Stuck at 4k rpm..... Ugh!
    • 9980
    Just found these there also. Not quite so painful. Only one left though.
      #47
      Plus postage!
      ^ Oh snap! $36 for a t-connector??? Nooooo way! There are tons of things at a hardware store I could make happen for much less before I ever consider that, let alone small bike shops, etc. I know there has to be online places much cheaper than that!
      Hi Ian,
      that's one turned brass thing, one turned and cross-bored brass thing, a brazed assembly and 4 o-rings to install, it's quite a complicated
      little part with far too small a job run for the economies of full automation.
      Add the 200% markup the e-seller puts on what they paid the Asiatic mfrs for the bulk purchase.
      And the warehousing and putting them in little plastic bags.
      Mind you, $20 postage is a bit rough for something that'll fit in a small bubble envelope.
      • sparkfly88
        • Mar 2013
        • 585
        • CedarKey FL
        #48
        Well I'm out here right now.... And the rubber must have swelled enough to stop the leak totally....
        Petcocks on prime, and moving the tee back and forth isn't producing a single drop...
        79F
        "Excelsior"
        Honda gl1100 handlebar
        Vetter IV fairing with speaker system
        OE headers,Jardine slipons
        Hid headlight 6000k
        Stock jets
        Shinko 712 F & R
        Oe hardbags and luggage rack
        TC fuse block
        K&n filter with oe airbox
        Raptor 660 Acct
          • 9980
          • sparkfly88
            • Mar 2013
            • 585
            • CedarKey FL
            #50
            And I just finished syncing, colortuning, and reassembling her.
            Going out on an evening run with a buddy of mine.
            79F
            "Excelsior"
            Hid headlight 6000k
            Stock jets
            Shinko 712 F & R
            TC fuse block
            Raptor 660 Acct
            • sparkfly88
              • Mar 2013
              • 585
              • CedarKey FL
              #51
              I'm happy to report I did 53 miles tonight. A mix of highway and city.
              It performed flawlessly aside from the cruising stumble I get at lower rpm while in a high gear, but not that big of a deal to me right now.
              Woo!
              Thank you everyone for following the thread and your insights as I went through this headache!
              The next project I do will follow the same kind of flow. I'll video tape n such.
              79F
              "Excelsior"
              Hid headlight 6000k
              Stock jets
              Shinko 712 F & R
              TC fuse block
              Raptor 660 Acct
