I threw my colortune in the garbage. Used it twice and was good but then it started arcing from the electrode to the body, not igniting the fuel. I tried all ways of insulating it but it was way too much trouble. Seems its not an uncommon problem. Ill stick with vacuum gauges and ear from now on.
First time working on multiple carbs on the Trashboat
Nate
78 XS11 "Matilda" 2H7 000364
K+N Air Filter
88 Voyager XII
81 XJ650 Maxim -
I've never done ear tuning with multiple carbs.
There just seems like too many variables.79F
"Excelsior"
Honda gl1100 handlebar
Vetter IV fairing with speaker system
OE headers,Jardine slipons
Hid headlight 6000k
Stock jets
Shinko 712 F & R
Oe hardbags and luggage rack
TC fuse block
K&n filter with oe airbox
Raptor 660 AcctComment
You can adjust the idle mix with whatever you use for syncing (carbtune) by Adjusting the idle mix screws to the highest vacuum you can get. Do that on each cylinder and then sync again. Any further adjustments you do will be very small and can then be done by checking plug color.
Again I say that they Morgan Carbtune is the best tool for this. Others work well and cost less, but the Morgan Carbtune is easier to use and less fuss, smaller and much more portable if you want to help others out.Nathan
Theodore RooseveltComment
What I had confused what the Gunson carbtune thing and the Morgan.79F
"Excelsior"
Hid headlight 6000k
Stock jets
Shinko 712 F & R
TC fuse block
Well my boxes arrived for the carbs.
Looks like I have 42, 137, and 180 numbered parts.
79F
"Excelsior"
Hid headlight 6000k
Stock jets
Shinko 712 F & R
TC fuse block
Those pilot jets look wrong. If they have anything others than 6 holes (2-1-2-1 pattern) around the side they will not work.Nathan
79F
"Excelsior"
Hid headlight 6000k
Stock jets
Shinko 712 F & R
TC fuse block
Yup, do not use those 8 hole pilot jets.Nathan
180 42.5 and 152 are my jets.
The 6 hole staggered pilots have been pretty fubard by the previous owners...
It has the all metal float valves. Should I keep them, or install the new plastic tipped ones from the kits?
I kept them in the rack and took Em apart.
Right now the bodies are soaking in pinesol in a five gallon bucket.
Guess I need 4 New 6 hole 42.5s...I bet if I put them in with their current state, getting them out again will involve drilling. The screw slot is pretty shot...79F
"Excelsior"
Hid headlight 6000k
Stock jets
Shinko 712 F & R
TC fuse block
Yup, gunna need the correct 42.5 pilot jets.
Those 152 jets will be WAY too big. 137.5 is stock and I doubt one could make enough mods to need 152's.
In the pics it looks like the replacement float needles are all metal. Stick with the all metal ones.Nathan
So maybe that's why I'm running so rich? Lol lol
The replacements weren't all metal. But what is in the carbs right now are all metal.
I remembered reading about the plastic issues..that's why I knew to ask.79F
"Excelsior"
Hid headlight 6000k
Stock jets
Shinko 712 F & R
TC fuse block
79F
"Excelsior"
Hid headlight 6000k
Stock jets
Shinko 712 F & R
TC fuse block
Yeah, just to save yourself from future issues, easiest just to replace them now. Make absolutly sure that you go out and buy a cheap screwdriver and shape it to fit those jets EXACTLY before you put the new ones in. Keep that screwdriver somewhere and always use it to remove and install those jets.Nathan
I did that already to get these outYeah, just to save yourself from future issues, easiest just to replace them now. Make absolutly sure that you go out and buy a cheap screwdriver and shape it to fit those jets EXACTLY before you put the new ones in. Keep that screwdriver somewhere and always use it to remove and install those jets.
79F
"Excelsior"
Hid headlight 6000k
Stock jets
Shinko 712 F & R
TC fuse block
