Stuck at 4k rpm..... Ugh!
  • sparkfly88
    • Mar 2013
    • 585
    • CedarKey FL
    First video!
    The second video is uploading, I have the carbs out and you can see the sticking butterfly
    79F
    "Excelsior"
    Honda gl1100 handlebar
    Vetter IV fairing with speaker system
    OE headers,Jardine slipons
    Hid headlight 6000k
    Stock jets
    Shinko 712 F & R
    Oe hardbags and luggage rack
    TC fuse block
    K&n filter with oe airbox
    Raptor 660 Acct
    • James England
      • 3039
      • North of England
      I would try flattening the washer on the throttle linkage, extreme left, and loosening the nut slightly. I removed mine to zinc plate the washer and nut and when I put them back on, I over tightened them slightly and found the throttle stuck. Might be worth a try...
      • sparkfly88
        • Mar 2013
        • 585
        • CedarKey FL
        Second video finally finished.
        79F
        "Excelsior"
        Hid headlight 6000k
        Stock jets
        Shinko 712 F & R
        TC fuse block
        Raptor 660 Acct
          OK. #1 is the easiest to remove from the rack. Take it off and figure out what's hanging up.
            PS......do it in a pan with tall sides, like a plastic dish pan. So you don't have any tiny pieces ( like a tiny detent ball for the choke rod ) fly away into never never (never find it) land.
            • James England
              • 3039
              • North of England
              Are you sure that there is nothing actually stuck in the bore of the carb? A tiny piece of grit or whatever. The brass butterfly would tend to force it into the softer aluminium. Have you opened up the butterfly and felt in there, and on the edge of the butterfly itself?
                • 4015
                Great video Spark!
                • sparkfly88
                  • Mar 2013
                  • 585
                  • CedarKey FL
                  Today I'll get back to the carb diagnosing...
                  Yesterday I decided to go to the gym with my buddy whos a Sgt in the army...
                  Needless to say, sitting down and working on the carbs will be a blessing after working on cars all day at work today....
                  79F
                  "Excelsior"
                  Hid headlight 6000k
                  Stock jets
                  Shinko 712 F & R
                  TC fuse block
                  Raptor 660 Acct
                  • sparkfly88
                    • Mar 2013
                    • 585
                    • CedarKey FL
                    GENTLEMEN I think I found the PROBLEM!!
                    FIRST WE HAVE MY PROFESSIONAL DIAGNOSIS video walkthrough
                    Then I had this BRIGHT IDEA
                    see the problem? I do
                    My next problem is I dont have the proper screwdriver tip to fit the screws
                    79F
                    "Excelsior"
                    Hid headlight 6000k
                    Stock jets
                    Shinko 712 F & R
                    TC fuse block
                    Raptor 660 Acct
                      The butterfly valve is WAY off center in the throat of that carb. Have you loosened the 2 screws that hold it and see if it frees up?
                      Also, if that nut on the end of the shaft ( right side of video outside the carb) is too tight it will cause sticking too.
                      • sparkfly88
                        • Mar 2013
                        • 585
                        • CedarKey FL
                        I have three different tips for my driver, none of which fit just right for me to trust it...
                        How soft are the screws?
                        79F
                        "Excelsior"
                        Hid headlight 6000k
                        Stock jets
                        Shinko 712 F & R
                        TC fuse block
                        Raptor 660 Acct
                          A GOOD #2 Phillips is what you need. Set it in the head by lightly tapping it in and turn the screws counter clockwise carefully slowly increasing force and they will come loose. Set the carb on a bench or table so you can hold the driver in there good. Some penetrating oil wouldn't hurt either. You don't need to take them out, just loosen them.
                          Before you do that loosen the nut on the shaft and see if that helps.
                          • sparkfly88
                            • Mar 2013
                            • 585
                            • CedarKey FL
                            okay, I got everything loose.
                            I can get the butterfly to act smoothly without that nut on the side.
                            But the MOMENT that nut comes into play even finger tight, things start binding up.
                            Whats the correct procedure to setting this?
                            EDIT
                            GOT IT!!
                            My problem was that one of the spring coils, sunk into the gap that was made when I loosened everything
                            Now its all tightened and working how it should be!
                            79F
                            "Excelsior"
                            Hid headlight 6000k
                            Stock jets
                            Shinko 712 F & R
                            TC fuse block
                            Raptor 660 Acct
                              That nut doesn't need to be "tight". It has a washer that bends over the flats to keep it from backing off. Screw it on to the point just before it starts binding and lock it there with the washer.
                              Then, close the butterfly all the way. Make sure it is centered good in the bore and retighten the screws.
                              Understand?
                                Just saw your edit. COOL! I suspected it was something simple like that.
                                There's all kinds of crazy stuff that can drive you up a wall with these bikes.
