Jet Kit for 79 xs1100F
    • 4015
    Originally posted by TheRev
    So i pulled my main jets yesterday and I can't tell what size they are. Is there a special number I should be looking for? If so where should it be? I can't see any numbers on these jets. Perhaps they wore off.
    On the face of the jet, u should see the number with the Mikuni swirl logo. If u do not see it, they're not Mikuni's. See my link for jets for cheap in my thread.
    • TheRev
      • Jun 2012
      • 235
      • Madison, Wi.
      #77
      Thanks Ian
      Are those jets in your link genuine Mikuni's? You suggest starting with stock and moving up one size on the main, correct?
      1979 xs1100f
      New Fuse Box
      Progressive Shocks
      Gold Valve Emulator
      Dyna Coils
      Electronic Flasher
      Led Headlight
      Led Turn Signals
      4 Led Driving Lights
      2nd Gear Fix
      Auto Cam Tensioner
      Digital Dash
      Stainless Braided Lines
      R6 4 Piston Calipers
      Stainless Bolt Kit
      Maier Fairing
      Dyna Balancing Beads
      Spin On Oil Filter
      Stebel Nautilus Horn
      Plasti Dip Rims
      ISO Grips
        Rev, Go back a a bit and look at my post. I've set up a '79 with the '79 carbs, and I went up 1 jet size with stock air box, K&N, and turnout MAC exhaust. I would start there, and tune as needed. JMHO
        • TheRev
          • Jun 2012
          • 235
          • Madison, Wi.
          #79
          Thanks Ray
          You went to 140 on the main? I will start there. Thanks
          1979 xs1100f
          New Fuse Box
          Progressive Shocks
          Gold Valve Emulator
          Dyna Coils
          Electronic Flasher
          Led Headlight
          Led Turn Signals
          2nd Gear Fix
          Auto Cam Tensioner
          Digital Dash
          Stainless Bolt Kit
          Maier Fairing
          Spin On Oil Filter
          Plasti Dip Rims
          ISO Grips
          • TheRev
            • Jun 2012
            • 235
            • Madison, Wi.
            #80
            Are these the jets i'm looking for.
            http://www.mikesxs.net/product/48-0121.html
            I want to go up one jet size so that would be 140.
            1979 xs1100f
            New Fuse Box
            Progressive Shocks
            Gold Valve Emulator
            Dyna Coils
            Electronic Flasher
            Led Headlight
            Led Turn Signals
            2nd Gear Fix
            Auto Cam Tensioner
            Digital Dash
            Stainless Bolt Kit
            Maier Fairing
            Spin On Oil Filter
            Plasti Dip Rims
            ISO Grips
              Read that again! "Main Jet #140 - Large Round Mikuni Type Yamaha XS650" You aren't going to get Mikuni jets. You're going to get jets that fit in your Mikuni carburetor.
              • TheRev
                • Jun 2012
                • 235
                • Madison, Wi.
                #82
                Good point. I think I want Mikuni. What about these
                http://www.amazon.com/Mikuni-Main-Je...n+main+jet+140
                1979 xs1100f
                New Fuse Box
                Progressive Shocks
                Gold Valve Emulator
                Dyna Coils
                Electronic Flasher
                Led Headlight
                Led Turn Signals
                2nd Gear Fix
                Auto Cam Tensioner
                Digital Dash
                Stainless Bolt Kit
                Maier Fairing
                Spin On Oil Filter
                Plasti Dip Rims
                ISO Grips
                • TheRev
                  • Jun 2012
                  • 235
                  • Madison, Wi.
                  #83
                  I'm not sure if our jets are round, small round or large round.
                  1979 xs1100f
                  New Fuse Box
                  Progressive Shocks
                  Gold Valve Emulator
                  Dyna Coils
                  Electronic Flasher
                  Led Headlight
                  Led Turn Signals
                  2nd Gear Fix
                  Auto Cam Tensioner
                  Digital Dash
                  Stainless Bolt Kit
                  Maier Fairing
                  Spin On Oil Filter
                  Plasti Dip Rims
                  ISO Grips
                    • 4015
                    Hey Rev- I also have 140's in my bike, with a modified airbox I've , and at the time Mac exhaust. The bike runs great! However, my mileage is not great, and I attribute that to my engine modifications and possibly the jetting. So . . . I experiment with a smaller main jet (stock 137.5), and if I don't see a correct tune, I'll resort back to the 140's.
                    If you see my link, the jets are three dollars cheaper. However, as Nate/Moto pointed-out, the pic shows EBC RD jets, yet the description says "Mikuni" under brand. I'll let you know when they arrive. I'll probably be doing my carbs a week or two before you.
                    LARGE ROUND
                    • TheRev
                      • Jun 2012
                      • 235
                      • Madison, Wi.
                      #85
                      Sounds great Ian. I don't ride the bike enough to worry to much about mileage. I just want the bike to run likes it's supposed to. I can't wait to ride it when she is tuned right. I spent the entire season last year trying to tune her. I just hope going back to the air box will solve my problems. I have way to much money invested in these carbs to not have the bike run properly.
                      1979 xs1100f
                      New Fuse Box
                      Progressive Shocks
                      Gold Valve Emulator
                      Dyna Coils
                      Electronic Flasher
                      Led Headlight
                      Led Turn Signals
                      2nd Gear Fix
                      Auto Cam Tensioner
                      Digital Dash
                      Stainless Bolt Kit
                      Maier Fairing
                      Spin On Oil Filter
                      Plasti Dip Rims
                      ISO Grips
                        • 4015
                        Yes, I suppose. But, it'd be nice to see 150-160 miles to the tank + reserve, as opposed to the 130 I currently get.
                          I get mine from Jets R Us. They have removed the guesswork
                          Good luck!
                          • TheRev
                            • Jun 2012
                            • 235
                            • Madison, Wi.
                            #88
                            So i pulled the jets out of the carb today just to see what size they were. I don't want to purchase jets I already have. The jets say 135 and have a symbol of a box within a box. So my guess is that these arn't Mikuni jets. Is 135 close enough to stock Mikuni jets? If so then I will start with them. If I need to go up one jet size then I will go to 140. Does that sound correct.
                            1979 xs1100f
                            New Fuse Box
                            Progressive Shocks
                            Gold Valve Emulator
                            Dyna Coils
                            Electronic Flasher
                            Led Headlight
                            Led Turn Signals
                            2nd Gear Fix
                            Auto Cam Tensioner
                            Digital Dash
                            Stainless Bolt Kit
                            Maier Fairing
                            Spin On Oil Filter
                            Plasti Dip Rims
                            ISO Grips
                            • TheRev
                              • Jun 2012
                              • 235
                              • Madison, Wi.
                              #89
                              Never mind. I guess the symbol of a box within a box is Mikuni. So 135 is too small. I am going to order stock 137.5 and start there. It's interesting that the jets that were in my carbs were smaller. Perhaps that was the main problem. Is there any reason my mechanic would drill the slides and then put in a smaller jet?
                              1979 xs1100f
                              New Fuse Box
                              Progressive Shocks
                              Gold Valve Emulator
                              Dyna Coils
                              Electronic Flasher
                              Led Headlight
                              Led Turn Signals
                              2nd Gear Fix
                              Auto Cam Tensioner
                              Digital Dash
                              Stainless Bolt Kit
                              Maier Fairing
                              Spin On Oil Filter
                              Plasti Dip Rims
                              ISO Grips
                              • red bandit
                                • 970
                                • central michigan
                                #90
                                A symbol of a box within a box, they ARE Mikuni jets. 135 is too small for stock 79 carbs. Stock is 137.5
                                79 SF parts bike.
