I can't get my carb's tuned properly with exhaust and pods. ):
  • Dylano*
    • Apr 2014
    • 202
    • San Luis Obispo, CA.
    #136
    Originally posted by motoman
    Likely broke off a chip of brass, and it wedged down in the threads.
    Probably EXACTLY wehat happened... haha
    I also think I need to adjust my valves as I have a feeling they might be sticking, and thus giving me some of my popping.
    The problem is, these have those shim things... and dont you need like a boat load of a selection to adjust the valves properly? Like don't you take the measurement, then dependent on what it is, read off a chart what size to put in, and it could more than likely be different for each valve...?
    And aren't those shimms hard to find!?? haha
    Have:
    1994 FZR600
    1982 XJ1100
    Had:
    1996 YZF600R
    2001 Honda xr125
    Suzuki race 80
    Honda PW 50
    Etc.
    Getting:
    1977 DT400
    • Dylano*
      • Apr 2014
      • 202
      #137
      Originally posted by BA80
      I'm wondering if the idle mix screw issue isn't related to #1 the fuel delivery problem, #2 the sync problem. It's impossible to tune carbs without being able to sync them properly.
      I know, I definitely need to get THIS right?
      http://www.ebay.com/itm/The-YICS-Eli...151721&vxp=mtr
      Have:
      1994 FZR600
      1982 XJ1100
      Had:
      1996 YZF600R
      2001 Honda xr125
      Suzuki race 80
      Honda PW 50
      Etc.
      Getting:
      1977 DT400
      • Dylano*
        • Apr 2014
        • 202
        #138
        See Greg, you're doing great, you don't have to be an XJ guru like Jerry!
        Dylano, sounds like you've found a major problem to the performance, yep, the bike won't run right without fuel! Now, with the pilot screw 7 turns out, as has been stated in previous posts that once you're over 3-4 turns out, it's time to go up in jet size. Now that the carbs can get and KEEP a consistent fuel level, you'll probably find you'll be able to start having success in your tuning efforts....keep at it!
        That's what I thought! BUT i put THREE over pilots in and the pilot screws STILL had to be turned out like 4-5 turns?! Any ideas?
        Have:
        1994 FZR600
        1982 XJ1100
        Had:
        1996 YZF600R
        2001 Honda xr125
        Suzuki race 80
        Honda PW 50
        Etc.
        Getting:
        1977 DT400
          Have you synced them yet Dylan? With gauges I mean.
          You'll need one of THESE and most XJers just leave them in.
          • Dylano*
            • Apr 2014
            • 202
            #140
            I posted a link to that same thing on the last page!
            No I haven't synced them yet.
            I will buy that tool soon, and hopefully my jets will all be here soon too, even though they STILL haven't sent me tracking info or anything ):
            What are the up's and down's to leaving that tool in vs taking it out?
            Also what do you think about that last post I made, responding to the persona saying I need bigger pilots?
            I know I need to vacuum sync them, but I feel as if my bench sync was pretty effective... I did you gauge pins, and got them all to the same slip fit, all through the throttle range too.
            Have:
            1994 FZR600
            1982 XJ1100
            Had:
            1996 YZF600R
            2001 Honda xr125
            Suzuki race 80
            Honda PW 50
            Etc.
            Getting:
            1977 DT400
            • Dylano*
              • Apr 2014
              • 202
              #141
              ALSO
              Does anyone have the specs of that yics tool?
              I could whip that up pretty easily on the lathe if I had dimensions,
              Just looks like a tube with some o-rings!
              Have:
              1994 FZR600
              1982 XJ1100
              Had:
              1996 YZF600R
              2001 Honda xr125
              Suzuki race 80
              Honda PW 50
              Etc.
              Getting:
              1977 DT400
              • Dylano*
                • Apr 2014
                • 202
                #142
                Have:
                1994 FZR600
                1982 XJ1100
                Had:
                1996 YZF600R
                2001 Honda xr125
                Suzuki race 80
                Honda PW 50
                Etc.
                Getting:
                1977 DT400
                  The shims are 29mm. Yamaha, Kawasaki, and BMW all take the same shims.
                  You can get a small assortment on fleabay pretty cheap or individually from one of the MC dealers I listed.
                  HOME MADE YICS TOOL INSRUCTIONS
                  Seems $40 is pretty cheap for plug and play though.
                  • Dylano*
                    • Apr 2014
                    • 202
                    #144
                    Wow that's great info to know, thank you.
                    I will get some shims and adjust those bad boys!
                    What do you think of this?!
                    Will that work with my 1100?
                    It is cheap, just the waiting I can't stand!!! HAHA I'd rather make it today!
                    Have:
                    1994 FZR600
                    1982 XJ1100
                    Had:
                    1996 YZF600R
                    2001 Honda xr125
                    Suzuki race 80
                    Honda PW 50
                    Etc.
                    Getting:
                    1977 DT400
                      I think that's prey much what's in the instructions in that link I sent.
                        Since seeing you use that word 'sticking valves' in a couple threads now, just wanted to let you know that is NOT what happens having the wrong heat expansion clearances. Too much clearance, valve doesn't lift enough and is late doing so. Too tight and won't seat tight eventually leads to burnt valve.
                        • Dylano*
                          • Apr 2014
                          • 202
                          #147
                          I'm aware that they aren't actually sticking as in remaining stationary, I mean more like sticking as in staying open, and not closing all the way. (: I agree it is a terrible term though.
                          Have:
                          1994 FZR600
                          1982 XJ1100
                          Had:
                          1996 YZF600R
                          2001 Honda xr125
                          Suzuki race 80
                          Honda PW 50
                          Etc.
                          Getting:
                          1977 DT400
                          • Dylano*
                            • Apr 2014
                            • 202
                            #148
                            Valve clearance is as follows:
                            (Inches)
                            (SUPPOSED TO BE .008"-.010")
                            Exhaust:
                            1. .006"
                            2. .008"
                            3. .007"
                            4. .007"
                            (SUPPOSED TO BE .004-.006")
                            Intake:
                            1. .005"
                            2. .004"
                            3. .004"
                            4. .002"
                            NOW, those clearance gaps SHOULD get bigger with time due to wear, correct? OR do they get tighter for some reason like my diesel?!
                            That has always confused me...
                            Basically what I'm asking is:
                            Should I buy smaller shims to make the gaps bigger?
                            (on the ones that are at the bottom of, but in, tolerance)
                            and should I mainly worry about the ones that are over tolerance?
                            Have:
                            1994 FZR600
                            1982 XJ1100
                            Had:
                            1996 YZF600R
                            2001 Honda xr125
                            Suzuki race 80
                            Honda PW 50
                            Etc.
                            Getting:
                            1977 DT400
                              Still not sticking.......to tight and not sealing properly.
                              The clearance DIMINISHES(get tighter). Set clearances at upper end of specs.
                              • Dylano*
                                • Apr 2014
                                • 202
                                #150
                                That,s what I thought!!! What is it that makes that happen though???
                                Have:
                                1994 FZR600
                                1982 XJ1100
                                Had:
                                1996 YZF600R
                                2001 Honda xr125
                                Suzuki race 80
                                Honda PW 50
                                Etc.
                                Getting:
                                1977 DT400
