First time working on multiple carbs on the Trashboat
  • sparkfly88
    • Mar 2013
    • 585
    • CedarKey FL
    #61
    79F
    "Excelsior"
    Honda gl1100 handlebar
    Vetter IV fairing with speaker system
    OE headers,Jardine slipons
    Hid headlight 6000k
    Stock jets
    Shinko 712 F & R
    Oe hardbags and luggage rack
    TC fuse block
    K&n filter with oe airbox
    Raptor 660 Acct
      Well it runs, try with the air box attached and a filter in there. They don't run too well with the backs of the carbs open like that. I'd check the sync also.
      • sparkfly88
        • Mar 2013
        • 585
        • CedarKey FL
        #63
        Okay. Will do.
        I'll also finish tuning it when I get the baffle and packing installed in the muffler
        79F
        "Excelsior"
        Hid headlight 6000k
        Stock jets
        Shinko 712 F & R
        TC fuse block
        Raptor 660 Acct
        • sparkfly88
          • Mar 2013
          • 585
          • CedarKey FL
          #64
          I don't think my bike likes the carbtune at all.
          It came today and I hooked it up.
          My carbs are a little off, pretty good for eyeballing it.... But it hated it.
          So, I think I'm gonna remove the carbs, get the OE type floats so I know without a doubt those will be right...
          It was purring away yesterday... Today, it's backfiring and blowing out the carbs at times.
          When it finally decides to idle... It'll be fine for a bit, then it'll skyrocket to 4k rpm and sit there till I turn the idle down...
          Ugh.
          Frustrating.
          79F
          "Excelsior"
          Hid headlight 6000k
          Stock jets
          Shinko 712 F & R
          TC fuse block
          Raptor 660 Acct
          • sparkfly88
            • Mar 2013
            • 585
            • CedarKey FL
            #65
            Ya know.... It sounds timing related.... Backfires and carb burps....
            I think I'll run out and get a timing light and check that out before fartin around with the carbs more...
            Ya think ?
            79F
            "Excelsior"
            Hid headlight 6000k
            Stock jets
            Shinko 712 F & R
            TC fuse block
            Raptor 660 Acct
              You don't need a light, just put a mark where the plate meets the engine case, loosen the 2 screws and rotate the plate CCW a little to advance. That way you can put it back to where it was if it doesn't help.
              • sparkfly88
                • Mar 2013
                • 585
                • CedarKey FL
                #67
                79F
                "Excelsior"
                Hid headlight 6000k
                Stock jets
                Shinko 712 F & R
                TC fuse block
                Raptor 660 Acct
                  #68
                  What are your idle mix screws set at right now?
                  • sparkfly88
                    • Mar 2013
                    • 585
                    • CedarKey FL
                    #69
                    In a nutshell.... If you don't wanna watch... It floors itself now if I touch the accelerator.
                    79F
                    "Excelsior"
                    Hid headlight 6000k
                    Stock jets
                    Shinko 712 F & R
                    TC fuse block
                    Raptor 660 Acct
                      #70
                      Put your idle mix screws at 3 turns out and start over. 1.5 is too lean.
                      • sparkfly88
                        • Mar 2013
                        • 585
                        • CedarKey FL
                        #71
                        So that'll be a cause of the hovering?
                        79F
                        "Excelsior"
                        Hid headlight 6000k
                        Stock jets
                        Shinko 712 F & R
                        TC fuse block
                        Raptor 660 Acct
                          #72
                          Could be...
                            • 3193
                            #73
                            When you throttle up and the idle hangs at higher RPM you are to lean.
                            I agree with Nate that you should try the pilot screws out a bit. I have carbs that are turned out as much as 5 turns and they work well. It is a matter of what the bike wants and not what the opening settings are.
                            If you read up a bit there is a recent thread about synching and then setting the pilots with the carbtune and then doing the synch all over again.
                            You synch the carbs and then set the idle by vacuum to the highest reading on each carb. Note you do not set them equal but to the highest on each cylinder. Then do a synch to balance the carbs. Well at least that is my understanding of the procedure. I have not yet tried this but it sounds good.
                            Rooster is trying that very method tonight with his carbs so maybe he will chime in as to how well it works. I use the colortune and then set it with plug color but this may well be a better method. YMMV
                            • sparkfly88
                              • Mar 2013
                              • 585
                              • CedarKey FL
                              #74
                              That makes sense. Better the burn the more oxygen that's pulled in. Thus the reading would be higher.
                              I'll experiment with that tomorrow.
                              I was unaware that the pilot screws could move to that much to adjust, I'll fidget more for sure.
                              Thanks guys!
                              79F
                              "Excelsior"
                              Hid headlight 6000k
                              Stock jets
                              Shinko 712 F & R
                              TC fuse block
                              Raptor 660 Acct
                              • sparkfly88
                                • Mar 2013
                                • 585
                                • CedarKey FL
                                #75
                                I tried adjusting the needles, and no change happened that was noticeable. It still revs high, and still hovers at RPM ranges...
                                I have the feeling the carbs are just running insane lean due to those aftermarket floats....which would explain the giant jets that had installed in it...
                                tomorrow I get paid, I'll order tires and the floats.
                                79F
                                "Excelsior"
                                Hid headlight 6000k
                                Stock jets
                                Shinko 712 F & R
                                TC fuse block
                                Raptor 660 Acct
