First time working on multiple carbs on the Trashboat
  • Tat2demon
    • Jun 2012
    • 718
    • Sioux Falls, South Dakota
    I threw my colortune in the garbage. Used it twice and was good but then it started arcing from the electrode to the body, not igniting the fuel. I tried all ways of insulating it but it was way too much trouble. Seems its not an uncommon problem. Ill stick with vacuum gauges and ear from now on.
    Nate
    78 XS11 "Matilda" 2H7 000364
    K+N Air Filter
    88 Voyager XII
    81 XJ650 Maxim
    • sparkfly88
      • Mar 2013
      • 585
      • CedarKey FL
      I've never done ear tuning with multiple carbs.
      There just seems like too many variables.
      79F
      "Excelsior"
      Honda gl1100 handlebar
      Vetter IV fairing with speaker system
      OE headers,Jardine slipons
      Hid headlight 6000k
      Stock jets
      Shinko 712 F & R
      Oe hardbags and luggage rack
      TC fuse block
      K&n filter with oe airbox
      Raptor 660 Acct
        You can adjust the idle mix with whatever you use for syncing (carbtune) by Adjusting the idle mix screws to the highest vacuum you can get. Do that on each cylinder and then sync again. Any further adjustments you do will be very small and can then be done by checking plug color.
        Again I say that they Morgan Carbtune is the best tool for this. Others work well and cost less, but the Morgan Carbtune is easier to use and less fuss, smaller and much more portable if you want to help others out.
        • sparkfly88
          • Mar 2013
          • 585
          • CedarKey FL
          What I had confused what the Gunson carbtune thing and the Morgan.
          79F
          "Excelsior"
          Hid headlight 6000k
          Stock jets
          Shinko 712 F & R
          TC fuse block
          Raptor 660 Acct
          • sparkfly88
            • Mar 2013
            • 585
            • CedarKey FL
            Well my boxes arrived for the carbs.
            Looks like I have 42, 137, and 180 numbered parts.
            79F
            "Excelsior"
            Hid headlight 6000k
            Stock jets
            Shinko 712 F & R
            TC fuse block
            Raptor 660 Acct
              Those pilot jets look wrong. If they have anything others than 6 holes (2-1-2-1 pattern) around the side they will not work.
              • sparkfly88
                • Mar 2013
                • 585
                • CedarKey FL
                that's the one marked 42.
                It has 8 holes 2-2-2-2
                79F
                "Excelsior"
                Hid headlight 6000k
                Stock jets
                Shinko 712 F & R
                TC fuse block
                Raptor 660 Acct
                  Don't use those, use your old ones, should say 42.5 or 45 on them with 6 air bleed holes.
                    Yup, do not use those 8 hole pilot jets.
                    • sparkfly88
                      • Mar 2013
                      • 585
                      • CedarKey FL
                      180 42.5 and 152 are my jets.
                      The 6 hole staggered pilots have been pretty fubard by the previous owners...
                      It has the all metal float valves. Should I keep them, or install the new plastic tipped ones from the kits?
                      I kept them in the rack and took Em apart.
                      Right now the bodies are soaking in pinesol in a five gallon bucket.
                      Guess I need 4 New 6 hole 42.5s...I bet if I put them in with their current state, getting them out again will involve drilling. The screw slot is pretty shot...
                      79F
                      "Excelsior"
                      Hid headlight 6000k
                      Stock jets
                      Shinko 712 F & R
                      TC fuse block
                      Raptor 660 Acct
                        Yup, gunna need the correct 42.5 pilot jets.
                        Those 152 jets will be WAY too big. 137.5 is stock and I doubt one could make enough mods to need 152's.
                        In the pics it looks like the replacement float needles are all metal. Stick with the all metal ones.
                        • sparkfly88
                          • Mar 2013
                          • 585
                          • CedarKey FL
                          So maybe that's why I'm running so rich? Lol lol
                          The replacements weren't all metal. But what is in the carbs right now are all metal.
                          I remembered reading about the plastic issues..that's why I knew to ask.
                          79F
                          "Excelsior"
                          Hid headlight 6000k
                          Stock jets
                          Shinko 712 F & R
                          TC fuse block
                          Raptor 660 Acct
                          • sparkfly88
                            • Mar 2013
                            • 585
                            • CedarKey FL
                            Okay, so I ran all the innards and bowls through my ultrasonic.
                            The carbs were soaked overnight in pinesol, then blown out with carb cleaner spray.
                            Does look like someone sliced into the pilot already, so someone had issues previously...
                            79F
                            "Excelsior"
                            Hid headlight 6000k
                            Stock jets
                            Shinko 712 F & R
                            TC fuse block
                            Raptor 660 Acct
                              Yeah, just to save yourself from future issues, easiest just to replace them now. Make absolutly sure that you go out and buy a cheap screwdriver and shape it to fit those jets EXACTLY before you put the new ones in. Keep that screwdriver somewhere and always use it to remove and install those jets.
                              • sparkfly88
                                • Mar 2013
                                • 585
                                • CedarKey FL
                                I did that already to get these out
                                79F
                                "Excelsior"
                                Hid headlight 6000k
                                Stock jets
                                Shinko 712 F & R
                                TC fuse block
                                Raptor 660 Acct
