I can't get my carb's tuned properly with exhaust and pods. ):
  • CaptonZap
    • Jun 2010
    • 1748
    • Denver
    #286
    Originally posted by Dylano*
    I think the mains are good.
    And looking at them after the thing chokes would let you KNOW, not think.
    CZ
      • 5073
      #287
      You said:4 over mains, 1 over pilots, pilot screws 6 out.
      Screwed pilot screws down to 3.5 out.
      I would go back to stock on the pilot jets. I may start fine, but after you warm it up and go a few blocks it could be overly rich. If you are talking about earlier carbs, you can't block the carb vent hoses or you will start overfilling the carbs... (sorry, I don't know your carb models, I forgot to look.)
      • Dylano*
        • Apr 2014
        • 202
        • San Luis Obispo, CA.
        #288
        CZ
        I have checked my plugs after every run, and they look great, that is why I THINK they are good. I'm no expert, so although the plugs look good to me, they could still be the wrong mains, but I am fairly confident they are good.
        Have:
        1994 FZR600
        1982 XJ1100
        Had:
        1996 YZF600R
        2001 Honda xr125
        Suzuki race 80
        Honda PW 50
        Etc.
        Getting:
        1977 DT400
        • Dylano*
          • Apr 2014
          • 202
          #289
          I've tried stock pilots two separate times, in order for it to run pilots screws have to be out like seven turns.
          Have:
          1994 FZR600
          1982 XJ1100
          Had:
          1996 YZF600R
          2001 Honda xr125
          Suzuki race 80
          Honda PW 50
          Etc.
          Getting:
          1977 DT400
          • XJ Rob
            • Apr 2009
            • 161
            • Kimball, Michigan
            #290
            I'm curious to know.... WAS the headlight bucket off this bike at any time???
            The reason I ask is........ I installed a new/used headlight bucket last season. After a week or so I had serious stumbling, stalling, backfire problems. ONLY while I was moving. I went absolutely NUTS trying to figure out why.. Then I remembered, ALL of the ign./ power wires are in that bucket and they were all disconnected and re-connected..... I went back in the bucket and checked, cleaned and rechecked all of the connections. Problem GONE!!!!!!!!! You may be chasing your tail looking at the carbs or fuel. I would start disconnecting, cleaning, greasing all the electrical connections starting at the battery. "Deoxit" is an awesome cleaner. It can be found at electronics store and music stores where they sell amps, guitars, and things. AND just because it might not have been off, doesn't mean the problem isn't in there. Give the fuel system and your brain a break. It's not like cleaning connections is a waste of time. If you received this bike in parts, I'm sure they were all neglected. Good Luck!!!
            Rob
            82 XJ1100
            Stock..With a few cosmetic changes.
            Current Project..Dad's 81 1100 Special
            http://s727.photobucket.com/albums/ww272/RiderXJ/
            • Dylano*
              • Apr 2014
              • 202
              #291
              You couldn't POSSIBLY be talking about THIS neat and tidy, all assuredly properly connected ball of wires could you?! ....
              Have:
              1994 FZR600
              1982 XJ1100
              Had:
              1996 YZF600R
              2001 Honda xr125
              Suzuki race 80
              Honda PW 50
              Etc.
              Getting:
              1977 DT400
                • 9981
                Just be cause it looks good doesn't mean it is good. ( 3 divorces)
                  .......scotch-locs and who knows what all.......
                    #294
                    I HATE THOSE THINGS WITH THE GREATEST PASSION ONE CAN POSSIBLY MUSTER!!!!!!!
                    The number of truck driver I have cussed out over the years after they "fixed" their trailer lights..........
                    • Dylano*
                      • Apr 2014
                      • 202
                      #295
                      Yeah basically that was all apart, and I got it hooked up working great, so I thought. Could that crap really be my problem? I though all that was just for the "warning everything is broken" module between the gauges.
                      Have:
                      1994 FZR600
                      1982 XJ1100
                      Had:
                      1996 YZF600R
                      2001 Honda xr125
                      Suzuki race 80
                      Honda PW 50
                      Etc.
                      Getting:
                      1977 DT400
                      • CaptonZap
                        • Jun 2010
                        • 1748
                        • Denver
                        #296
                        Did you check them after you got back to the shop? Plugs will change color in a few seconds, so if the engine is crapping out, hit the kill switch, pull the clutch, coast over to the side of the road, and pull the plugs and look. If they aren't black, then chances are that there are other problems. If two are black, 1-4 or 2-3, then you probably have ignition problems. Usually though, igniton faults leave the plugs at their running color when the ignition failed. They might be wet, depending on how hot the engine is and how fast you got the plugs out.
                        And if you are using old plugs, all bets are off.
                        CZ
                          "Mmm, could be!" (munching on a carrot) but have you checked the fuel tank filler cap to see if the vent is plugged up?
                          If the vent's plugged the engine'll run and rev fine until you get on the road, then it'll pull a vacuum in the tank and basically run out of gas until it sits for a few minutes and the air pressure equalizes enough for the fuel to flow down to the carbs again.
                          That'd beat the heck out of changing jets again or messing up that pretty blue wiring.
                          • Dylano*
                            • Apr 2014
                            • 202
                            #298
                            Vent hole?!?! That could be it! I have noticed that sometimes my right hand side filter would run dry... messing with the petckock was the only thing that fixed it.... when I've been riding... I've so far neglected to see if that is happening -_- I really hope that is it so I can feel like a happy idiot!!!!
                            Have:
                            1994 FZR600
                            1982 XJ1100
                            Had:
                            1996 YZF600R
                            2001 Honda xr125
                            Suzuki race 80
                            Honda PW 50
                            Etc.
                            Getting:
                            1977 DT400
                            • Dylano*
                              • Apr 2014
                              • 202
                              #299
                              Found/cleaned the vent holes,
                              Literally, runs PERFECT!!!!
                              I had to change plugs and put pilot screws at 4 turns, and she purrs, and HAULS ASSSSSSS!!!!!!
                              Now it's time for all the cosmetics, well before that, the brakes, and a steering damper, and new front rubber.
                              I seriously can't believe this entire time it has just been a clogged freaking vent hole!
                              before I uncloged It I went on one more test ride, and checked the fuel filter.
                              it was at the same level as the other, but I guess a vacuum was keeping it at that level and choking the carbs!!!
                              Seriously I can't thank you all enough.
                              ESPECIALLY YOU 3Phase!!!
                              Ockams razor right?!?! *slaps face*
                              Have:
                              1994 FZR600
                              1982 XJ1100
                              Had:
                              1996 YZF600R
                              2001 Honda xr125
                              Suzuki race 80
                              Honda PW 50
                              Etc.
                              Getting:
                              1977 DT400
                                Right on! That's about the best news I've had all day except for my new clutch springs showing up! Yeah, it's been one of those days.
                                It's happened to me and a lot of other folks, glad you got it fixed now put it back together and go ride somewhere!
