Stuck at 4k rpm..... Ugh!
  • sparkfly88
    • Mar 2013
    • 585
    • CedarKey FL
    Well, my shaft seals have finally kicked the bucket....
    My butterflies won't shut all the way...
    Time to order seals....
    Where's the best place?
    79F
    "Excelsior"
    Honda gl1100 handlebar
    Vetter IV fairing with speaker system
    OE headers,Jardine slipons
    Hid headlight 6000k
    Stock jets
    Shinko 712 F & R
    Oe hardbags and luggage rack
    TC fuse block
    K&n filter with oe airbox
    Raptor 660 Acct
    Check and make sure your throttle cable is in place and that the carb linkage isn't hanging on something. Like a boot clamp.
    • sparkfly88
      • Mar 2013
      • 585
      • CedarKey FL
      I've been having the problem for a while. I've just been bandaiding it with lube.
      Number one and number 4 jam up even when not on the rack.
      79F
      "Excelsior"
      Hid headlight 6000k
      Stock jets
      Shinko 712 F & R
      TC fuse block
      Raptor 660 Acct
        MikesXS.net has them.
        http://www.mikesxs.net/product/48-5021.html
        OEM #is: 25-14997-00-00 according to Mikes.
        And just below that item if you go back to the carbs parts page, they also have the replacement butterfly screws...since you'll need to grind off the crimped/peened end of the OEM ones on there!
          It seems to me that if the butterfly shafts are so loose in the carb bodies that the valves are sticking it seems it will need a little more than rubber seals to fix it. It would need bushings in the shaft holes.
          I can't see these carbs getting that worn with the design they are. Unless those shafts are absolutely flopping around in the bores I would bet on another cause.
          Just speaking from 35 years of experience rebuilding all types of carburetors.
          • sparkfly88
            • Mar 2013
            • 585
            • CedarKey FL
            I thought it was common knowledge on here when it was sticking... It's the seals swelling? At least that's what I've gathered....
            They soaked my carbs in some unknown cleaner to me for a weekend After I told them not to.
            I bet that was the problem.
            Thanks cat for the links.. I wasn't sure if it was them or not.
            Sirus or whatever that site is had them for like 23$ Woo!
            79F
            "Excelsior"
            Hid headlight 6000k
            Stock jets
            Shinko 712 F & R
            TC fuse block
            Raptor 660 Acct
              Funny, I've never experienced the "swelling" issue and Ive been into a lot of these carbs. I've actually never heard of that and I'
              've been around since 2009. (different name) So, not so common.
              I hope the problem is that easy to fix for you.
                That's just another reason we suggest here that you learn and rebuild these carbs yourself.
                • sparkfly88
                  • Mar 2013
                  • 585
                  • CedarKey FL
                  Sorry if that was abrasive at all... It's just how I talk....
                  I'm honestly trying to learn.
                  It was just a question.
                  So basically I have to take the carbs out at really look and see what the issue is.
                  I'll even record it and stick a video link on photo bucket.
                  79F
                  "Excelsior"
                  Hid headlight 6000k
                  Stock jets
                  Shinko 712 F & R
                  TC fuse block
                  Raptor 660 Acct
                    That would be your best approach. Ordering parts before you actually know what you need can end up being a waste of time and money. You may get it apart and find that the issue is being caused by bent or rusted linkage parts.
                    One other thing is, if the butterfly valves were removed when the carbs were gone through before they could very well be off center or the screws may have come loose. Either would cause hanging up.
                    I would be very doubtful of the seals but then I have been wrong before.......lots.
                    • sparkfly88
                      • Mar 2013
                      • 585
                      • CedarKey FL
                      They haven't been removed.. .... They still have the original peened over screws..
                      But I could try that trick I read about loosening them, closing the valve then tightening them so they'd be centered.
                      Shrug.
                      At least I have my jeep. It's just not as fun as Excelsior
                      79F
                      "Excelsior"
                      Hid headlight 6000k
                      Stock jets
                      Shinko 712 F & R
                      TC fuse block
                      Raptor 660 Acct
                        I used carb soak before and the throttle plate seals swelled. I then soaked them in mineral spirits and they returned to normal. I thought all of the Chems would have disintegrated the rubber but that was like a decade ago.
                        • sparkfly88
                          • Mar 2013
                          • 585
                          • CedarKey FL
                          Since they started sticking....I have been using silicone spray at the shaft ends.
                          Its worked for a while, but yesterday no matter what I did, would not work.
                          It will stick at 4k RPM, till I push the linkage down with a screwdriver.
                          Rinse and repeat
                          79F
                          "Excelsior"
                          Hid headlight 6000k
                          Stock jets
                          Shinko 712 F & R
                          TC fuse block
                          Raptor 660 Acct
                            I have not often heard or read of some one having this issue, but then, it is very often stated and or repeated, and repeated to any one who mentioned cleaning the carbs in any type of dip to avoid this situation. I don't think it is a "meatloaf and the pan" type of thing, so I believe every now and then someone suffers the fate of this occurring. Sorry it had to be you.
                            IF that rubber swells, it could itself push the stem off center if it swelled inconsistently. Therefor pushing the disc off center.
                            If you know the rubber is swollen, and has been that long, it is probably misshaped by now as well. You will need to replace them no matter what the other issue might be. I would order the seals, and pay close attention to the rest of your linkage and such on your way to getting the new seals installed.
                            • sparkfly88
                              • Mar 2013
                              • 585
                              • CedarKey FL
                              Of course it would be me
                              When I get home today, Ill take the carbs out and video document the problems.
                              Funny thing is, I had to trailer my bike home, pretty much from the same area I bought it from back in march
                              Only this time the bike was in WAY better condition than when I got it
                              79F
                              "Excelsior"
                              Hid headlight 6000k
                              Stock jets
                              Shinko 712 F & R
                              TC fuse block
                              Raptor 660 Acct
