Jet Kit for 79 xs1100F
  • TheRev
    • Jun 2012
    • 235
    • Madison, Wi.
    #91
    Ok, I just ordered jets for 137.5 and 140. I also ordered a K&N filter. Thanks for all the advice. I will start with stock jets and see how it runs. I then can move up to 140 if I have to. Now I just need the 14 inches of snow we got yesterday to melt. The joy of living in Wisconsin. Thanks
    1979 xs1100f
    New Fuse Box
    Progressive Shocks
    Gold Valve Emulator
    Dyna Coils
    Electronic Flasher
    Led Headlight
    Led Turn Signals
    4 Led Driving Lights
    2nd Gear Fix
    Auto Cam Tensioner
    Digital Dash
    Stainless Braided Lines
    R6 4 Piston Calipers
    Stainless Bolt Kit
    Maier Fairing
    Dyna Balancing Beads
    Spin On Oil Filter
    Stebel Nautilus Horn
    Plasti Dip Rims
    ISO Grips
      • 4015
      Same boat Rev! I'll be pulling carbs as-soon as the jets arrive.
      • MPittma100
        • Aug 2011
        • 2359
        Jets
        The stock 137.5 jets will work just fine. You WILL get good gas mileage - a must for Specials. The only change that you will see with the 140 jets is less MPG.
        If the bike does not run correctly with the stock jets, something else is wrong with it.
        1981 XS1100H Venturer
        K&N Air Filter
        ACCT
        Custom Paint by Deitz
        Geezer Rectifier/Regulator
        EBC Front Rotors
        Limie Accent Moves On In 2015
        Mike
        • TheRev
          • Jun 2012
          • 235
          • Madison, Wi.
          #94
          The bike dosen't run correctly now because my mechanic drilled the slides in an attempt to tune the bike to PODS. I have decided to ditch the PODS and use the air box with a K&N filter. I have jets that say 135 on them. I beleive these are too small so I ordered some 137.5 jets. This is where I will start.
          1979 xs1100f
          New Fuse Box
          Progressive Shocks
          Gold Valve Emulator
          Dyna Coils
          Electronic Flasher
          Led Headlight
          Led Turn Signals
          2nd Gear Fix
          Auto Cam Tensioner
          Digital Dash
          Stainless Bolt Kit
          Maier Fairing
          Spin On Oil Filter
          Plasti Dip Rims
          ISO Grips
            • 4015
            Oh snap Rev. You're getting replacement slides, right?
            • TheRev
              • Jun 2012
              • 235
              • Madison, Wi.
              #96
              Yes Ian
              I purchased four slides. I should be set as soon as the jets come in. Why do you think I had 135 jets in the carbs? Perhaps that has been my problem all along rather than the drilled out slides.
              1979 xs1100f
              New Fuse Box
              Progressive Shocks
              Gold Valve Emulator
              Dyna Coils
              Electronic Flasher
              Led Headlight
              Led Turn Signals
              2nd Gear Fix
              Auto Cam Tensioner
              Digital Dash
              Stainless Bolt Kit
              Maier Fairing
              Spin On Oil Filter
              Plasti Dip Rims
              ISO Grips
                • 4015
                Can't really say honestly. Using the smaller main jets would definitely have leaned out the main circuit, and the effect the drilled slides had is unknown to me. The only indicator of how that bike ran to me would be plug color. Either way, 137.5 mains, stock airbox and a great group of knowledgable guys to ask questions to will get ur bike running sweet.
                  Once you get that airbox installed, this job is going to get a whole lot easier!
                  This can happen when you throw away the airbox: Rockers vs. Mods Berlin cir 1945
                    • 4015
                    That was funny Marty.
                    • TheRev
                      • Jun 2012
                      • 235
                      • Madison, Wi.
                      #100
                      That was awesome Marty! ai see your point about the PODS!
                      1979 xs1100f
                      New Fuse Box
                      Progressive Shocks
                      Gold Valve Emulator
                      Dyna Coils
                      Electronic Flasher
                      Led Headlight
                      Led Turn Signals
                      2nd Gear Fix
                      Auto Cam Tensioner
                      Digital Dash
                      Stainless Bolt Kit
                      Maier Fairing
                      Spin On Oil Filter
                      Plasti Dip Rims
                      ISO Grips
                      • phatts27
                        • Aug 2012
                        • 189
                        • Clementon, New Jersey
                        #101
                        "I feel like such a deuch".
                        81 xs1100 SH
                        81 xs1100 SH (parts)
                        80 suzuki gs550et
                        07 suzuki S40
                          #102
                          Is there any reason my mechanic would drill the slides and then put in a smaller jet?
                          Not any good reason that I can think of.....
                            I'm not sure if our jets are round, small round or large round.
                            Small round' mains are the air-jets in back of carb bell
                            'Large round mains are the main jets used for metering fueling.
