I can't get my carb's tuned properly with exhaust and pods. ):
    #196
    You'll rarely hit it right on as the shims are increments of .002", but as close as you can get without having too much is what I always shoot for....
    • Dylano*
      • Apr 2014
      • 202
      • San Luis Obispo, CA.
      #197
      Well what would you consider too much?
      You already suggested I make them looser than the tolerances suggest!
      Have:
      1994 FZR600
      1982 XJ1100
      Had:
      1996 YZF600R
      2001 Honda xr125
      Suzuki race 80
      Honda PW 50
      Etc.
      Getting:
      1977 DT400
      • Dylano*
        • Apr 2014
        • 202
        #198
        Oh also another random question for you guys.
        What is the normal operating temperature range for these xj1100's?
        I'm considering installing a temperature gauge, and also wondering where I should hook it up.
        Have:
        1994 FZR600
        1982 XJ1100
        Had:
        1996 YZF600R
        2001 Honda xr125
        Suzuki race 80
        Honda PW 50
        Etc.
        Getting:
        1977 DT400
          Dylano,
          Tuning the depends on the mechanical state of the engine. How much do you want to spend for new shims right now, this minute? If you go for the max valve clearance you'll need to buy more shims.
          Again -- did you check the engine when it was cold or hot? It makes a difference in the clearances measured and Yamaha only gives the specs for cold clearances and cylinder pressures.
          Adjust the valve clearances with the engine cold.
          Remove all four spark plugs and check the cylinder compression with the engine cold.
          Check the ignition system: ignition and pick-up coil resistances; spark plug gaps; spark plug wire resistances.
          Check and adjust the fuel level in the carburetor float bowls.
          Sync the carbs.
          Make carburetor jetting changes.
          • MPittma100
            • Aug 2011
            • 2359
            Valve Clearances
            Since valve train wear lessens the valve clearance, the rule of thumb is to set the valves at the maximum, no more. So if your spec. is .004-.007, set the clearance at .007.
            Mike
            1981 XS1100H Venturer
            K&N Air Filter
            ACCT
            Custom Paint by Deitz
            Geezer Rectifier/Regulator
            Stebel Nautilus Horn
            EBC Front Rotors
            Limie Accent Moves On In 2015
            Mike
            • Dylano*
              • Apr 2014
              • 202
              #201
              Alright! All of that sounds good.. except the order of operations...
              HOPEFULLY this is what will happen this weekend:
              Ill get my jets, and my yics tool.
              I'll sync my carbs,
              then rejet to get it running as good as I can...
              BECAUSE.. I think I MIGHT take it somewhere to get the valves done...
              If the guy will do it for $200. He quoted me over the phone ($200-$300)
              That will save me MUCH time and effort... I mean I could do them myself...
              BUT they shims are much more expensive than I imagined,
              and that would be MUCH more wait time to get the shims and the tools all together
              After the valves are done I'll re-sync my carbs, and re-jet if need be.
              Sound ok?
              Have:
              1994 FZR600
              1982 XJ1100
              Had:
              1996 YZF600R
              2001 Honda xr125
              Suzuki race 80
              Honda PW 50
              Etc.
              Getting:
              1977 DT400
              • Dylano*
                • Apr 2014
                • 202
                #202
                Also, I just wanna say again how awesome this forum is...
                I'm also a member on FZR Online... those people are a**holes!!!
                Seriously, almost no helpful info, just smart ass remarks and stuff.
                Have:
                1994 FZR600
                1982 XJ1100
                Had:
                1996 YZF600R
                2001 Honda xr125
                Suzuki race 80
                Honda PW 50
                Etc.
                Getting:
                1977 DT400
                  Dylano,
                  There is a reason for the order. I'm not just trying to mess with your mind, man but it's your bike, your time and your labor.
                  Where are you buying the shims? There are better deals around but on eBay you can buy shims for ~$6 to $9 each or two shim kits for ~$200 but it's your bike and money:-
                  http://www.ebay.com/sch/sis.html?_nk...9MM+VALVE+SHIM
                  Thanks, we know!
                  Oh! Goody! A CONTEST! <twirls waxed mustache>
                    #204
                    Sound ok?
                    No, but it is your money I guess....
                    You can get new, unused shims for $5 online. So even if you had to buy all 8 shims and the tool we will say on the high side it would cost you $80. That extra $120 could buy a lot of other things....
                      #205
                      Sorry, they have went up in price to $5.95. I still stand buy my less than $80 to do it though...
                      Valve Shims for Bikes in CRC2's Online Catalog of New motorcycle Parts and Accessories Indy
                      • Dylano*
                        • Apr 2014
                        • 202
                        #206
                        Yes I agree, $120 saved is worth it... IF they would both be done in at the same time... BUT I'd gladly spend $120 if that means I can ride the bike and call it mostly DONE a week sooner..
                        I've been building this bike for quite some time now, and getting it running great is the last step before ...taking it apart again to clean everything up better haha
                        But really... I got everything rigged 90% and just want to make it run good and ride-able. THEN I will take apart one section at a time (triple tree/side panels/etc. to bead blast and paint.) Each of those things only taking a day and the bike still being a now ride-able project!
                        That's the goal anyways.
                        I'll probably end up doing the valves myself, but man, I just wanna ride the thing!
                        P.S. of course it's a contest, and YES you are winning! haha
                        Have:
                        1994 FZR600
                        1982 XJ1100
                        Had:
                        1996 YZF600R
                        2001 Honda xr125
                        Suzuki race 80
                        Honda PW 50
                        Etc.
                        Getting:
                        1977 DT400
                        • Dylano*
                          • Apr 2014
                          • 202
                          #207
                          Also, I but everything the cheapest I can get it... Almost always eBay.
                          Have:
                          1994 FZR600
                          1982 XJ1100
                          Had:
                          1996 YZF600R
                          2001 Honda xr125
                          Suzuki race 80
                          Honda PW 50
                          Etc.
                          Getting:
                          1977 DT400
                            Patience grasshopper........in order, as Scott explained IS your best choice.
                            Us oldies' here can guess with farly good accuracy what's gonna happen, and in what order it's gonna take place if NOT following those sound suggestions.
                              • 9980
                              I bought a starter kit from somewhere, don't recall now, and paid like $100 for the shims in an organizer box. I think there were 20 shims. I've been adding from my parts engines as I tear them down.
                              I was trying to do kind of a shim library thing but a couple of people didn't send the ones they took out back to me when I sent what they needed to replenish the stock so I quit.
                                #210
                                Originally posted by motoman
                                us oldies' here can guess with fairly good accuracy what's gonna happen, and in what order it's gonna take place if not following those sound suggestions.
                                +1.... Lolol.....
