First time working on multiple carbs on the Trashboat
  • sparkfly88
    • Mar 2013
    • 585
    • CedarKey FL
    #106
    Well I have a new handlebar coming from a gl1100 and the new intake boots.
    At least all the work I'm doing is improving it as I go along
    Here is the video of it running,
    It sounds FANTASTIC now that it's burning properly.
    Just need to seal up the vacuum leak.
    79F
    "Excelsior"
    Honda gl1100 handlebar
    Vetter IV fairing with speaker system
    OE headers,Jardine slipons
    Hid headlight 6000k
    Stock jets
    Shinko 712 F & R
    Oe hardbags and luggage rack
    TC fuse block
    K&n filter with oe airbox
    Raptor 660 Acct
    • sparkfly88
      • Mar 2013
      • 585
      • CedarKey FL
      #107
      Talk about a total transformation.
      It idles great!
      But now, all I need to do it slightly move the throttle and it floors it.
      All the intakes are sealed and tight. No vacuum leak from the petcock hoses or the end caps...
      Hmmmm....... Still an air problem?
      Maybe another carb cleaning is in order......?
      Here's the video...
      79F
      "Excelsior"
      Hid headlight 6000k
      Stock jets
      Shinko 712 F & R
      TC fuse block
      Raptor 660 Acct
      • WMarshy
        • Apr 2009
        • 2402
        • Mexico NY
        #108
        Originally posted by sparkfly88
        So I'm beginning to think they put the huge jets in the carb to even out this insane leak.
        They look pretty bad... Should I just order new intake boots from eBay...
        http://pages.ebay.com/motors/link/?n...d=190840370430
        Too lean will make it run away like that, too rich will make it dopey and unresponsive. In one of your videos it sounded like it popped once the RPM got up (~5K ) but then you hit the kill switch... if it starts popping then it means its getting more lean in that RPM range. Pull the plugs and post a picture of the color. Keep track of what hole they come out of (#1 cylinder is the left more cylinder sitting on the bike).
        Im not entirely sure but maybe the sync is off still... did you perform a sync? It might be best to pull them and do a bench sync to get you started but, to get it tuned the best you will need some type of sync "sticks" (vacuum gauges, fluid manometer). There are instructions on the site on building your own fluid manometer out of clean pvc hose and transmission fluid.
        '79 XS11 F
        Stock except K&N
        '79 XS11 SF
        Stock, no title.
        '84 Chevy K-10 "Big Blue"
        • sparkfly88
          • Mar 2013
          • 585
          • CedarKey FL
          #109
          I bought the Morgan carbtune. Cream of the crop right there.
          They are perfectly synced.
          I'm having the feeling I'm lean too.... But what to do to solve it.... Lol
          79F
          "Excelsior"
          Hid headlight 6000k
          Stock jets
          Shinko 712 F & R
          TC fuse block
          Raptor 660 Acct
            #110
            How did you set the idle mix screws?
            Adjust them to get the highest vacuum on each cylinder, then sync, then adjust for guest vacuum and sync again.
              #111
              You have no load on the engine, I am not sure it is wrong the way it is running. Look at the plugs. Take it out for a spin and see how she acts under load.
              • WMarshy
                • Apr 2009
                • 2402
                • Mexico NY
                #112
                IDK if I agree with that. The first thing I noticed after syncing my bike was its responsiveness. Not only opening the throttle but how fast it settled to idle rpm after letting the butterflies snap close... I still think he has a mixture and sync issue... something isnt right.
                '79 XS11 F
                Stock except K&N
                '79 XS11 SF
                Stock, no title.
                • sparkfly88
                  • Mar 2013
                  • 585
                  • CedarKey FL
                  #113
                  I have the carbs apart.... Again....
                  I'm gonna blow every single passage out again, and double check I didn't miss anything the first time..
                  Idk what else it could possibly be other than the carbs.. .
                  79F
                  "Excelsior"
                  Hid headlight 6000k
                  Stock jets
                  Shinko 712 F & R
                  TC fuse block
                  Raptor 660 Acct
                  • sparkfly88
                    • Mar 2013
                    • 585
                    • CedarKey FL
                    #114
                    Okay. A day and night of soaking in simple green and two cans of brake clean....
                    Assembling the carbs as I speak.
                    If it doesn't run right.... I really have no idea.
                    79F
                    "Excelsior"
                    Hid headlight 6000k
                    Stock jets
                    Shinko 712 F & R
                    TC fuse block
                    Raptor 660 Acct
                    • sparkfly88
                      • Mar 2013
                      • 585
                      • CedarKey FL
                      #115
                      It's aliveeeeeeeee muhahahahahaah
                      79F
                      "Excelsior"
                      Hid headlight 6000k
                      Stock jets
                      Shinko 712 F & R
                      TC fuse block
                      Raptor 660 Acct
                      • sparkfly88
                        • Mar 2013
                        • 585
                        • CedarKey FL
                        #116
                        Well, after changing the tires and rebuilding the suspension, I took it for a ride yesterday, and just now today.
                        I think it's starving for fuel.
                        If I keep it at a higher rpm while cruising, it bogs down, but if I slow down, then go faster again, it is restored for a little while.
                        If I recall what I have read, this can be caused by incorrect float level ( I have them set to OE specs.) or the tank valve isn't venting.
                        So my first experiment will be to ride with the cap hinged open.
                        If it still doesn't run, I'll tear into the carbs AGAIN and change the float levels.
                        Correct?
                        79F
                        "Excelsior"
                        Hid headlight 6000k
                        Stock jets
                        Shinko 712 F & R
                        TC fuse block
                        Raptor 660 Acct
                          #117
                          I really doubt it is float level. Cap vent is likely.
                          • sparkfly88
                            • Mar 2013
                            • 585
                            • CedarKey FL
                            #118
                            Isn't it Purdy?
                            79F
                            "Excelsior"
                            Hid headlight 6000k
                            Stock jets
                            Shinko 712 F & R
                            TC fuse block
                            Raptor 660 Acct
                            • sparkfly88
                              • Mar 2013
                              • 585
                              • CedarKey FL
                              #119
                              nastttyyyy!
                              Well I cleaned it up and that little brass doodad is now flopping around like it should I guess.
                              All the holes let air through and it's cleaned up.
                              79F
                              "Excelsior"
                              Hid headlight 6000k
                              Stock jets
                              Shinko 712 F & R
                              TC fuse block
                              Raptor 660 Acct
                              • sparkfly88
                                • Mar 2013
                                • 585
                                • CedarKey FL
                                #120
                                Okay so now I hear the vent in the tank working when I park it.
                                But now it's still erratically deciding it doesn't want to go above 4-5 K
                                Sometimes it's great, sometimes not.
                                79F
                                "Excelsior"
                                Hid headlight 6000k
                                Stock jets
                                Shinko 712 F & R
                                TC fuse block
                                Raptor 660 Acct
