First time working on multiple carbs on the Trashboat
  • sparkfly88
    • Mar 2013
    • 585
    • CedarKey FL
    #76
    Set to 23mm from the highest point of the float.
    This look right now?
    79F
    "Excelsior"
    Honda gl1100 handlebar
    Vetter IV fairing with speaker system
    OE headers,Jardine slipons
    Hid headlight 6000k
    Stock jets
    Shinko 712 F & R
    Oe hardbags and luggage rack
    TC fuse block
    K&n filter with oe airbox
    Raptor 660 Acct
      #77
      Yes, but you may want to drop that tang that bumps the float post so the float can not drop quite so far. They tend to bind up if you let them drop to far.
      • sparkfly88
        • Mar 2013
        • 585
        • CedarKey FL
        #78
        Alright.... So.....
        When it first started up, it skyrockets. When it warmed up, it was pretty nice.
        Later as it warmed more, it got a little rough.
        So I wondered...
        I pulled number 1 plug wire while it putted along. No change. At all. Plug wire would put weak sparks against block when running.
        Number 2 will kill the engine when pulled. Same with number 3.
        Number 4 zapped me when I touched it and that ended the test because the engine wouldn't stay idled and I killed the battery trying to keep it idling.
        So when I get the battery charged up, I'll check number 4 plug wire.
        But. It cruises with no load now. It doesn't like to. And it's kinda rough. But it's better than nothing at this point. I'll take a video next time I get it running and I pull the wires
        79F
        "Excelsior"
        Hid headlight 6000k
        Stock jets
        Shinko 712 F & R
        TC fuse block
        Raptor 660 Acct
        • CaptonZap
          • Jun 2010
          • 1748
          • Denver
          #79
          Sounds like you are running on #2&3, with 1&4 not doing much.
          The left hand coil is the 1&4 coil, so check the resistance through the primary and secondary windings. You should get the same spark intensity through both plugs when the coil fires. If you don't, look for leakage in the high tension wires to ground, defective plug caps and/or resister in the cap, fouled center electrode of plug, wrong gap in plug, etc.
          CZ
          • sparkfly88
            • Mar 2013
            • 585
            • CedarKey FL
            #80
            I wonder....
            I remember posting that I bought the coils from mike's Xs.... But... It appears the post and opinions about Em are gone... Where'd they go....?
            79F
            "Excelsior"
            Hid headlight 6000k
            Stock jets
            Shinko 712 F & R
            TC fuse block
            Raptor 660 Acct
              The site was moved to a new server and a weeks worth of posts have bit the dust.
              • sparkfly88
                • Mar 2013
                • 585
                • CedarKey FL
                #82
                Well it's better that reason than what I thought happened. On other forums I have seen posts deleted because of bad product reviews n such.
                Well, tomorrow I get some packages in the mail, and the coils should be one of them.
                I haven't touched the bike in a week and I'm getting anxious to make this darn thing run like I know it can.
                Right now I feel as though I went backwards, it at least ran before I changed out carb internals and such.
                Now it's being temperamental and I gotta figure out why.
                :: shakes fist ::
                79F
                "Excelsior"
                Hid headlight 6000k
                Stock jets
                Shinko 712 F & R
                TC fuse block
                Raptor 660 Acct
                  Just a heads up, I've seen those MikesXS coils burn up if you are running the bike and testing for a dead cylinder by pulling one of the plug wires off. Make sure both plug wires are connected when running and you should be fine with them. GL.
                  • sparkfly88
                    • Mar 2013
                    • 585
                    • CedarKey FL
                    #84
                    I remember reading about the failures on the website thanks for the extra heads up though.
                    on the walk through he used 8 millimeter wire, is that what would be used for it, or he just used what he had to make it work?
                    79F
                    "Excelsior"
                    Hid headlight 6000k
                    Stock jets
                    Shinko 712 F & R
                    TC fuse block
                    Raptor 660 Acct
                      You can use either 7 or 8 MM wires, shouldn't matter.
                      • sparkfly88
                        • Mar 2013
                        • 585
                        • CedarKey FL
                        #86
                        Thanks for the quick reply. I'm planning in hitting the auto store in a bit to go get Em.
                        I saw the 8 mm fit a bit tight on the walk through. So maybe 7mm will work better.. I'll bring a coil to test fit some wires.
                        79F
                        "Excelsior"
                        Hid headlight 6000k
                        Stock jets
                        Shinko 712 F & R
                        TC fuse block
                        Raptor 660 Acct
                        • sparkfly88
                          • Mar 2013
                          • 585
                          • CedarKey FL
                          #87
                          I'm pretty electronically retarded..... Plus I really don't wanna fry these things...
                          Which primaries are positive and negative?
                          The coils are marked that way, and I really don't wanna fudge up
                          Also. Never messed with these kinda coils.... I suppose I just push the wires into them and make sure they bottom out, making the spear tip in the coil poke into the wire making the connection?
                          79F
                          "Excelsior"
                          Hid headlight 6000k
                          Stock jets
                          Shinko 712 F & R
                          TC fuse block
                          Raptor 660 Acct
                            #88
                            If the primary connections are marked, connect the red/white wire to +, the orange/grey to -......
                            • sparkfly88
                              • Mar 2013
                              • 585
                              • CedarKey FL
                              #89
                              Thanks! Man that was fast.
                              I'm in the process of figuring out making the coils and wires. Lol.
                              79F
                              "Excelsior"
                              Hid headlight 6000k
                              Stock jets
                              Shinko 712 F & R
                              TC fuse block
                              Raptor 660 Acct
                              • sparkfly88
                                • Mar 2013
                                • 585
                                • CedarKey FL
                                #90
                                ALRIGHTY THEN. I seem to have run into a problem.
                                Seems faulty mass production has struck.
                                I simply went to remove the connection to heat shrink it and the entire damn plug came with it.
                                I'm livid. OH AND GUESS WHAT. The other connection is getting ready to do the same thing, I went to slide the connection off and I saw the entire thing move instead.
                                79F
                                "Excelsior"
                                Hid headlight 6000k
                                Stock jets
                                Shinko 712 F & R
                                TC fuse block
                                Raptor 660 Acct
