First time working on multiple carbs on the Trashboat
  • spayne83
    • Jan 2013
    • 159
    • Campbell, CA.
    #91
    I had the same thing happen to me. How long have you had those coils? I had that happen when I first installed mine and I emailed MikesXS and they sent me a new pair and then refunded my money when those failed as well, so it is worth a try.
    Personally, I switched to the Dyna Coils with their screw on connectors.
    79 SF 3H3 Engine, 145/45 Mikuni Jets, El Cheapo Pod Filter Mod w/ EMGO Pods, Coil Repower w/ Dyna Coils, Accell Wires and Side Gapped Plugs, 78 Mech Advance, 4-2 Turnouts
    • sparkfly88
      • Mar 2013
      • 585
      • CedarKey FL
      #92
      I got them in the mail yesterday....
      Went to install them today and didn't even get outside with them...
      79F
      "Excelsior"
      Honda gl1100 handlebar
      Vetter IV fairing with speaker system
      OE headers,Jardine slipons
      Hid headlight 6000k
      Stock jets
      Shinko 712 F & R
      Oe hardbags and luggage rack
      TC fuse block
      K&n filter with oe airbox
      Raptor 660 Acct
      • sparkfly88
        • Mar 2013
        • 585
        • CedarKey FL
        #93
        I will have a replacement shipped in the next day, these terminals are sensitive, so on the replacement, please handle carefully.
        MikesXs
        Shouldn't that be listed on the website, and I guess that makes these a set and forget type of device
        79F
        "Excelsior"
        Hid headlight 6000k
        Stock jets
        Shinko 712 F & R
        TC fuse block
        Raptor 660 Acct
        • sparkfly88
          • Mar 2013
          • 585
          • CedarKey FL
          #94
          Kyle,
          Before we send the replacement please try the other coil? If faulty we suggest a refund, as these have been questionable, please advise.
          MikesXS
          79F
          "Excelsior"
          Hid headlight 6000k
          Stock jets
          Shinko 712 F & R
          TC fuse block
          Raptor 660 Acct
            #95
            Hmmmm....
            If your on a budget, the Honda VF1000 coils are nice "upgrade". Otherwise, Accel or Dyna are the better choice for true increased performance over the stock units.
              #96
              I would just break the other one and get a refund and get something of better known quality.
              • sparkfly88
                • Mar 2013
                • 585
                • CedarKey FL
                #97
                Well... He wanted me to test it, so I did.
                I plugged in both terminals of the other one... And one of the spade connectors came right off.
                Emailed him that the other was faulty as well.
                So, what can I use now that is plug n play?
                79F
                "Excelsior"
                Hid headlight 6000k
                Stock jets
                Shinko 712 F & R
                TC fuse block
                Raptor 660 Acct
                • Rasputin
                  • 3193
                  • Lacombe, Alberta, Canada
                  #98
                  I run the Accels on one of my bikes and they are pretty goof proof but pricey. I did have one that was out of spec as I tested it before mounting it. I contacted them and they made good very fast. Got a few years out of them so far and no issues. Unknown amount of mileage at this time on these units as I forget when I even mounted them. Works great if you are using a colortune as well as the spark is very good. Sometimes cheaper wins and sometimes it sucks.
                  2-79 XS1100 SF
                  2-78 XS1100 E Best bike Ever
                    • 8930
                    Accel
                    Dynatek
                    Honda VF1000
                    XS/XJ 1100 81-82
                    Connections for the primary side will need to be spliced, plugs are not the same.
                    • sparkfly88
                      • Mar 2013
                      • 585
                      • CedarKey FL
                      #100
                      I found this list on the forum archive..
                      Honda VF 500 FE/F2E 84 Ignition Coil
                      Honda VF 500 FF/F2F 85 Ignition Coil
                      Honda VT 500 ED 83-86 Ignition Coi
                      lHonda VT 500 EF 86-88 Ignition Coi
                      lHonda VF 750 FD RC15 83-84 Ignition Coil
                      Honda VF 750 FE RC15 84-86 Ignition Coi
                      lHonda VF 1000 FE SC15 84 Ignition Coil
                      Honda VF 1000 FF/FG/F2F/F2G 84-88 Ignition Coi
                      lHonda VF 1000 RE/RF/RG 84-86 Ignition Coil
                      Kawasaki VN 700 A1 Vulcan 85 Ignition Coil
                      Kawasaki ZN 700 A1/A2 LTD 84-85 Ignition Coil
                      Kawasaki VN 750 A2-A5 85-90 Ignition Coil
                      Kawasaki VN 750 A9/A10 93-94 Ignition Coi
                      lKawasaki VN 1500 A6 (VN15) 92 Ignition Coil
                      Kawasaki VN 1500 B2-B6 (VN15SE) 88-92 Ignition Coil
                      Kawasaki VN 1500 C1/C2 (VN15) 94-95 Ignition Coil*
                      79F
                      "Excelsior"
                      Hid headlight 6000k
                      Stock jets
                      Shinko 712 F & R
                      TC fuse block
                      Raptor 660 Acct
                      • sparkfly88
                        • Mar 2013
                        • 585
                        • CedarKey FL
                        #101
                        Well, mikesXS emailed me again, and wanted me to check the other coil....
                        I did, and it broke just like the other one.
                        So, he said he went through the boxes of coils and found the "faulty" box, and handpicked me out a couple good coils.
                        They should be here sometime this week.
                        79F
                        "Excelsior"
                        Hid headlight 6000k
                        Stock jets
                        Shinko 712 F & R
                        TC fuse block
                        Raptor 660 Acct
                          #102
                          Good Luck!! I'd hold the coils by those tabs and walk with them like that. Think about the vibrations of the wires on those tabs while the bikes running, and how long till one might break when your 150 miles form home.
                          • sparkfly88
                            • Mar 2013
                            • 585
                            • CedarKey FL
                            #103
                            Alright!
                            Well I got the coils yesterday.
                            First thing I did was 2 ton epoxy the primaries and let Em set for a day.
                            Today I got home from work, installed the wires on them and installed them into the bike.
                            WOW what a difference. There is no stumble now, no hesitation.
                            Only problem is that it is so happy, it floors itself.
                            No matter how far back I adjust the idle, it only slows down the extreme acceleration.
                            So, I have spark and alot of it. It fires right up with no delay..
                            Now, what the heck is going on now?
                            79F
                            "Excelsior"
                            Hid headlight 6000k
                            Stock jets
                            Shinko 712 F & R
                            TC fuse block
                            Raptor 660 Acct
                            • GLoweVA
                              • Jun 2011
                              • 1957
                              • Virginia Beach, VA.
                              #104
                              sounds like a vacuum leak.
                              It's allowing air in and thus more combustion, then more revs, and such until its outta control.
                              Check to make sure your carb boots are snug up tight, I've had one of those allen bolts back right out due to vibration.
                              If you've got a sync gauge(s) then you can hook them up to the carb boot intack nipples and see what suction you've got and adjust all 4 to 'suck' the same amount, then adjust your master idle set screw to get her back down to about 1100rpms.
                              80G (Green paint(PO idea))
                              The Green Monster
                              Got him in '04.
                              bald tire & borrowing parts
                              Scarlet
                              Got her in '11
                              Ready for the twisties!
                              81H (previously CPMaynard's)
                              Hugo
                              Cold weather ride
                              • sparkfly88
                                • Mar 2013
                                • 585
                                • CedarKey FL
                                #105
                                So I'm beginning to think they put the huge jets in the carb to even out this insane leak.
                                They look pretty bad... Should I just order new intake boots from eBay...
                                79F
                                "Excelsior"
                                Hid headlight 6000k
                                Stock jets
                                Shinko 712 F & R
                                TC fuse block
                                Raptor 660 Acct
