Well, I hope you read the fine print in that advert? That MC is for other brands, but not PNP for Yamaha because of the right hand mirror. Ours are reverse threaded on the right side, but this one says you will need to get an adapter to use your OEM mirror, or get a regular right hand threaded mirror for the right side!?
It is the smaller 12.7 mm bore which is even a little smaller than the stock XJ's 14mm. It is designed for single caliper functionality, so it should work fine, but that's why you felt like you weren't getting much braking power when you grabbed the front brake handle/lever because you're only using 1 rotor/caliper with the front lever!
SOME folks don't like the linked system, and separate them, putting both front calipers on the front handlebar lever/MC, and then the rear only on the foot pedal. I have a FRONT XJ style MC on mine...I got it from a local bike parts breaker years ago before I KNEW the difference between the XS and the XJ's MC. I first had to pull the lever all the way to the grip, and even pump it a few times before it would give me any real braking action....but this was with the OEM VINYL lines! Once I put on the SS lines, it was night and day, and I then had a very firm front brake lever without crushing my fingers against the grip! I have since installed some dual caliper FZR600 calipers with a MAJOR MOD to my forks, but the little capacity front MC is even more firmer with even LESS movement!
Due to the proportioning valve for the rear....it sends like 60% of the fluid to the front, and 40% to the rear, and so that's another reason why the rear felt spongy, not to mention a possibly crudded up Caliper Piston and such??
So...plugging up the front section of the rear MC valve from what I've heard will still only give you about 1/2 of the pressure/action vs. an XS rear MC that was designed to drive the rear alone.
Oh...and like Scott and Harry, I too earned the Indy Rick BRICK award this last year, had just filled up the bike at the gas station close to the hotel AFTER the long day's ride. Went to turn around at the end of the pump station, too much clutch, too little throttle and too little speed, and whoomp, down I went on my right side!
I also didn't try to catch the bike with my foot, and thankfully my 1/4" angle iron mounted forward controls/footrests helped keep the engine from totally crushing my ankle inside my riding boots! I was able to extract myself out from under the bike and get it righted fairly quickly without loosing too much fuel out of the gas cap!
Keep at it! T.C.
Keep at it! T.C.
