First time working on multiple carbs on the Trashboat
  • sparkfly88
    • Mar 2013
    • 585
    • CedarKey FL
    #46
    Got the float levels to 25.7mm as per the manual.
    Previous owner had them all basically flat and level...
    79F
    "Excelsior"
    Honda gl1100 handlebar
    Vetter IV fairing with speaker system
    OE headers,Jardine slipons
    Hid headlight 6000k
    Stock jets
    Shinko 712 F & R
    Oe hardbags and luggage rack
    TC fuse block
    K&n filter with oe airbox
    Raptor 660 Acct
    • tarzan
      • 1700
      • Chandler,Az.
      #47
      Those don't look right to me.They typically end up fairly level.IIRC
      80 SG XS1100
      14 Victory Cross Country
        Those aren't the right floats.
        • sparkfly88
          • Mar 2013
          • 585
          • CedarKey FL
          #49
          What?? The floats aren't OE???
          Gahhhhhhhhhhhhdkkwnfjenfd
          79F
          "Excelsior"
          Hid headlight 6000k
          Stock jets
          Shinko 712 F & R
          TC fuse block
          Raptor 660 Acct
          • sparkfly88
            • Mar 2013
            • 585
            • CedarKey FL
            #50
            Well... I hope I can find a cheaper alternative...
            http://www.boats.net/parts/detail/ya...985-01-00.html
            79F
            "Excelsior"
            Hid headlight 6000k
            Stock jets
            Shinko 712 F & R
            TC fuse block
            Raptor 660 Acct
            • jwhughes3
              • 2798
              • Home of the Alamo
              #51
              These are the correct shape and price.
              John
              '81 XS1100H - "Enterprise"
              • sparkfly88
                • Mar 2013
                • 585
                • CedarKey FL
                #52
                Wow what a price difference!
                It's compatible with my 79? They have 1980 listed, but not 79..
                Thanks either way! Wow
                79F
                "Excelsior"
                Hid headlight 6000k
                Stock jets
                Shinko 712 F & R
                TC fuse block
                Raptor 660 Acct
                  The easiest way would be to get the correct brass or plastic floats (they are interchangeable) which then could be set to the correct measurement. You could probably get those that you have to work by using the clear plastic tube method to get them all at the same/correct level. This would probably involve removing the carbs and resetting the floats many times. If you have the few extra bucks I would just get the correct floats, waaaay less hassle, JMHO.
                  • jwhughes3
                    • 2798
                    • Home of the Alamo
                    #54
                    Yes floats can be used in any year, you just have a separate height adjustment for plastic (23mm) vs brass (25.7mm) floats.
                    bikerphil has a good method there for setting levels, but I havent found swapping types to need more than a ruler. Then on second thought I am not 100% positive those carbs I did were supposed to be plastic in first place. I did that a few years ago.
                    John
                    • sparkfly88
                      • Mar 2013
                      • 585
                      • CedarKey FL
                      #55
                      Well just for some giggles... I put the carbs on with the floats as they were. I synced the valves manually and turned the idle screws out 1 3/4 turn.
                      I just wanted to see if it would run at all, and if it sounded any better with the carbs at least clean and somewhat synced.
                      It didn't. Lol.
                      So.... I'm gonna buy the correct floats...
                      I also think the floats how I set them were starving the engine out anyway, it would only run with the fully enriched mode.
                      I heard the bike run though... I missed it, as crappy as it runs. It'll just get better from here.
                      With the proper fuel levels, synced carbs, and proper back pressure, it'll run.
                      I hope.
                      79F
                      "Excelsior"
                      Hid headlight 6000k
                      Stock jets
                      Shinko 712 F & R
                      TC fuse block
                      Raptor 660 Acct
                        Those floats should all be about level, then it will have enough fuel to run. They should all be the same measurment whatever that would be.
                        • sparkfly88
                          • Mar 2013
                          • 585
                          • CedarKey FL
                          #57
                          Your up still? Lol.
                          We should be asleep
                          79F
                          "Excelsior"
                          Hid headlight 6000k
                          Stock jets
                          Shinko 712 F & R
                          TC fuse block
                          Raptor 660 Acct
                            Na, just got in.
                            • sparkfly88
                              • Mar 2013
                              • 585
                              • CedarKey FL
                              #59
                              I'll set the floats level and see what happens.
                              It would be nice to see an improvement with what I have done.
                              Just for progress sake... I miss riding it. So I want to hear it at least!
                              79F
                              "Excelsior"
                              Hid headlight 6000k
                              Stock jets
                              Shinko 712 F & R
                              TC fuse block
                              Raptor 660 Acct
                              • sparkfly88
                                • Mar 2013
                                • 585
                                • CedarKey FL
                                #60
                                I leveled the floats this morning and popped the carbs back on for curiosity sake. Since I know it ran ( ish ) with the floats how they were, I just put em back to it.
                                it runs without the choke now. but still not the best, heck, it ran better before.
                                Guess I really have to wait for the Carbtune to come...
                                79F
                                "Excelsior"
                                Hid headlight 6000k
                                Stock jets
                                Shinko 712 F & R
                                TC fuse block
                                Raptor 660 Acct
