I can't get my carb's tuned properly with exhaust and pods. ):
You said:4 over mains, 1 over pilots, pilot screws 6 out.
Screwed pilot screws down to 3.5 out.
I would go back to stock on the pilot jets. I may start fine, but after you warm it up and go a few blocks it could be overly rich. If you are talking about earlier carbs, you can't block the carb vent hoses or you will start overfilling the carbs... (sorry, I don't know your carb models, I forgot to look.)Skids (Sid Hansen)
Down to one 1978 E. Stock air box with K&N filter, 81H pipes and carbs, 8500 feet elevation.Comment
I have checked my plugs after every run, and they look great, that is why I THINK they are good. I'm no expert, so although the plugs look good to me, they could still be the wrong mains, but I am fairly confident they are good.Have:
1994 FZR600
1982 XJ1100
Had:
1996 YZF600R
2001 Honda xr125
Suzuki race 80
Honda PW 50
Etc.
Getting:
1977 DT400Comment
I would go back to stock on the pilot jets. I may start fine, but after you warm it up and go a few blocks it could be overly rich. If you are talking about earlier carbs, you can't block the carb vent hoses or you will start overfilling the carbs... (sorry, I don't know your carb models, I forgot to look.)Have:
1994 FZR600
1982 XJ1100
Had:
1996 YZF600R
2001 Honda xr125
Suzuki race 80
Honda PW 50
Etc.
Getting:
1977 DT400Comment
I'm curious to know.... WAS the headlight bucket off this bike at any time???
The reason I ask is........ I installed a new/used headlight bucket last season. After a week or so I had serious stumbling, stalling, backfire problems. ONLY while I was moving. I went absolutely NUTS trying to figure out why.. Then I remembered, ALL of the ign./ power wires are in that bucket and they were all disconnected and re-connected..... I went back in the bucket and checked, cleaned and rechecked all of the connections. Problem GONE!!!!!!!!! You may be chasing your tail looking at the carbs or fuel. I would start disconnecting, cleaning, greasing all the electrical connections starting at the battery. "Deoxit" is an awesome cleaner. It can be found at electronics store and music stores where they sell amps, guitars, and things. AND just because it might not have been off, doesn't mean the problem isn't in there. Give the fuel system and your brain a break. It's not like cleaning connections is a waste of time. If you received this bike in parts, I'm sure they were all neglected. Good Luck!!!Rob
82 XJ1100
Stock..With a few cosmetic changes.
Current Project..Dad's 81 1100 Special
http://s727.photobucket.com/albums/ww272/RiderXJ/Comment
The reason I ask is........ I installed a new/used headlight bucket last season. After a week or so I had serious stumbling, stalling, backfire problems. ONLY while I was moving. I went absolutely NUTS trying to figure out why.. Then I remembered, ALL of the ign./ power wires are in that bucket and they were all disconnected and re-connected..... I went back in the bucket and checked, cleaned and rechecked all of the connections. Problem GONE!!!!!!!!! You may be chasing your tail looking at the carbs or fuel. I would start disconnecting, cleaning, greasing all the electrical connections starting at the battery. "Deoxit" is an awesome cleaner. It can be found at electronics store and music stores where they sell amps, guitars, and things. AND just because it might not have been off, doesn't mean the problem isn't in there. Give the fuel system and your brain a break. It's not like cleaning connections is a waste of time. If you received this bike in parts, I'm sure they were all neglected. Good Luck!!!....
Have:
1994 FZR600
1982 XJ1100
Had:
1996 YZF600R
2001 Honda xr125
Suzuki race 80
Honda PW 50
Etc.
Getting:
1977 DT400Comment
Just be cause it looks good doesn't mean it is good. ( 3 divorces)Greg
The list changes.Comment
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Theodore RooseveltComment
Yeah basically that was all apart, and I got it hooked up working great, so I thought. Could that crap really be my problem? I though all that was just for the "warning everything is broken" module between the gauges.Have:
1994 FZR600
1982 XJ1100
Had:
1996 YZF600R
2001 Honda xr125
Suzuki race 80
Honda PW 50
Etc.
Getting:
1977 DT400Comment
And if you are using old plugs, all bets are off.
CZComment
If the vent's plugged the engine'll run and rev fine until you get on the road, then it'll pull a vacuum in the tank and basically run out of gas until it sits for a few minutes and the air pressure equalizes enough for the fuel to flow down to the carbs again.
That'd beat the heck out of changing jets again or messing up that pretty blue wiring.
.-- Scott
♬Comment
"Mmm, could be!" (munching on a carrot) but have you checked the fuel tank filler cap to see if the vent is plugged up?
.Have:
1994 FZR600
1982 XJ1100
Had:
1996 YZF600R
2001 Honda xr125
Suzuki race 80
Honda PW 50
Etc.
Getting:
1977 DT400Comment
Found/cleaned the vent holes,
Literally, runs PERFECT!!!!
I had to change plugs and put pilot screws at 4 turns, and she purrs, and HAULS ASSSSSSS!!!!!!
Now it's time for all the cosmetics, well before that, the brakes, and a steering damper, and new front rubber.
I seriously can't believe this entire time it has just been a clogged freaking vent hole!
before I uncloged It I went on one more test ride, and checked the fuel filter.
it was at the same level as the other, but I guess a vacuum was keeping it at that level and choking the carbs!!!
Seriously I can't thank you all enough.
ESPECIALLY YOU 3Phase!!!
Ockams razor right?!?! *slaps face*Have:
1994 FZR600
1982 XJ1100
Had:
1996 YZF600R
2001 Honda xr125
Suzuki race 80
Honda PW 50
Etc.
Getting:
1977 DT400Comment
Right on! That's about the best news I've had all day except for my new clutch springs showing up! Yeah, it's been one of those days.
It's happened to me and a lot of other folks, glad you got it fixed now put it back together and go ride somewhere!
.-- Scott
♬Comment
