No its on 4. Figured that way if it caused a problem I could get to it without removing the carbs. Popped the cable off, no change. Made sure to check for any rubbing too.
Carbs done!
Nate
78 XS11 "Matilda" 2H7 000364
K+N Air Filter
88 Voyager XII
81 XJ650 Maxim -
I did notice this morning that the diaphrams are from a later model. Should have the ones with the adjustable clip needle but these have the washers.Nate
K+N Air Filter
88 Voyager XII
81 XJ650 MaximComment
If you have the wrong needles in there that could be your problem...Fast, Cheap, Reliable... Pick any two
Should I put in the ones from the Georgefix sets? You said dont use the jets so I didnt touch the needles either. No idea whats in them now. My clip pliers isnt long enough to get to the c-clip.Nate
K+N Air Filter
88 Voyager XII
even if it was on the lean side,
the idle/revs mite hang for a little but
it should still return to normal,
when u pull the carbs again just make sure
the throttle valves arent sticking, it only takes 1.
or maybe u havent synced the carbs properly.
hold the carbs up to the light and have a look at each
throttle valve and see if they all look like there in the same
or at least close position.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
Reverse to reinstall.
Check around, you can get just the bowl gaskets. That's all you really need.Greg
The list changes.Comment
Ah ha! I didn't think about picks. Great idea.
I don't need gaskets anymore. I bought 4 kits from George a couple weeks ago to not only replace the gaskets but also all the idle screws. Unfortunately he doesn't sell just the screws. All the jets that came with are sitting in a bag in case I ever need them.Nate
K+N Air Filter
88 Voyager XII
