You'll rarely hit it right on as the shims are increments of .002", but as close as you can get without having too much is what I always shoot for....
I can't get my carb's tuned properly with exhaust and pods. ):
Yep, can't leave nuthin' alone... -
Have:
1994 FZR600
1982 XJ1100
Had:
1996 YZF600R
2001 Honda xr125
Suzuki race 80
Honda PW 50
Etc.
Getting:
1977 DT400Comment
Oh also another random question for you guys.
What is the normal operating temperature range for these xj1100's?
I'm considering installing a temperature gauge, and also wondering where I should hook it up.Have:
1994 FZR600
1982 XJ1100
Had:
1996 YZF600R
2001 Honda xr125
Suzuki race 80
Honda PW 50
Etc.
Getting:
1977 DT400Comment
Dylano,
Tuning the depends on the mechanical state of the engine. How much do you want to spend for new shims right now, this minute? If you go for the max valve clearance you'll need to buy more shims.
Again -- did you check the engine when it was cold or hot? It makes a difference in the clearances measured and Yamaha only gives the specs for cold clearances and cylinder pressures.
Adjust the valve clearances with the engine cold.
Remove all four spark plugs and check the cylinder compression with the engine cold.
Check the ignition system: ignition and pick-up coil resistances; spark plug gaps; spark plug wire resistances.
Check and adjust the fuel level in the carburetor float bowls.
Sync the carbs.
Make carburetor jetting changes.
.-- Scott
♬Comment
Valve Clearances
Mike1981 XS1100H Venturer
K&N Air Filter
ACCT
Custom Paint by Deitz
Geezer Rectifier/Regulator
Stebel Nautilus Horn
EBC Front Rotors
Limie Accent Moves On In 2015
MikeComment
Alright! All of that sounds good.. except the order of operations...
HOPEFULLY this is what will happen this weekend:
Ill get my jets, and my yics tool.
I'll sync my carbs,
then rejet to get it running as good as I can...
BECAUSE.. I think I MIGHT take it somewhere to get the valves done...
If the guy will do it for $200. He quoted me over the phone ($200-$300)
That will save me MUCH time and effort... I mean I could do them myself...
BUT they shims are much more expensive than I imagined,
and that would be MUCH more wait time to get the shims and the tools all together
After the valves are done I'll re-sync my carbs, and re-jet if need be.
Sound ok?Have:
1994 FZR600
1982 XJ1100
Had:
1996 YZF600R
2001 Honda xr125
Suzuki race 80
Honda PW 50
Etc.
Getting:
1977 DT400Comment
Also, I just wanna say again how awesome this forum is...
I'm also a member on FZR Online... those people are a**holes!!!
Seriously, almost no helpful info, just smart ass remarks and stuff.Have:
1994 FZR600
1982 XJ1100
Had:
1996 YZF600R
2001 Honda xr125
Suzuki race 80
Honda PW 50
Etc.
Getting:
1977 DT400Comment
Dylano,
There is a reason for the order. I'm not just trying to mess with your mind, man but it's your bike, your time and your labor.
Where are you buying the shims? There are better deals around but on eBay you can buy shims for ~$6 to $9 each or two shim kits for ~$200 but it's your bike and money:-
Thanks, we know!
Seriously, almost no helpful info, just smart ass remarks and stuff.<twirls waxed mustache>
.-- Scott
♬Comment
Sound ok?
You can get new, unused shims for $5 online. So even if you had to buy all 8 shims and the tool we will say on the high side it would cost you $80. That extra $120 could buy a lot of other things....Last edited by natemoen; 05-14-2014, 04:25 PM.Nathan
Theodore RooseveltComment
Yes I agree, $120 saved is worth it... IF they would both be done in at the same time... BUT I'd gladly spend $120 if that means I can ride the bike and call it mostly DONE a week sooner..
I've been building this bike for quite some time now, and getting it running great is the last step before ...taking it apart again to clean everything up better haha
But really... I got everything rigged 90% and just want to make it run good and ride-able. THEN I will take apart one section at a time (triple tree/side panels/etc. to bead blast and paint.) Each of those things only taking a day and the bike still being a now ride-able project!
That's the goal anyways.
I'll probably end up doing the valves myself, but man, I just wanna ride the thing!
P.S. of course it's a contest, and YES you are winning! hahaHave:
1994 FZR600
1982 XJ1100
Had:
1996 YZF600R
2001 Honda xr125
Suzuki race 80
Honda PW 50
Etc.
Getting:
1977 DT400Comment
Us oldies' here can guess with farly good accuracy what's gonna happen, and in what order it's gonna take place if NOT following those sound suggestions.
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
I bought a starter kit from somewhere, don't recall now, and paid like $100 for the shims in an organizer box. I think there were 20 shims. I've been adding from my parts engines as I tear them down.
I was trying to do kind of a shim library thing but a couple of people didn't send the ones they took out back to me when I sent what they needed to replenish the stock so I quit.Greg
The list changes.Comment
