Stuck at 4k rpm..... Ugh!
79F
"Excelsior"
Honda gl1100 handlebar
Vetter IV fairing with speaker system
OE headers,Jardine slipons
Hid headlight 6000k
Stock jets
Shinko 712 F & R
Oe hardbags and luggage rack
TC fuse block
K&n filter with oe airbox
Raptor 660 Acct -
I would try flattening the washer on the throttle linkage, extreme left, and loosening the nut slightly. I removed mine to zinc plate the washer and nut and when I put them back on, I over tightened them slightly and found the throttle stuck. Might be worth a try...XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
OK. #1 is the easiest to remove from the rack. Take it off and figure out what's hanging up.Greg
PS......do it in a pan with tall sides, like a plastic dish pan. So you don't have any tiny pieces ( like a tiny detent ball for the choke rod ) fly away into never never (never find it) land.
Are you sure that there is nothing actually stuck in the bore of the carb? A tiny piece of grit or whatever. The brass butterfly would tend to force it into the softer aluminium. Have you opened up the butterfly and felt in there, and on the edge of the butterfly itself?XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
Great video Spark!1979 XS1100F
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Comment
Today I'll get back to the carb diagnosing...
Yesterday I decided to go to the gym with my buddy whos a Sgt in the army...
Needless to say, sitting down and working on the carbs will be a blessing after working on cars all day at work today....
79F
"Excelsior"
Hid headlight 6000k
Stock jets
Shinko 712 F & R
TC fuse block
Raptor 660 AcctComment
"Excelsior"
Hid headlight 6000k
Stock jets
Shinko 712 F & R
TC fuse block
The butterfly valve is WAY off center in the throat of that carb. Have you loosened the 2 screws that hold it and see if it frees up?
Also, if that nut on the end of the shaft ( right side of video outside the carb) is too tight it will cause sticking too.Greg
I have three different tips for my driver, none of which fit just right for me to trust it...
How soft are the screws?79F
"Excelsior"
Hid headlight 6000k
Stock jets
Shinko 712 F & R
TC fuse block
A GOOD #2 Phillips is what you need. Set it in the head by lightly tapping it in and turn the screws counter clockwise carefully slowly increasing force and they will come loose. Set the carb on a bench or table so you can hold the driver in there good. Some penetrating oil wouldn't hurt either. You don't need to take them out, just loosen them.
Before you do that loosen the nut on the shaft and see if that helps.Greg
okay, I got everything loose.
I can get the butterfly to act smoothly without that nut on the side.
But the MOMENT that nut comes into play even finger tight, things start binding up.
Whats the correct procedure to setting this?
EDIT
GOT IT!!
My problem was that one of the spring coils, sunk into the gap that was made when I loosened everything
Now its all tightened and working how it should be!Last edited by sparkfly88; 11-14-2013, 06:31 PM.79F
"Excelsior"
Hid headlight 6000k
Stock jets
Shinko 712 F & R
TC fuse block
That nut doesn't need to be "tight". It has a washer that bends over the flats to keep it from backing off. Screw it on to the point just before it starts binding and lock it there with the washer.
Then, close the butterfly all the way. Make sure it is centered good in the bore and retighten the screws.
Understand?Greg
Just saw your edit. COOL! I suspected it was something simple like that.
There's all kinds of crazy stuff that can drive you up a wall with these bikes.Greg
