Carbs done!
  • #76
    No its on 4. Figured that way if it caused a problem I could get to it without removing the carbs. Popped the cable off, no change. Made sure to check for any rubbing too.
    Nate
    78 XS11 "Matilda" 2H7 000364
    K+N Air Filter
    88 Voyager XII
    81 XJ650 Maxim
    • #77
      I did notice this morning that the diaphrams are from a later model. Should have the ones with the adjustable clip needle but these have the washers.
      Nate
      K+N Air Filter
      88 Voyager XII
      81 XJ650 Maxim
      • #78
        If you have the wrong needles in there that could be your problem...
        • #79
          Should I put in the ones from the Georgefix sets? You said dont use the jets so I didnt touch the needles either. No idea whats in them now. My clip pliers isnt long enough to get to the c-clip.
          Nate
          K+N Air Filter
          88 Voyager XII
          81 XJ650 Maxim
          • #80
            even if it was on the lean side,
            the idle/revs mite hang for a little but
            it should still return to normal,
            when u pull the carbs again just make sure
            the throttle valves arent sticking, it only takes 1.
            or maybe u havent synced the carbs properly.
            hold the carbs up to the light and have a look at each
            throttle valve and see if they all look like there in the same
            or at least close position.
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            1981 xs1100 RH (aus) (5N5)
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
            • #81
              A couple of picks work well. I put the needle lightly in the vice, just enough to hold it from flying out, remove the clipthen hold your hand over the top of the slide and release the needle. It'll pop up and hit your hand instead of flying across the room.
              Reverse to reinstall.
              Check around, you can get just the bowl gaskets. That's all you really need.
              • #82
                Ah ha! I didn't think about picks. Great idea.
                I don't need gaskets anymore. I bought 4 kits from George a couple weeks ago to not only replace the gaskets but also all the idle screws. Unfortunately he doesn't sell just the screws. All the jets that came with are sitting in a bag in case I ever need them.
                Nate
                K+N Air Filter
                88 Voyager XII
                81 XJ650 Maxim
