
    Led Headlight
    Led Turn Signals
    4 Led Driving Lights
    2nd Gear Fix
    Auto Cam Tensioner
    Digital Dash
    Stainless Braided Lines
    R6 4 Piston Calipers
    Stainless Bolt Kit
    Maier Fairing
    Dyna Balancing Beads
    Spin On Oil Filter
    Stebel Nautilus Horn
    Plasti Dip Rims
    ISO Grips
      • 2104
      Jat...
      ... would it be possible to epoxy or solder the "modded" drilled holes in your original slides ?
        Let me look at what I have, Rev. I MAY have a set of slides, but I need to pull and check them, as the carbs went through an engine fire.
        As for color tune, a set of gauges to set the carbs will make it run as well as anything else, and ARE the proper way of setting up a multi-carb engine. You should be able to get a 4 gauge set on ebay for about $100. That and a box fan are all you need.
          You'll probably have more luck buying another complete carb set rather than trying to track down four good slides. Now personally, I'd go with another '78-79 carb set as that will allow you to rob parts if needed, and I think the early carbs are a bit better in terms of performance and tunablity (but not fuel economy). But either type will work, you just need to jet accordingly. Make sure your timing/timing advance is right, and it wouldn't hurt to check to make sure the cam timing is right too.
            Not really, as maintaining correct slide weight is critical too. Those Dynojet kits sold a lot of Harley slides, if there was a way to fix them the Harley boys would have found a way....
              • 4015
              Rev- If you need to borrow my Carbtune, I could loan it to you. No need to buy a gauge set.
              • TheRev
                • Jun 2012
                • 235
                • Madison, Wi.
                DiverRay
                That would be great. I would appreciate it greatly.
                1979 xs1100f
                New Fuse Box
                Progressive Shocks
                Gold Valve Emulator
                Dyna Coils
                Electronic Flasher
                Led Headlight
                Led Turn Signals
                2nd Gear Fix
                Auto Cam Tensioner
                Digital Dash
                Stainless Bolt Kit
                Maier Fairing
                Spin On Oil Filter
                Plasti Dip Rims
                ISO Grips
                • TheRev
                  • Jun 2012
                  • 235
                  • Madison, Wi.
                  If I do find new slides what size jets do you all recomend for pods. I read the jetting guide posted by Denny Zander and he suggests moving up three jets on the main to 145 and one for the pilot to 45. Does that sound like a good starting point?
                  1979 xs1100f
                  New Fuse Box
                  Progressive Shocks
                  Gold Valve Emulator
                  Dyna Coils
                  Electronic Flasher
                  Led Headlight
                  Led Turn Signals
                  2nd Gear Fix
                  Auto Cam Tensioner
                  Digital Dash
                  Stainless Bolt Kit
                  Maier Fairing
                  Spin On Oil Filter
                  Plasti Dip Rims
                  ISO Grips
                    Be conservative... I'd start at no more than one size up on the mains and leave the pilot alone if using the early carbs. That jetting guide is a bit out of date these days IMO, given the different fuel available now. Try stock jetting to start with, that will at least give a good baseline. The later carbs were run leaner for emissions reasons, those I would bump up one size to start with.
                    • donebysunday
                      • Oct 2012
                      • 1737
                      • New Berlin, Wi.
                      I found my first 1951 HD in a big garage, pigeon crap and feathers covered it. Guy wanted more but I bought it for $125 and spent near a year getting it road worthy with help from my dad, I was 14 years old.
                      Why couldn't the slide be tapped and aluminum rod threaded and turned into the enlarged hole made in the slide and then drilled to spec ? Then the weight would be near exact.
                      Worth a try, Yea/Nea ?
                      76 XS650 C ROADSTER
                      80 XS650 G Special II
                      https://ibb.co/album/icbGgF
                      80 XS 1100 SG
                      81 XS 1100LH/SH DARKHORSE
                      https://tinyurl.com/k6nzvtw
                      AKA; Don'e, UD, Unca Don'e
                        • 4015
                        I'm wondering if you could find threaded rod that small? How about set screws lock-tited in?
                        • donebysunday
                          • Oct 2012
                          • 1737
                          • New Berlin, Wi.
                          To hard to drill through.
                          Could drill next to, use the set screws just to plug the over sized holes ?
                          Would change the weight a bit more.
                          I swear I saw tiny aluminum rod at Ace.
                          76 XS650 C ROADSTER
                          80 XS 1100 SG
                          • TheRev
                            • Jun 2012
                            • 235
                            • Madison, Wi.
                            Do you think a set screw could be drilled out to the original size hole.
                            1979 xs1100f
                            New Fuse Box
                            Progressive Shocks
                            Gold Valve Emulator
                            Dyna Coils
                            Electronic Flasher
                            Led Headlight
                            Led Turn Signals
                            2nd Gear Fix
                            Auto Cam Tensioner
                            Digital Dash
                            Stainless Bolt Kit
                            Maier Fairing
                            Spin On Oil Filter
                            Plasti Dip Rims
                            ISO Grips
                            • TheRev
                              • Jun 2012
                              • 235
                              • Madison, Wi.
                              How sensitive are the slides to weight? Aluminum would be pretty light.
                              1979 xs1100f
                              New Fuse Box
                              Progressive Shocks
                              Gold Valve Emulator
                              Dyna Coils
                              Electronic Flasher
                              Led Headlight
                              Led Turn Signals
                              2nd Gear Fix
                              Auto Cam Tensioner
                              Digital Dash
                              Stainless Bolt Kit
                              Maier Fairing
                              Spin On Oil Filter
                              Plasti Dip Rims
                              ISO Grips
                                It's not just the weight, but it's also the fact that the original hole is a metered air orifice. That was considered by some to be the main problem with the drilled slides; the home-drilled holes just weren't as consistent in air flow as the factory holes. IIRC some did try to repair the altered slides, but still chased tuning issues until new ones were fitted.
