I can't get my carb's tuned properly with exhaust and pods. ):
  • Dylano*
    • Apr 2014
    • 202
    • San Luis Obispo, CA.
    #211
    Originally posted by BA80
    I bought a starter kit from somewhere, don't recall now, and paid like $100 for the shims in an organizer box. I think there were 20 shims. I've been adding from my parts engines as I tear them down.
    I was trying to do kind of a shim library thing but a couple of people didn't send the ones they took out back to me when I sent what they needed to replenish the stock so I quit.
    Yeah I saw a couple deals similar to that.
    That a good idea... of course, leave it to the few to spoil it for the many! (:
    Have:
    1994 FZR600
    1982 XJ1100
    Had:
    1996 YZF600R
    2001 Honda xr125
    Suzuki race 80
    Honda PW 50
    Etc.
    Getting:
    1977 DT400
    • Dylano*
      • Apr 2014
      • 202
      #212
      Originally posted by motoman
      Patience grasshopper........in order, as Scott explained IS your best choice.
      Us oldies' here can guess with farly good accuracy what's gonna happen, and in what order it's gonna take place if NOT following those sound suggestions.
      But I would be doing in the order suggested wouldn't I?
      I'll do the order suggested, just sync and rejet BEFORE as well...
      I don't see what harm that could do.
      I will sync and rejet to get it actually running somewhat decently(hopefully) then follow the suggested steps
      Nothin' wring with that in my book!
      Have:
      1994 FZR600
      1982 XJ1100
      Had:
      1996 YZF600R
      2001 Honda xr125
      Suzuki race 80
      Honda PW 50
      Etc.
      Getting:
      1977 DT400
        Do ONE thing at a time Dylan, that way if it isn't right your not wondering which change caused it.
        • Dylano*
          • Apr 2014
          • 202
          #214
          Of course! Good advise I tryy to follow!
          Have:
          1994 FZR600
          1982 XJ1100
          Had:
          1996 YZF600R
          2001 Honda xr125
          Suzuki race 80
          Honda PW 50
          Etc.
          Getting:
          1977 DT400
            Go for it!
            Nope, there's nothing wrong with the way you want to do in my book either!
            Bear in mind that all this stuff can be and usually is cumulative. You may wind up doing several carb syncs; pulling the carbs to clean them; play with the fuel levels and re-jetting several times to work around tight valve clearances and a wonky ignition and/or electrical problem.
            Finally! It's sync'd up and running! You've got a set of monscuceous main jets in that bad boy that'd do a Chrysler 440 Hemi proud so you jump on and ride out to see just exactly what it'll do. Holy Moly! Aside from a few pops and snorts in the low and midrange it hits 5K RPM and pulls like a freight train right up to and over the ton before you know it!
            How are the brakes?
              The advise I usually give anyone that's going to try to build a custom bike is, get it running good with the stock components FIRST. It will run good with the carbs set up stock no matter what you do to it if the carbs and ignition are right.
              Then you can take little steps one at a time to try to improve on it.
                Brakes?
                Greg, I think he's going to take the high, winding, twisty route just for the fun and the leaning <sic> experience: Kinesthesia -- he'll do alright.
                Brakes?
                  • 7819
                  Brakes?
                  Scott, as I remember, the XJ had linked brakes, so he will be able to push on the pedal, try the hand lever, and come to a stop.......eventually. Then, when he tries to start on the next great road, the rotors will be smoking HOT! We've been there, done that.
                  As long as he STARTS with a valve adjustment, the rest should go well.
                  Dylano*, I do have a few shims, so I may be able to send down the correct size once you know what you need.
                    It's like a rerun of, &quot;Officer and A Gentleman&quot; ...
                    He wants to get jets!
                    I've got some spare shims too; gleeped one from the wrecked XJ11 head that's sitting in the corner and fixed the tight exhaust valve that showed up this time around in the valve check.
                    Brakes.
                    • Dylano*
                      • Apr 2014
                      • 202
                      #220
                      I would normally agree with that...
                      BUT I bought this bike in a pile of parts, well a few piles actually.
                      Most of it was there, but rather than build it stock first,
                      I decided to just build it how I want it to begin with.
                      Even if it is harder to get running,
                      I was hoping that this way it would be running and built the way I want it, sooner.
                      That was the goal anyways! (:
                      Have:
                      1994 FZR600
                      1982 XJ1100
                      Had:
                      1996 YZF600R
                      2001 Honda xr125
                      Suzuki race 80
                      Honda PW 50
                      Etc.
                      Getting:
                      1977 DT400
                      • Dylano*
                        • Apr 2014
                        • 202
                        #221
                        How are the brakes?
                        Ahhhh yes the breaks,
                        The fronts weren't all there to begin with,
                        so I got an after market lever and reservoir.
                        I got good pressure,
                        but I have to squeeze the hell out of it with minuscule results!
                        The rear breaks... they are kinda locked up,
                        basically on all the time,
                        BUT I can make them MORE on by pressing the lever!
                        I end up stopping, just slowly... haha
                        Luckily this thing has so much damn torque, that downshifting works wonders!
                        Have:
                        1994 FZR600
                        1982 XJ1100
                        Had:
                        1996 YZF600R
                        2001 Honda xr125
                        Suzuki race 80
                        Honda PW 50
                        Etc.
                        Getting:
                        1977 DT400
                        • Dylano*
                          • Apr 2014
                          • 202
                          #222
                          And if you guys have shims that would be awesome.
                          I'd make it worth your while.
                          This weekend, I will re-measure all the valve clearances,
                          and maybe make a tool to check my shims.
                          Have:
                          1994 FZR600
                          1982 XJ1100
                          Had:
                          1996 YZF600R
                          2001 Honda xr125
                          Suzuki race 80
                          Honda PW 50
                          Etc.
                          Getting:
                          1977 DT400
                            • 3294
                            Dylano*,
                            Get your shims figured out and take the ones you don't need to a dealer service department in your area, along with a six-pack of Coca-Cola. Tell them you are new to the dealership, and wanted to say hello while handing over the soda. Then ask them if they can help you with some shims you want to swap. Ask me how I know.
                            2001 ZRX 1200
                            1982 Seca 750
                            1983 Nighthawk 550
                            • Dylano*
                              • Apr 2014
                              • 202
                              #224
                              Originally posted by Bonz
                              Dylano*,
                              Not a bad idea, if I lived near some dealers...
                              Although there is a shop that might do that for me!
                              Have:
                              1994 FZR600
                              1982 XJ1100
                              Had:
                              1996 YZF600R
                              2001 Honda xr125
                              Suzuki race 80
                              Honda PW 50
                              Etc.
                              Getting:
                              1977 DT400
                              • dpotter58
                                • Aug 2004
                                • 1865
                                • Southern Maryland
                                #225
                                Dude, fix your brakes before you go on the road. Going fast is great but stopping is essential. I don't want to be harsh but don't be stupid. fix your brakes before you go on the road
                                1980 LG
                                1981 LH
